 Li'l Red Murray Project
Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 15  Next
BriggsBandit99
PostSubject: Re: Li'l Red Murray Project   Tue Jul 18, 2017 4:58 am
So what tires, engine, trans, etc. are you planning to use Rich?
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Tue Jul 18, 2017 10:34 am
@RichieRichOverdrive wrote:
It seems those gaskets are hit or miss. Plus it doesn't help having like 42 cubic inches of area in the crankcase being added/removed 3600 times per minute, and all that pressure difference being pulled through just a few holes. That's actually part of why pulse pumps work so well on these engines lol. Also, did you loctite the bolt for the oil slinger? I figure that would prevent any future problems. I like your idea to stiffen up the frame, but aren't you going to have to cut a big hole in the middle of it for steering?  I see that box steel there, do I sense a bumper coming soon?
Yeah I was reading somewhere that these engines do have the tendency to "suck the gasket in".
The plate is going on the bottom. No need to put a hole in it for that. And yes, I'm hoping to build a bumper down the way. If you are talking about the box tube on the frame. That is how much wider the frame was on the old tractor to fit the hood! But I had planned coming off it and the bottom connection points with a new bumper.
(Kal-El) 1982 Murray GT. . . . . . . . . . . . . . . . . . 2-39002 . . . [2018 Entry]
Progress:  ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
http://mightyraze.com Online
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 12:08 am
I was looking tonight and I think I can put the old bumper back on.
What to do when it is 100 degrees out and the garage is super hot?
You install the window unit you have stored in the shed in the already screwed up storm door.
Got the bottom plate installed.
Did like doc with Fuzazi and cut out the bottom plate to accept the 6 inch pulley.  While grinding, I caught some reminant oil that hadn't got cleaned on fire.  Smoked up the garage.  Had to open the big door to let the smoke out and lost my cooling.
I did some strengthening up of the steering because the bolts have about pulled through on the plate. Reassembly has started.
Forum Rep : 117
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 12:18 am
Looks good mighty! Hopefully that stiffens it up quite a bit.
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 1:04 am
Man it is so hot and dry, this crack is almost 3 inches wide.  I wear a size 13 wide.
Red is starting to look like a tractor again!
Forum Rep : 53
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 1:33 am
Looking good Mighty! You're making me wanna put Orion together...I mean it doesn't need that much, I just dont like it so much...
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 6:40 pm
Progress is being made, now I am at a roadblock.  Before I can run it, I need to finally figure out the gas tank issue.  I either need to patch the one I have again with something better, buy a new one (yikes) or come up with another idea like a portable/removable gas can.  I'll take a few days to figure that out.  I may end up patching what I have with JBweld or something since I know exactly where the leak is at this time.
Forum Rep : 53
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 6:55 pm
Maybe something like Doc did with Mule 2? That'd be cool to see done again!
Forum Rep : 117
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 7:43 pm
Just tow a big fuel tank on a trailer behind you at all times and pump it right into the carb! Anyone?? Hahaha
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 9:13 pm
HAHA... I was actually considering the megatank. I even have access to a jerry can but it's in bad shape now. Sad New ones are about the same as a new Murray tank.
Got my old bumper reinstalled.
I have room now for a wench. One of those may be in order in the future.
I have a few things that I can continue with until I get the tank fixed.
Forum Rep : 117
PostSubject: Re: Li'l Red Murray Project   Sun Jul 23, 2017 9:25 pm
A wench?? Why would you want one of those on the front of your tractor, that wont help at all!! Haha, just kidding. A winch would be cool though, would be handy if ya really got 'er burried somewhere.
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Mon Jul 24, 2017 11:32 pm
I jbwelded the tank where it leaks for now until I can fab something new up. I got everything buttoned back together so I can start it up and check for leaks.
Took it for a speed run after a tune up and redoing pulleys.
Yup, 27mph. Pretty stable at that speed too.
Still a few things I need to get done. I am going to go back a hair smaller with the fronts, back to 16x16.5-8's. I also would like to do fender flares. I am pretty sold with the Doc version on Fugazi.
Forum Rep : 53
PostSubject: Re: Li'l Red Murray Project   Mon Jul 24, 2017 11:36 pm
27 eh? Nice! Me and you'll have to drag race some day! Lol, that'd be interesting!
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Mon Jul 24, 2017 11:43 pm
Vroom Vroom!
Forum Rep : 9
PostSubject: Re: Li'l Red Murray Project   Tue Jul 25, 2017 9:02 am
Love the looks of that one
I can do anything I set my mind to... the impossible just takes me a little longer
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Tue Jul 25, 2017 9:41 am
Thank Lawren, I think the older grill gives it more character.
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Thu Jul 27, 2017 3:12 pm
So a couple months back I had to go back to the old rear tires I had on the front.  They are holding until I can finally get some new fronts.  I was thinking of re-painting my rims when I did the tire swap?
Right now it looks like:
This is what I was thinking?
Also be a good time to trim excess axle nubs in the back.
Forum Rep : 53
PostSubject: Re: Li'l Red Murray Project   Thu Jul 27, 2017 3:21 pm
I like it! I gotta paint the rims on MUTT someday. The white on the front turned kinda...cream...lol
Man it's like
ALL YOUR PAINT ARE BELONG TO US
with you  lol!
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Thu Jul 27, 2017 3:47 pm
Man it's like
with you  lol!
HAHA, I wouldn't call it cream, call it "mud stained"
All your paint? LOL, making fun of the signature. Oh, the joys of photoshop.
Forum Rep : 53
PostSubject: Re: Li'l Red Murray Project   Thu Jul 27, 2017 4:06 pm
ALL YOUR PHOTOSHOP ARE BELONG TO US
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Thu Jul 27, 2017 9:09 pm
Decided to save some $$$ and swap tires with Thor, my 77 Hydro Sears Suburban who's engine kicked the bucket back in March.  Current avatar image.
Took it out back in the empty lot for a stroll with the daughter on her purple people eater.
Plates did well helping with frame twist.  A lot.  Also, steering with the smaller tires was much easier and turned sharper.  But I also have tread.  Plus these are on ball bearing gokart hubs.
Images when I repaint the hub.
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Thu Jul 27, 2017 10:45 pm
Little preview!
Forum Rep : 117
PostSubject: Re: Li'l Red Murray Project   Fri Jul 28, 2017 12:40 am
HA! I got to see the preview of the preview! Haha, looking good mighty!
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Fri Jul 28, 2017 8:49 am
The rear's are done. I have to re-run my positive battery cable before I put them back on. The new one I created that I thought was a lower gauge, turned out to be higher. These oppys need all the power they can get to start. Fun stuff there.
Forum Rep : 179
PostSubject: Re: Li'l Red Murray Project   Sat Jul 29, 2017 10:34 am
Well I got the fronts painted, the hubs dialed in where they do not wobble and greased up.  Greased the spindles while I was at it.  I also re-boogered the weld on the arch pice on the bumper.  The right side was breaking loose.
And my little helper!
Forum Rep : 117
PostSubject: Re: Li'l Red Murray Project   Sat Jul 29, 2017 10:46 am
Looks great mighty, love the doggie as well haha. They do look kind rat rod-ish with the tape on dont they? Should look pretty cool once all put back together!
Page 9 of 15Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 15  Next
» My Murray project AKA "The Night Train" (PICS!)
» Li'l Red Murray Project
» 84 murray mudding project
» Hey got a project ive been working on its a late 90's early 2000 mtd
» Project: M&M's "military Mud Mowing Murray"
