 Craftsman GT3000 "MUTT"
Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 20 ... 31  Next
PostSubject: Re: Craftsman GT3000 "MUTT"   Wed Jun 28, 2017 4:00 am
I'm just gonna leave it stock lol, at least till I get this carb issue solved
Alright I'm sorry my dudes but this is prolly gon b very hard to follow, my mind is in shambles between my dreaming/daydreaming/brinestorming/lookingthrured'smtdthread/listeningtometallicalol/its3am
Ok, you folks remember when I tried out those 21x7-10s on the front? How they really wouldn't have worked well without some new bushings, and spacers to clear the knuckles? Not to mention that they won't help my lean problem. I'm not sure if I mentioned that I had to space out the new 8" rims I have on the front with some washers, but I had to because the tire would rub the knuckle because these rims don't have the offset the hubs rims did. They are so far out on the bolts I used for spindles that the bushings are actually riding on the threads on the bolts, which is wallowing out the bushing slowly, which is adding camber(there is already camber from the knuckles wearing into the axle, which i kinda anticipated, it only really adds a degree or two yet it still looks horrible to me) so I have to space the rims out even further. The spacing them out wouldn't be such a problem if I could find some ball bearings for them, but I'm not sure where I can find those. Plus I'm uncertain of the OD of the bushings themselves. I'm hoping 1-3/8", if so then supposedly there's ones from wheelbarrow rims that match...I had a set of tsc wheelbarrow wheels that i guess had those bearings on the front of one of my snappers that blew out. Plus some similar ones dad threw on an elevator just to get it home lasted only about 1/4mi. Yes, they were overloaded, but you'd think they'd last longer than that!! Although now that I think of it didn't Doc put high speed heavy duty wheelbearings in the fronts on the Diesel Weasel? Maybe those would work. I'll have to ask him about those, lol.
AAAAAAnywho some of you (probably all of you) were anticipating this, I'm thinking about suspension. Monolink similar to Red's(he's a bad influence on me lol). But I don't want to use coilovers if i don't have to. Just doesn't look right to me. Not very sleek. Plus I dont wanna shell out lotsa clams (see what i did there?) to get ones with a decent amount of travel. My dad used to be a dirt bike guy. There's a part of my grandpa's barn(in new york, unfortunately) with a bunch of old dirt bike parts. Actually i shouldn't say dirt bike because they are back from the Sport/Trail/Offroad days. Anyways there was(is) a pair of motorcycle front shocks/forks there. I never thought much of them, but now that I remember them I think it'd be cool to incorporate some into a tractor suspension setup. I talked to dad and he said some are rebuildable with kits available for heavier/lighter applications(bikes). They have plenty of travel, like maybe 10" or 12". Plus they don't automatically spring back out so fast. I've only done a quick search on some on ebay, but I think they'd suit the application.
Thoughts?
Forum Rep : 94
PostSubject: Re: Craftsman GT3000 "MUTT"   Wed Jun 28, 2017 8:02 am
This should be cool! I dont see why those wont work, the only problems I can see are the shocks being a bit too long, and the fact that there are no mounting loops at the bottom of the shocks. But I've already thought of a couple ways to fix that and I'm you will as well Rich haha. Now hurry up and get this started already!
Success doesn't happen to all of us, if it did they'd change it believe me - Red Green
                             Tourque it 'til it breaks, then back it off a quarter turn!
        Stuff I've Welded Together
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        - Lawn Tractor Utility Trailer
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Thu Jun 29, 2017 1:22 am
As soon as somebody buys me a set of shocks I'll get on it lol. I pretty much have the stuff to build suspension aside from the big ball joint I need for the main swivel. I don't think they're too long. Will probably get the bottom mounted to the axle and the top on some hoops. Can shorten them if I gotta. Also, the top of these I'm pretty sure are dried and tapped to like 3/8-sumtin. I could drill them over and tap to the 1/2" UNF thread that my heim joints have. I think they'll hold up to the weight of an entire opposed twin crashing down on them lol. Plus I'll have a use for the ones that got stuff when welding.
I forgot to mention that I'm probably gonna be bracing up the front end of the frame while I'm doing this. The front axle might get moved up an inch or two also. Just to give me room for stuff. I'll also Have to modify my hood to open like Doc's Fugazi hood to allow shock towers. I've wanted to do that anyways, lol. I'll brace up the grille good too.
Man, this is gonna suck! Finally some action!
Forum Rep : 94
PostSubject: Re: Craftsman GT3000 "MUTT"   Thu Jun 29, 2017 7:52 am
Yeah well dont hold your breath! Hahaha, you're putting the shocks under the hood right? Like in front of the engine?
Forum Rep : 129
PostSubject: Re: Craftsman GT3000 "MUTT"   Thu Jun 29, 2017 8:22 am
Interesting idea. Definately have travel room LOL. Like Alliskid said, may be a bit tall for the application. Unless..... I wonder if you could get the same outcome with some from a 50cc mini pocket dirtbike shocks?
Progress:   ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Thu Jun 29, 2017 3:22 pm
I have absolutely no room for shocks under the hood without some serious cutting. the fuel pump is nosed right up less than 1/2" from the grille screen. they're definitely gonna be in front of the hood. Why I have to modify the hood to open differently
I've never been up close and personal with one of the little bikes. Plus I think they only travel 6". Not counting preload from the big twin, lol. They are little bikes for little people, lol
Forum Rep : 94
PostSubject: Re: Craftsman GT3000 "MUTT"   Thu Jun 29, 2017 7:16 pm
Oh in front of the hood, ok I remember now. Sounds interesting.
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Fri Jun 30, 2017 3:26 am
Well i got my carb kit and cleaned and rebuilt the carb. Actually had some brake parts cleaner to use this time haha. I noticed when disassembling the fuel pump that one of the tiny springs had slipped around the little flap on the diaphragm, rendering the fuel pump somewhat inoperable because of not being able to stop the fuel from flowing back into the tank. Maybe i assembled it like that and it did that, I dunno. Anyways, she runs fine now. Excellent throttle response, plenty of power back, and smooth idle(for an oppy). I'm still having a starting issue. It's just plain hard to get her going. Choking doesn't do much. only thing that gets her there is kinda stepping on the gas pedal a bit then letting off when cranking. Then she'll pop just a bit and you gotta carefully get back on the throttle and she's running fine again. I think this may be coil related though. When I pull the right spark plug wire, the left side loses spark too, no matter how fast she's turning. She still runs if you only remove the other wire though, which confuses me to no end. Maybe I should break down and buy a brand new coil, I'm not sure. The aftermarket ones are well...aftermarket.
Alright I was gonna type somethin here about suspension but I'm too tired so it can wait for tomorrow lol!
Forum Rep : 129
PostSubject: Re: Craftsman GT3000 "MUTT"   Fri Jun 30, 2017 9:38 am
Maybe a fouled plug? My old sears with an onan did that and it turned out to be a bad plug. Could be why you are having the hard start. You may be really only running efficient on one cylinder.
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Fri Jun 30, 2017 2:40 pm
Maybe that's it. You think it would start on one cylinder at least though? I still think it's bleeding on the coil somewhere. The coil on here that went bad first I did manage to get going again. When you pulled the right spark plug wire (same as the one that kills it on here) you could see spark jump. I think it was because it had more voltage available from not firing both plugs at once. I'll try some different plugs out of another oppy I have
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Fri Jun 30, 2017 6:03 pm
Well Mighty I'd never have thought. I switched in a set of J19LMs I had in one of my spare 18s and she pretty much started right up. Must be my timing experiment killed them. She still won't run if I pull the right cyl wire but that's alright by me. She starts and runs, that's all I ask. Also I put one of those cheap mower hose clamps on where the fuel line goes to the carb. Should've before but on both of the oppys I've had on here it wasn't really a problem. Oh well lol.
Just got back from a romp along some power lines near me. Was about an hour and a mile or two away from my house. I managed to find a road to drive back on lol
I was just gonna ramp up this hill in 6th gear but I decided I didn't wanna die today, lol
Standing on top of this hill I took this pic lol. I
Forum Rep : 129
PostSubject: Re: Craftsman GT3000 "MUTT"   Fri Jun 30, 2017 10:23 pm
Looks like a nice ride!
Forum Rep : 24
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 01, 2017 10:07 pm
Them rear tires look vicious.
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Sun Jul 02, 2017 2:36 am
It was great! Lol, surprised I didn't roll her, I was on a side hill most of the time!
They really do tear up anything and everything!
I had one helluva a romp today. First I found a spot in the creek that the local amish use as a gravel pit
Ventured a bit farther up the creek from there
Came up out of the valley to do some stuff up on the hill, some trail rides and one big hill climb. On the way there, this happened.
It seems these nuts on the heims with spacers never wanna stay tight
My shift knob was the only thing with 1/2" thread I had. I drove home in 3rd gear keeping a very close eye on it, lol. It got me back to the shop where I then proceeded to put red loctite on every bolt on my steering arms and tighten them pretty much as tight as I could without a cheater bar.
Like shaking hands with a kitten!
After a brief intermission I was back at it. Hit some mud on a subsidiary of the main creek
Went over on the other side of the main creek. Rammed up some stuff
Then...this...
I just drove like this for the rest of the day since there's not much I could do about it at the time. I know these fenders and running boards are kinda flimsy(I've already bent them up from getting large chunks of wood rammed under me) but jeez man, come on.
I think I dislodged a grad total of 4 or 5 stumps from their earthen graves today. Some had to be convinced with 3rd gear... I wasnt trying to break this one loose. Just for a pic. Although it certainly did not help my frame problem...
I think the front end of the frame is about an inch higher than the rest of the frame. With no typical AYP frame cracks either! Wow! i'm really not looking forward to fixing this frame
Forum Rep : 94
PostSubject: Re: Craftsman GT3000 "MUTT"   Sun Jul 02, 2017 10:38 am
Looks like fun man! Except for the all the damage hahaha. The push bar seems like its holding up good as well!
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Sun Jul 02, 2017 1:42 pm
It was great! I loved that I could just start her up whenever I wanted again lol
I'm thinking of rerouting the exhaust. I was rammed up a tree and came back down and the end of the pipes shoved into a stump. It was so weird, just a few seconds of almost silence and a tiny bit of valve clatter. Almost snuffed her out with back pressure but I just let off the clutch again and went back up the tree and managed to work around it and back off it haha
Oh, and there was a real deep spot in the creek I was gonna try but since I dont have a winch or comealong just in case I didn't wanna risk it. It was like 3ft deep but only like 12 feet long lol. Maybe I should find a spot to throw the comealong and a chain on for now
PostSubject: Re: Craftsman GT3000 "MUTT"   Mon Jul 03, 2017 6:35 pm
Thoughts?
Good, but expensive Idea! Tho moped shocks (older) are heavy duty aswell.
*Thunderdivine*
My Custom Racing Mower Build
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 08, 2017 12:32 am
While doing my usual late night internet window shopping I found these babies. I'm pretty much in love. 23s, and only 7" wide! Sweet! Some time I gotta get some of these! They also come in 21s. First I gotta mod some 10" rims to have a 3/4" bore lol.
Oh, and MUTT's all tore apart now for reasons I'll explain when I feel like it (finish what I'm doing)
Forum Rep : 94
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 08, 2017 11:30 am
He's swapping in a 35hp Vanny V-twin, all around 4-link suspension, and hydraulic steering. He told me in the chat.
Hahahaha!
It'd be nice if you could find some bolt on 10" rims, then you could maybe find 3/4" hubs for 'em.
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 08, 2017 3:26 pm
Lol maybe I'll do that on some other build after I win the lottery
Yeah I have those 10" rims but they don't have much of an offset, I'll have to rely on the hubs or whatever rims I weld on em for that. Or I might add some positive camber to the front spindles to clear the knuckles. Who knows with me.
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 15, 2017 3:48 pm
So I've had MUTT tore apart for the past like 2 weeks or so. Building a new front axle mount to replace the chinsey stock one.
Straightened out the frame before I did anything. She's straight now!
I cut the stock mount out, forgot to get a pic. Luckily it seems AYP didn't have much in the budget for good welds.
Cut out the first part of my mount. Same stuff I used on my bumper
Had a cool looking mockup just to tease some guys lol.
At this point I quit for like a week because I thought I was out of cutoff wheels. Well I was about to go cut the piece with a bandsaw but it turns out you can use a half used chopsaw blade in an angle grinder. Not something I'd wanna try again, but it got the job done. Had to cut out a piece for the other side of the mount.
Got back at it last night. My bluetooth speaker broke so I had to fix it with a little cube speaker. Sounds better and is louder!
This is where I'm at as of now. Welded the mount together. Just gotta weld it in the frame and then I can start on bracing everything up. I'm thinking of doing like a 1" lift in the front just to help with approach angle. Oh, and the axle has about 10* caster and it looks like everything will clear linkage wise. The new mount has 15* of articulation too.
Forum Rep : 94
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 15, 2017 3:56 pm
Looks good Rich. John Deere GT steering box and motorcycle shocks should bolt right up now! Hahaha.
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 15, 2017 7:43 pm
got to love those ayp frames, with a little bracing they are bullet proof, you can find pit bike shocks online that are strong, how you think all those grown men ride em at dragstrips with out bottoming out
check out my builds
mini deuce
and my youtube channel
Forum Rep : 24
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 15, 2017 8:12 pm
Quote :
Man is it ever a bummer when the tunes die... the radio in my jeep recently died. Sad
Dont take your tunes for granted people.
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 15, 2017 8:46 pm
Taking a break to let the breaker cool down. She doesn't like being run on 135 for too long, lol. Used some of what i assume were deck mounts on this thing for supports. Gave her about 8* of positive caster, and just under an inch lift
Forum Rep : 94
PostSubject: Re: Craftsman GT3000 "MUTT"   Sat Jul 15, 2017 8:55 pm
Nice. Gonna have a couple braces from the front of the axle mount to the frame? With your driving habits I'd advise as much bracing as possible hahaha!
Page 9 of 31Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 20 ... 31  Next
» Craftsman GT3000 "MUTT"
» My first build 2003 craftsman gt3000 23hp v-twin
» The Mudding Craftsman
» Thinking about fixing steering
» Craftsman mower
