| | My main murray | |
SatiricalHen Member
Join date : 2016-04-07 Points : 2992 Posts : 49 Location : South Carolina
| Subject: My main murray April 7th 2016, 10:39 pm | |
| This is my murray I've built recently. It's my go to tractor for doing work and having fun, the most reliable one I have, and works well. Some background on it. I traded 2 cheap LED light bars for it off of my jeep. Got it right before some snow we had, first snow day I took it out with my other offroad mower (at the time sold off now) and I slid into mud and knocked the bead off the rear tire. Then that night my friend and I welded a front bumper on it, put another set of tires on the rear and put some snow chains on. So that gets us through the snow. | |
| | | SatiricalHen Member
| | | | SatiricalHen Member
| Subject: Re: My main murray April 7th 2016, 10:52 pm | |
| Once I had good tires I decided it was time to lock and pulley swap so that all that tread could go to good use That's the case on the welding table after getting it stick welded, then the pulley was a pain to get off and had to use 2 different types of pullers tl finally get it off in a few pieces. I swapped pulleys, locked the rear axle and added bearings all in one go. After that it was a whole different completely sketchy tractor. | |
| | | SatiricalHen Member
| | | | SatiricalHen Member
| | | | SatiricalHen Member
| | | | 1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5230 Posts : 1311 Location : NW USA
| Subject: Re: My main murray April 7th 2016, 11:49 pm | |
| looks good, my first tractor was a murray widebody, but it had the bigger fenders. My first tractor I built for off road was identical, right down to the missing headlight. | |
| | | SatiricalHen Member
| Subject: Re: My main murray April 9th 2016, 12:01 am | |
| - 1997 Murray wrote:
- looks good, my first tractor was a murray widebody, but it had the bigger fenders. My first tractor I built for off road was identical, right down to the missing headlight.
it's been a good little tractor, always starts up, takes a beating and keeps going. I'm not sure why they all seem to be missing lights... | |
| | | SatiricalHen Member
| Subject: Re: My main murray April 25th 2016, 11:52 pm | |
| Does anybody know how to/if I can upgrade the charging system on my Briggs and Stratton 12.5 to better handle the winch. It drains the battery really quick and then it won't start afterward always. | |
| | | SatiricalHen Member
| Subject: Re: My main murray May 8th 2016, 4:48 pm | |
| Anyone know if/how I could mount these rims on the front of this mower? I figured I got 4 for free, they have good tread. Why not? If it's just not an economical idea, anyone have a suggestion for some nice front tires for my mower that are on the cheap side. These turf savers suck turning and they have a lot of slow leaks. | |
| | | SatiricalHen Member
| Subject: Re: My main murray May 10th 2016, 7:04 pm | |
| Well I'm not really sure how it happened but the govorner is broken on the mower, it runs way too fast, and it's easy to stall out if I push the throttle lever down so it won't run ridiculously fast. Any suggestions on where to look or what to do about it... | |
| | | | | My main murray | |
| Who is online? | In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests
