Swing by the Chatroom anytime! Next Chat Event - 10/7/2017 @ 8:00pm EST .
ATTENTION!! - The 2017 ATLTF Build-Off ends just over a month! Click Here to view qualification rules, and Click Here to view entry instructions!
Be sure your build threads are updated and your build meets "finished" qualification rules!!
 MTD off-road build (Mobile Terrain Dominator)
Go to page : Previous  1 ... 16 ... 27, 28, 29
mightyraze
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Sun Nov 12, 2017 9:21 pm
Awesome! I was doing some research and the ATV/UTV trail over here about 15 miles from the house was converted to Equestrian only 5 years ago. UGH!
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Sun Nov 12, 2017 9:27 pm
Yeah it was fun for sure! I wanna go back during the day sometime though and bring my brother on the ol' Ford along with us. That'd be quite a show hahaha.
Online
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Sun Nov 12, 2017 10:08 pm
The video did look fun! MTD running a little rough? It is fun to go fast!
Projects:
Sasquatch II
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Sun Nov 12, 2017 11:56 pm
No she's still running great, backfires if you throttle down real fast with the short pipe obviously but it's not too bad. I could probably fix it by playing with the mixture but I'll probably leave it haha.
Online
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 13, 2017 12:05 am
I totally blanked out the new pipe. That's what I am hearing is just the poppy in the engine through the mic. I wish I was playing in mud!
Projects:
Sasquatch II
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 13, 2017 11:20 am
Oh hahaha, yeah that's probably what it was. Yesterday before the romp I did a bit of tinkering with my steering linkages and got it to turn a bit sharper than it did without being so stiff, which is nice.
Also I tried a different clutch spring and it seemed to help the slipping in higher gears but it still slips when I take off in 2nd or reverse. Might have to mess with it a little more to see what I can figure out.
Online
Forum Rep : 28
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 13, 2017 12:40 pm
You're running a stock engine pulley right? That's gonna slip no matter what you do. It's just so small
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 13, 2017 12:54 pm
No, it's a slightly larger one welded to the original one. The clutch can be released pretty effortlessly from underneath the tractor so I think it's just a spring tension issue.
Online
Forum Rep : 31
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Sat Nov 18, 2017 4:47 pm
You should switch your pulleys to like 9" to 1". No belt slip, and good crawling speed. Truuuuuuuuust me.
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Sat Nov 18, 2017 5:58 pm
I would imagine you're right, might have to try that.
NOT!!
Hahaha, actually the next thing I'm gonna do is make a bearing to support my steering shaft just under the dash. I'm just gonna use a pillow block most likely, shoud be a major upgrade from the crappy plastic bushing thing on the dash. Hopefully I'll start fabbing that up tomorrow!
Online
Forum Rep : 31
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 20, 2017 12:21 am
Any update on adding more skookumness to that steering shaft?
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 20, 2017 9:52 am
Actually I took my fuel tank out and had a look, only to find out there's virtually no room to mount a pillow block in there. Gonna have to try and think about doing it a different way maybe haha. But I did use some "strategically placed" pieces of rebar to strenghten up my steering box mounting. I noticed it was torquing side to side when under a lot of stress, but there's virtually no movement at all now! Which is good. So I can say I got something done hahaha.
Online
Forum Rep : 31
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 20, 2017 7:35 pm
Ah, Allis and his angle iron and rebar. Can make even the floppiest MTD as stiff as a the dude that overdosed on viagra hahahaha
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 20, 2017 7:41 pm
That's right! If there's one thing I wanna be remembered for, it's that. Hahaha
Online
Forum Rep : 28
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 20, 2017 9:36 pm
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA lol! lol! lol!
mightyraze
Forum Rep : 85
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 20, 2017 10:39 pm
Projects:
Sasquatch II
Forum Rep : 31
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 20, 2017 10:52 pm
hmmmm...gifs upload the same as images?
this is gonna be good
Forum Rep : 73
PostSubject: Re: MTD off-road build (Mobile Terrain Dominator)   Mon Nov 20, 2017 10:54 pm
Oh great, Rich is loose with my thread again.... Hahaha
Online
Page 29 of 29Go to page : Previous  1 ... 16 ... 27, 28, 29
» Pinkie's off road build
» Murray Mud Mower
» Off Road mower Equipment Utility Trailer
» How do you build an off road trailer?
