Not sure if this will work. I clicked 'embed' on YouTube and got this.... <iframe width="560" height="315" src="https://www.youtube.com/embed/5Hfz1YsQByE" frameborder="0" allowfullscreen></iframe> which looks like code going nowhere. Anyone know how to get the little YouTube link pic please help Meanwhile here's another link to it. There's a limit to what can be done with just an iPhone instead of camera and editing computer etc but see what you think. All comments welcome https://youtu.be/5Hfz1YsQByE
Age : 34 Join date : 2013-11-02 Points : 6926 Posts : 2906 Location : New Jersey USA
If you want to put a video on from youtube, first get to the video and then copy the URL, or web address. Then when you are ready to post on the forum, click the youtube button at the top of the page as marked in my fancy diagram below. A box will open up. Paste the web address from your video there and then click insert. It will automaticly put the video into your post without any extra letters or addresses to clutter things up. You can type above or below it after that if you want to.
Here's how it will show up. Don't forget that you can experiment by hitting preview before you post and make sure everything is how you want it before you hit send.
Looks like it's in good shape. Similar to a sears custom by the looks of it. Grill is a little different, but I think even the hood on the sears custom has those louvers in the side.
Tractorhead Member
2016 Build-Off Finalist
Join date : 2016-07-10 Points : 2909 Posts : 75 Location : England
Thanks for that Mr Modified I'll do that from now on. Yes the red and white RT13 in the vid is pretty much a Sears Suburban by another name for export. Briggs single cylinder engine. Dash and front nose cone are cast ali and a bit different shape to Sears branded versions. The smaller Roper I'm doing brown for the build-off also has Ali dash and grille and is more similar to a Sears Custom. They all came out of the same Roper factory so there's a family resemblance. I am looking forward to using it 'Off Lawn' & today I get the brake bands back with fresh linings. Keen for that!
