The 2018 Build Off is Almost Over!! Click Here to view 2017 results!
 Li'l Red Murray Project
Go to page : Previous  1 ... 9 ... 13, 14, 15
PostSubject: Re: Li'l Red Murray Project   Tue Apr 10, 2018 7:53 pm
Buck Mault wrote:
3 things to make a engine run spark, compression and fuel. take one out no BOOM
But what if it's a diesel? lol!
Forum Rep : 5
PostSubject: Re: Li'l Red Murray Project   Tue Apr 10, 2018 7:59 pm
@RichieRichOverdrive just fuel and heat lol
Oh there is diesels out there now that are low compression and have a spark plug so you can run multi fuels
Forum Rep : 121
PostSubject: Re: Li'l Red Murray Project   Tue Apr 10, 2018 8:00 pm
Air, a ton of compression, and fuel. Hahaha.
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Tue Oct 02, 2018 12:59 pm
Update to L'il Red.
So...
So over the weekend, I got a call from my father-in-law.  "You want that other Murray?  If not I will haul it off."  Uh... Yeah I will take it.  LOL.
From what I gather, It is a 1985 Murray GT.  Everything on it is the same as KAL, except it does not have the hill hold (hand brake).  It's hood is currently on Li'l Red.
The Hood,
The Tractor (as it sits today)
So... if I run a new build on this tractor, I will more than likely pull the hood back off Li'l Red and put it's round hood back on.
This one.
So, I guess I will have some figuring out to do.
hmm hmm hmm
Murray CCT (KAL prebuild)
Sasquatch II [2017 Finalist]
ATLTF Facebook Page
How To Upload Pictures
ATLTF Staff:
Forum Rep : 76
PostSubject: Re: Li'l Red Murray Project   Tue Oct 02, 2018 4:27 pm
That's a tough call to make, but other hoods could be found for Lil Red.
Don't you have enough tractors and projects already?  Everyone could always use more parts though.
Forum Rep : 55
PostSubject: Re: Li'l Red Murray Project   Tue Oct 02, 2018 8:07 pm
I think that hood should stay on red, it's something that really makes it different from all the other widebodys out there. I'm certain you can figure something out for the other GT, maybe something like mr.moo did on the Baja Sears? You can convert that GT to the correct engine output orientation and build something similar to it.
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Thu Oct 04, 2018 2:45 pm
So after talking with @Doug today. He made me realize "indirectly" that I may or will need parts over time for KAL. I'm thinking... DUH... I will have that 85 murray! What better parts machine than another murray just like it. Transaxle, everything is the same other than engine and square headlights. So the hood is safe in Li'l Red. I may want to upgrade the headlights to LED in the future.
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 76
PostSubject: Re: Li'l Red Murray Project   Thu Oct 04, 2018 6:50 pm
That's a great call to have a spare tractor laying around whose parts you can use on Kal.  @TheBeal would be really proud.
Forum Rep : 55
PostSubject: Re: Li'l Red Murray Project   Thu Oct 04, 2018 11:41 pm
Beal doesn't even have a main tractor to throw those spare parts at lol!
Parts tractor sounds like an alright deal, like i did with the stupid murray gt i got. Are we at least gonna see it drive before you take it apart?
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Fri Oct 05, 2018 12:19 am
Probably not, engine needs a good going through.  I think the coil is missing.  Rag joint I think is busted.  Those massive rear weights will go on my Suburban. Score there.  I may end up giving that motor to my dad.  He's blown his 3rd intek V-twin in 5 years.  May talk him into an opposed for a while.
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Tue Oct 16, 2018 10:02 pm
Time to get Li'l Red some lovin. Current state again is a no start and some of my switches are not working properly.
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Sat Oct 20, 2018 9:41 pm
Looks like my light switch is out and my winch switch has a loose wire.  Smile
I need a couple relays to properly hook up the winch and the Horn which I think is going bad.  Mad
I think this phase of Li'Red is coming to an end.  Other than Red's fast speed, Kal is much more advanced feeling.  Red sounds awesome as well.  I think it is time to do some upgrades.
- Bumper needs reworked
- Newer winch, I really like the Harbor Freight one on Kal
- Rework the exhaust, remove the black pipe
- Fix the lighting
- new clutch spring, this one seems weak now
- fix choke, it hangs
- New rear tires when affordable.
- Maybe front suspension?  I LOVE the monolink on KAL.  SO much more stable.
- New paint?  I may want to incorporate some blue in the build.
Hmm... things to contemplate.
ATLTF Facebook Page
ATLTF Staff:
darkside0914
Forum Rep : 5
PostSubject: Re: Li'l Red Murray Project   Sat Oct 20, 2018 10:26 pm
that widebody looks really good with the older gt hood on it, wonder if my brother would get mad if I swiped the hood off the old murray 11/38 he's got in storage for my murray lt
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Sat Oct 20, 2018 11:57 pm
- Fix the lighting
Light switch worked out.. - FIXED
Winch switch loose wire.. - FIXED
Still need a couple relays.
-Lighting fixed
-clutch spring is OK
-Choke fixed.  The Z on the end of the cable was hanging in the carb.
-scratch on the paint.  After working on it this afternoon, I like the red.  Good contrast to KAL.
I NEED A FUEL TANK.  This one is still shot.  Not worth trying to continue to fix.  Mad
I really like the Early to mid 80's Murray hood.  I do like the original round hood to a point as well.. Just not as good.
ATLTF Facebook Page
ATLTF Staff:
darkside0914
Forum Rep : 5
PostSubject: Re: Li'l Red Murray Project   Sun Oct 21, 2018 1:25 am
- Fix the lighting
-Lighting fixed
the tank on my 99 widebody leaked, I cut the top and bottom out of it and mounted a craftsman tank inside it, basically used it as a mounting bracket, I had to cut the dash out a little for the fuel filler neck but it works great.
Forum Rep : 76
PostSubject: Re: Li'l Red Murray Project   Sun Oct 21, 2018 8:21 am
I like how those tires look on Lil' Red.  Not too many people have them so it's kinda unique.  They look like good tires for a trail machine, but what kind of tire would you rather have?
I think it's cool that you're doing more work on this rig and you want to add suspension to it ( @AllisKidD21 ) .  Are you thinking about going with something different than a monolink?
I would try to find a generic tank online and make it fit like Paulie Detmurds did on his Sears Resurrected.  I have the tank from a 196cc clone with a broken mount but clean on the inside that I'd mail to you if you could make it work.
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Sun Oct 21, 2018 10:11 am
Yeah they are good for trail but truly suck in mud.  The main reason I was thinking of maybe some newer ones is because the rubber has hardened and they are beginning to wear down fast.  Tires at this point are not a high priority as there is still 50% or so tread on the back.  As for what I would move to?  Not sure at this time.
Suspension.... probably another monolink, but I am still toying with an independant idea.  Rear will stay stiff.
I have some ideas floating.  Let me work those out, I also have a couple other tanks on hand myself. I will keep you in mind though.  Thanks @Crazy_Carl.  I would like to stick with 2.5 gallons or better like I have if I can.
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Yesterday at 10:48 am
One of these guys may fit nicely in there?  I can find one for fairly cheap considering the replacement for a Murray tank.  This also has a gauge on top.  Posting to remember.
But I will probably mod a bracket for a 2 gallon I have on hand.  Just not thrilled where the fill spout is located on it. Any of my tanks on hand actually.
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Today at 2:54 am
One more thought in trying to fix the existing tank... thinking about fiberglassing the whole thing up.  I think that would work.
ATLTF Facebook Page
ATLTF Staff:
darkside0914
Forum Rep : 5
PostSubject: Re: Li'l Red Murray Project   Today at 3:17 am
might want to check with a local fiberglass shop or body shop that does fiberglass, or at the very least make a test panel before committing to it, I've been told that the alcohol in pump gas will make the resin fail, how long before it happens i don't know, i'm not sure personally if it's even true just relaying info I was given.
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Today at 7:32 am
Good information.  I do think ethanol would break it down.  Something to consider should I go that route. We do have 100% here at some stations which I do purchase. Sometimes I think it gets swapped.
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 193
PostSubject: Re: Li'l Red Murray Project   Today at 9:09 am
Doing some research..
Avoid: Polyester Resin.
Good: marine based Epoxy Resin people have had luck with and easy to find at the auto store. OK with 100% gas, but ethanol can break some epoxy down over time. (This is my current problem, I used epoxy to seal the tank and used the wrong gas).
BEST: looks to be able to even handle E85 is Vinyl Ester Resin.  Not sure where to find outside an online store.
ATLTF Facebook Page
ATLTF Staff:
darkside0914
Forum Rep : 5
PostSubject: Re: Li'l Red Murray Project   Today at 7:24 pm
you could try several coats of plastidip, once dry it should be gas proof, put a couple extra coats in the areas where it's leaking, I can't find vinyl ester resin anywhere but online either
Page 15 of 15Go to page : Previous  1 ... 9 ... 13, 14, 15
» My Murray project AKA "The Night Train" (PICS!)
» Li'l Red Murray Project
» 84 murray mudding project
» Hey got a project ive been working on its a late 90's early 2000 mtd
» Project: M&M's "military Mud Mowing Murray"
