| | My monster Murray build | |
AlaskanJoe907 New Member
Age : 24 Join date : 2016-09-06 Points : 2775 Posts : 11 Location : Wasilla, Alaska
| Subject: My monster Murray build January 7th 2017, 2:07 am | |
| Well here's what I got so far on building my Monster Murray Build, I plan on doing a radius arm suspension with a panhard bar here it is stock here are the links here are the links mounted to the original axle here is the axle sitting about where it will be here are the shocks, they came off of an old Suzuki lt125 here are the shocks bolted in here is the panhard bolted in, its going to be a little over 12'' tall [/url] here it is, I still have to do the rear. I plan on locking the MST-205, putting two pillow blocks in for extra support for when I extend the input shaft. making hubs out of the old rims, to mount to the 22 x11 x10 tires here it is bolted in | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8349 Posts : 5190 Location : Ontario Canada
| Subject: Re: My monster Murray build January 7th 2017, 9:09 am | |
| Looks pretty cool man! How good does the suspension work? Is it stiff? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My monster Murray build January 7th 2017, 4:05 pm | |
| Its a little stiff, but I'm not worried about stiffness, as long as it has some, | |
| Subject: Re: My monster Murray build January 7th 2017, 5:10 pm | |
| Nice! I suppose once it's on all fours and driving, the suspension will probably be less stiff. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5515 Posts : 1993 Location : Northern Ireland
| Subject: Re: My monster Murray build January 8th 2017, 12:06 pm | |
| Nice build! I like the panhard rod arrangement. How much flex are you looking for? | |
Join date : 2015-02-02 Points : 4858 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: My monster Murray build January 8th 2017, 7:16 pm | |
| Nice front end setup. Do the shocks and panhard bar keep the front axle from twisting forward and backward? | |
| Subject: Re: My monster Murray build January 8th 2017, 10:20 pm | |
| The panhard bar is more for making the axle still, so it doesn't move side to side. its not really for flex, just something different then using the stock mower axle setup. This is the second one I'm building, I wasn't on ATLTF.com at the time of me building my first lifted mower. | |
