Swing by the Chatroom anytime! Next Chat Event - 10/7/2017 @ 8:00pm EST .
ATTENTION!! - The 2017 ATLTF Build-Off ends just over a month! Click Here to view qualification rules, and Click Here to view entry instructions!
Be sure your build threads are updated and your build meets "finished" qualification rules!!
 MTD off-road build (Mobile Terrain Dominator)
Go to page : Previous  1 ... 13 ... 23, 24, 25 ... 29  Next
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Sun Aug 27, 2017 9:48 pm
Not sure haha, gonna have to check sometime.
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Aug 29, 2017 9:39 pm
So I rigged up a simple steering damper today for fun.
[url=https://servimg.com/view/19509163/675
[/url]
Just used a screen door cylinder like I planned, seems to work pretty good. It does feels like it helps stop the wee bit of bumpsteer.
Also did a little playing around.
I'll probably keep it this way as it seems to be mounted pretty solid, just gotta paint it a cool colour haha. Let me know what ya think
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Aug 29, 2017 10:02 pm
Interesting. I see it's application. Good Job.
Projects:
Sasquatch II
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Aug 29, 2017 10:12 pm
Cool iv'e never seen that before.
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Aug 29, 2017 10:21 pm
Thanks fellas! Figured I'd throw it on there and see what happened, as I do with many things haha
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Aug 29, 2017 10:24 pm
What exactly does it do? make the steering easier and more smooth?
Forum Rep : 31
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Aug 29, 2017 10:30 pm
It's supposed to slow down steering action and fight it kinda. So if you hit a rock it only breaks your finger half of the time (jk lol)
Looks good Allis! Does it work both ways?
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Aug 29, 2017 10:48 pm
Yeah like Rich said it basically keeps the bump steer to a minimum. There isn't much anyways, but I still figured I'd add it just cuz. It seems to work both ways pretty good, I was wondering about it making one way really stiff to turn but it didnt really so I'm happy with it! Haha
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Sep 04, 2017 8:09 pm
Well I was considering swapping a heavier front axle under the MTD, something made of solid steel with greaseable spindles knuckles. Buuuuuutt I thought about having to swap over all my suspension mounts and what not, and I thought that sounded like too much work hahaha.
So I just decided to upgrade my stamped one a bit.
First I wanted to sleeve the spindle bushings and add a couple of grease fittings.
I also wanted to patch up the old hole I cut when I added the angle iron in the beginning of the build.
Finished it off with a piece of rebar hahaha
And I drilled and tapped a couple holes for grease fittings.
Turned out pretty good! Now my bushings wont run dry and start squeaking like usual haha. Tomorrow I'm hopefully gonna cut and re-weld my steering arms to get my ackerman angles back. Let me know what ya think!
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Sep 04, 2017 8:22 pm
Looks nice and i bet that axle is extremely solid now. I think I might do the same grease thing because I agree with you that the original setup is pretty pathetic.
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Sep 04, 2017 8:28 pm
Thanks! I sure hope she's solid now haha. Yeah some of these stamped axles aren't the best setup for getting dirty and stuff.
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Sep 04, 2017 10:53 pm
Nice boogers!  I bet it is pretty solid! Don't stop the boogers. One day if you keep it up they may become dimes!
Projects:
Sasquatch II
Mow Money Mods
Forum Rep : 4
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 7:30 am
theres some meat in there now for sure, I like the thinking behind it, it's like hidden gusseting.
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 7:21 pm
Well they only look like that because I was welding it straight up and down, should've flipped it up in the vise so they turned out better. Haha, oh well.
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 7:22 pm
Thanks haha, there should definitely be an improvement in strength compared to stock.
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 7:45 pm
So I finished my steering work today, just modified steering arms to get my ackerman angles back. I wanted to go for a drive to test it out so I pull on to the dirt track in second gear, I go to shift into third and when I let the clutch out she stops in 'er tracks. I try every gear and nothing, so I finally noticed my right axle is sticking way out amd I assume the snap ring has broken off some how and the axle pulled out of the spider bevel gear. Well I push 'er back to the barn and drop the trans out.
When I pulled the one axle sleeve off the shaft and bearing arent worn out a bit, which is surprising but good.
Just like I thought the snap ring popped off the end of the axle shaft
Then I notice my spider gear pin...
Yeah... not sure how that happen but I'm not happy about it.
But, this in a way might lead to a nice score. I'm not gonna say until the I find out if the deal is gonna go though or not, but I might have another project or two. We'll see!!
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 8:41 pm
That sux, I bet the snap ring got in there and pried gears apart snapping that shaft. Hope your score happens. Smile
Projects:
Sasquatch II
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 9:06 pm
Cheers mighty! I sure hope it does as well hahaha. I dont know about the cause of the pin snapping, but I can tell by looking at the ends that it didnt happen very recently. Oh well, If this deal goes through I wont have to worry about it!
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 9:18 pm
PS, good to see the front back together!
Projects:
Sasquatch II
sadeoo7
Forum Rep : 5
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 9:29 pm
time to doc lock it ! the pin is already in 2 pieces so half of the work is done lol
http://gdftech.com
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Tue Sep 05, 2017 9:33 pm
Yeah, now I guess it's time to work on the back end haha.
I thought you'd say that hahaha. I dont think I'll go that route but I'll keep the broken pin around just in case.
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Wed Sep 06, 2017 6:12 pm
Yay, score!! Haha.
The LT11 has a Peerless 801 which has the differential pin I need, along with lots of other useful parts. And the GT 6000 is gonna become a workhorse/off-roader.
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Wed Sep 06, 2017 6:34 pm
SWEET! That GT6000 is pretty close in model as the Squatch! I think it is a year or two newer. Looks to still have a horizontal, but in a Kohler!
Awesome!
Projects:
Sasquatch II
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Wed Sep 06, 2017 6:41 pm
Yeah she's got the horizontal shaft 18hp Magnum opposed. Got 'em both for a real good price too, $FREE. Hahaha
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Wed Sep 06, 2017 6:47 pm
Can't beat FREE! That Kohler run?
Projects:
Sasquatch II
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Wed Sep 06, 2017 7:26 pm
Nice mowers I wish I got free mowers...
Page 24 of 29Go to page : Previous  1 ... 13 ... 23, 24, 25 ... 29  Next
» Pinkie's off road build
» Murray Mud Mower
» Off Road mower Equipment Utility Trailer
» How do you build an off road trailer?
