Welcome to the All-Terrain Lawn Tractor Forum! 2024 is the 10th and LAST ATLTF.COM BUILD-OFF . . . for now! |
| | jd 214 mudder [2016 Build-Off Entry] | |
searsdude1977 Member
| Subject: jd 214 mudder [2016 Build-Off Entry] February 3rd 2016, 7:44 am | |
| About a year ago I was given a free john deere 214 with a unrunning k321 14hp kohler. I had it running not that long ago but the axle tube seals went bad in the peerless 2300 so I decided I was gonna tear it apart and build a mudder. My plans Rebuild the 14hp and get the cam welded and then redo the ignition system and a new carter 30 carb. I am going to rebuild the peerless axle and leave it unlocked. Then im going to paint the frame and under body and then going to repaint the underbody with origanal color schemn the im gonna paint the motor black with orange high lights. Im going with 26 inch kenda executioners and 18 inch front tires and a travelar 2500 pound winch up front. Also I might look into a smog pump supercharger or a small engine turbo also.
So to me I have a good bit of work ahead of me | |
Age : 34 Join date : 2013-11-02 Points : 6925 Posts : 2906 Location : New Jersey USA
| | | | redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 29 Join date : 2010-05-12 Points : 6138 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Re: jd 214 mudder [2016 Build-Off Entry] February 26th 2016, 9:43 pm | |
| So I haven't updated in a while but I've done a good amount of work first I pulled the motor to rebuild but I haven't torn done my motor completely because I don't know where exactly I'm going to build it yet I also painted the under body of my fender pan and my hitch plate Bed liner. Also my transaxle is torn apart and I found my axle shafts have huge groves in them from my axle tube | |
| Who is online? | In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests
