| BIG T's first off road build | |
+3AllisKidD21 mr.modified BIGT 7 posters |
BIGT New Member
Age : 26 Join date : 2014-02-08 Points : 3720 Posts : 12 Location : pei
| Subject: BIG T's first off road build January 7th 2017, 9:09 pm | |
| I figured id start my first build so i have 90's ford yt16h its got 16hp kohler twin and a hydro rear plans for it would be to lift in to fit 27" mud zilla tires swap out the hydro and add bumpers winch rack extra lights im open to ideas and such and i will post pics sometime tomorrow if i can find it after the snowstorm i might do a youtube build series on it as well for you guys to see whats going on other than just the pictures im very open to ideas of what to do and such i may not use all of the suggestions but i will try and use as many as possible | |
Age : 34 Join date : 2013-11-02 Points : 6926 Posts : 2906 Location : New Jersey USA
BIGT New Member
| Subject: Re: BIG T's first off road build January 10th 2017, 1:01 pm | |
| heres basically what im starting with and yes i got that pic off google but mine looks pretty well identical ive started looking for parts the biggest thing is gonna be finding the peerless 820 transaxle and swapping everything over from hydro to geared my plans for this tractor will be: dual throttle 27" mudzilla rear tires different front tires (i have no idea on them) bumper rack storage winch lights better trailer hitch charging system air compressor and quick disconnect booster cables Im open to everyones ideas and suggestions just post a reply | |
Age : 25 Join date : 2016-07-10 Points : 8350 Posts : 5190 Location : Ontario Canada
| Subject: Re: BIG T's first off road build January 10th 2017, 1:12 pm | |
| Should be cool! When you say dual throttle, do you mean hand and foot throttle? That's what I'm planning on adding to mine as well. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
BIGT New Member
Age : 23 Join date : 2016-04-12 Points : 5719 Posts : 2617 Location : Indiana
| Subject: Re: BIG T's first off road build January 10th 2017, 2:05 pm | |
| Carlisle snow hogs and X-tracs are pretty commonly run on the front. Fearless runs the snow hogs and redneckcomputergeek runs the x-tracs. I still haven't decided between the two lol | |
BIGT New Member
| Subject: Re: BIG T's first off road build January 10th 2017, 2:09 pm | |
| at the same time i also want this build to stand out and do stuff that no one has done before on a off road build | |
tater195 Member
| Subject: Re: BIG T's first off road build January 10th 2017, 3:29 pm | |
| The YT16s with the gear tx were prone to snapping axles. They had 23" tires on 12" wheels and 3/4" axles. They were not a bad mower, but using them for anything other than that was asking for trouble. You can overdrive the hydro a little. With the 27s and a mild pulley swap you should be able to get it in the 10mph range. | |
BIGT New Member
| Subject: Re: BIG T's first off road build January 10th 2017, 5:01 pm | |
| - tater195 wrote:
- The YT16s with the gear tx were prone to snapping axles. They had 23" tires on 12" wheels and 3/4" axles. They were not a bad mower, but using them for anything other than that was asking for trouble. You can overdrive the hydro a little. With the 27s and a mild pulley swap you should be able to get it in the 10mph range.
it all depends on how you build it too and for speed wise im looking to get between 20 and 30km/h | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4859 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: BIG T's first off road build January 10th 2017, 5:24 pm | |
| On the charging system, maybe a 10/12 SI GM alternator . The original 10 SI can go up to 63 amps (steel fan), while the original 12 SI alternator goes up to 94 amps (plastic fan). With a volt gauge and dummy light in the dash. Pretty easy and reliable setup. | |
BIGT New Member
| Subject: Re: BIG T's first off road build January 10th 2017, 7:14 pm | |
| - prancstaman wrote:
- On the charging system, maybe a 10/12 SI GM alternator . The original 10 SI can go up to 63 amps (steel fan), while the original 12 SI alternator goes up to 94 amps (plastic fan). With a volt gauge and dummy light in the dash. Pretty easy and reliable setup.
where would be the best place to mount it as this tractor may see some mud on the trails and such | |
| Subject: Re: BIG T's first off road build January 10th 2017, 9:11 pm | |
| Looks like a vertical shaft engine. Maybe mount a pulley on top of the engine, centering would be mandatory though, like a home made pull start setup, to drive the alternator. Then make a bracket to hold alternator in front of motor. In engine compartment away from any mud. | |
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5476 Posts : 1398 Location : Central PA
| Subject: Re: BIG T's first off road build January 11th 2017, 2:14 pm | |
| - BIGT wrote:
- yeah foot throttle and the dash for long adventures
Cool! Make sure to post lots of pictures of that. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
BIGT New Member
| Subject: Re: BIG T's first off road build January 11th 2017, 11:38 pm | |
| To the transaxle breakage it's probs because you had a Spicer in there I'm trying to find a peerless 820 transaxle and I do plan on adding lots support in that area and skid plate for sure only because it will take lots of abuse and I will take pics when I do the dual throttle | |
| Subject: Re: BIG T's first off road build January 12th 2017, 10:00 am | |
| That particular spicer is identical to a peerless... not sure what one though.
The rig was free anyway. Woot.
BIGT New Member
| Subject: Re: BIG T's first off road build January 12th 2017, 1:46 pm | |
| Yeah the one that's in mine is a hydro and it's got the 1 inch axles just like the peerless 820 so I'm hoping that will be heavy duty enough | |
BIGT New Member
| Subject: Re: BIG T's first off road build April 13th 2017, 2:15 pm | |
| Just a lil update I finally decided to pull it out and do an lil bit of work to it I'm currently working on pulling turf savers 20 10 8 on the front with a mild lift and got rid of all the hydro setup and I finally found a peerless 820 transaxle already locked and greased | |
