I think I found the new front tires and I got my new seat and a new 2500 pound winch. I make my stack and I am going to try to get the engine in this week.
Off Road Domination Member
2016 Build-Off Finalist
Age : 21 Join date : 2016-02-17 Points : 3044 Posts : 74
so I got my engine on hade to make a new plate for the rear bolts and a clutch. Also welded the stack on and the throttle post and fixed the hood next will be the throttle and the bumper thanks
Age : 34 Join date : 2013-11-02 Points : 6925 Posts : 2906 Location : New Jersey USA
been doing some ridding with dirty burban and there is a spring romp coming up soon and I want it looking good so I am painting early I still need to finish the winch and the bumper.[img][/img][img][/img][img][/img][img][/img][img][/img][img][/img]
tscustoms Member
Age : 23 Join date : 2015-02-25 Points : 3383 Posts : 54
some things that I have been doing the mower is the stack got cut off welded my bumper on. went for a romp with my friends and found some things that needed to be fix the back plat was getting caught on every thing so today I cut that and put my winch on loving the look of it. [img][/img][img][/img][img][/img][img][/img][img][/img][img][/img][img][/img][img][/img]
Looks great but dont you think you should have put the winch in the front because now if you get stuck in a mud hole its just going to pull you back out and you have to keep hitting it
tscustoms Member
