 Peerless 633 3 speed hi low. low not working
Hillbilly Homer
Hillbilly Homer
Peerless 633 3 speed hi low. low not working Empty
PostSubject: Peerless 633 3 speed hi low. low not working   Peerless 633 3 speed hi low. low not working Icon_minitimeMarch 8th 2016, 9:18 pm
i got the free B runin today.
It gos good with all 3 speeds in hi but wont go at all in low.
What should i check first ?
Off Road Domination
Off Road Domination
2016 Build-Off Finalist
PostSubject: Re: Peerless 633 3 speed hi low. low not working   Peerless 633 3 speed hi low. low not working Icon_minitimeMarch 8th 2016, 9:22 pm
Open up the transaxle and check the low range gear and see if it is out of place or blown
Rockinator
Rockinator
PostSubject: Re: Peerless 633 3 speed hi low. low not working   Peerless 633 3 speed hi low. low not working Icon_minitimeMarch 9th 2016, 6:45 am
Im not very much of an expert on these, but ive heard these things dont like to upshift while still in gear (but you can downshift if i remember correctly) i am thinking he couldve just been abusing it while shifting and low range was first to get stripped/broke.
PostSubject: Re: Peerless 633 3 speed hi low. low not working   Peerless 633 3 speed hi low. low not working Icon_minitimeMarch 9th 2016, 11:09 am
the linkage may be bent. I would check that out before you pull the trans out.
Hillbilly Homer
Hillbilly Homer
PostSubject: Re: Peerless 633 3 speed hi low. low not working   Peerless 633 3 speed hi low. low not working Icon_minitimeMarch 9th 2016, 11:23 am
Tank you ill check that first lol.
Hillbilly Homer
Hillbilly Homer
PostSubject: Re: Peerless 633 3 speed hi low. low not working   Peerless 633 3 speed hi low. low not working Icon_minitimeMarch 10th 2016, 11:32 am
Ok i think i figured it out.
If i put the 1-3 shift lever in N it will shift from Hi and Low.
PostSubject: Re: Peerless 633 3 speed hi low. low not working   Peerless 633 3 speed hi low. low not working Icon_minitimeMarch 10th 2016, 1:53 pm
yeah, it may be that you need to shift it while moving, that's the way mine is, cause the grears are straight cut and not synchronized.
» tranny ? 5 speed or 6 speed
» Stiff peerless 5 speed 801-038B
» Low Speed Tractor w/ Peerless 820 + Automatic Transmission Fluid = ?
» 820-037 Peerless Manual shift 5-speed Dimensions and Mounting holes location.
