| Craftsman GT3000 "MUTT" Part I | |
+27Double W Cross Ranch Dave.MTD muckmudd biggasmowers Cambren Scott wenger Crazy_Carl richie thomas sadeoo7 prancstaman Lawren Wimberly ConfederaSears TheBeal tater195 Jymmyee Warren Evans 1997 Murray Thunderdivine Rockinator mr.modified MightyRaze TheGreenHornet CraftsmanQuad19 Murryman AllisKidD21 MatthewD Doug RichieRichOverdrive 31 posters |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 23rd 2017, 9:39 pm | |
| - AllisKidD21 wrote:
- Just use a pnematic hand drill. Thats what I do and it works great! Unless you need the hole to be, y'know, straight. Hahaha
PNEUMATIC HAND H'WHAT? THAT'S SORCERY! I'll stick to my angry wall pixie operated wrist breaker, thanks! | |
Age : 25 Join date : 2016-07-10 Points : 8349 Posts : 5190 Location : Ontario Canada
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 23rd 2017, 11:02 pm | |
| Oh ok, hahaha fair enough. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 14946 Posts : 10556 Location : Oklahoma
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 23rd 2017, 11:13 pm | |
| I have one of those. "angry wall pixie operated wrist breaker". I like the cordless, but when all out of battery I get it out. I've had the thing rip out of my hand and go twirling stopped by the cord a few times. | |
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5515 Posts : 1993 Location : Northern Ireland
Age : 21 Join date : 2016-10-29 Points : 6503 Posts : 3563 Location : Lewisburg, KY
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 27th 2017, 1:47 am | |
| - MatthewD wrote:
- Steering box looks really good man! Really beefy setup now.
Thanks! Hopefully this one won't skip or break, lol No real updates. I cut the mounting face for the motor off to ease fitment of the box. Didn't need it anyways. I got the other drill press going. The two wires going to the cap were stripped clean in a spot. Electrical taped them and it runs sweet now. Did have a little accident with the variator, the snapring holding a big spring popped off, sending the spring right into the metal ceiling, where it made a perfect indentation of the washer that was on top of it, and a huge BANG i almost died laughing! | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 28th 2017, 7:38 pm | |
| Got the box mounted! Used a piece of the channel steel I used for the front axle mount and bumper. Had a kinda tab on the end that I bet so it was the perfect angle. I made the arm out of two pieces of 1/4" flatstock and the driveshaft adapter. Should hold up. Pic of box mounted Have to modify the linkage some. Gotta kinda bend it down so it clears the tie rod, might shorten it too, there's a lot of room for the steering arm to move forward. Hopefully I can shorten it enough so it won't hit the rod that holds the skidplate... | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 28th 2017, 8:28 pm | |
| Look good Rich! Hows the ratio with the new setup? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 28th 2017, 8:40 pm | |
| A bit under two turns lock to lock. Could add some more turns by drilling some more holes in the arm and have to fight the linkage even more, lol. Maybe I will. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 28th 2017, 9:07 pm | |
- A bit under two turns lock to lock. Could add some more turns by drilling some more holes in the arm and have to fight the linkage even more, lol. Maybe I will.
Yeah thats what I did to the steering arm on the MTD, its nice do have some adjustability. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 28th 2017, 9:23 pm | |
Yeah thats what I did to the steering arm on the MTD, its nice do have some adjustability. Yeah it is. I have 3 holes on the axle side to choose from, and two on the steering arm. I woulda done some more on the arm but the drill press threw the spring again. I actually got clobbered by the washer when it came back down this time lol I actually have a cross vice on this drill press, so I can line up and space the holes perfectly. The two holes on it are 7 turns apart, lol | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 28th 2017, 10:49 pm | |
| - mightyraze wrote:
- Ouch! Hope you were not hurt bad. Careful there.
I was just drilling a hole and all of the sudden POP BANG DOIIINNNGGG and the washer kinda bounced off my head lol, all my hair tucked up in my hat kinda softened it lol. Scared me more than it hurt I actually manages to finish the hole without the spring in there. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 29th 2017, 12:38 am | |
| Your having such bad luck with springs it's probably a good thing your not doing suspension haha. Now you gotta go ram your front wheels up against some stuff and see if the steering box takes it well! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 29th 2017, 5:29 am | |
| Finished welding up the front axle mount. I think all chances of suspension are gone with this one. Maybe on a future build... Pulled a Mowron trick, used some 3/4" Hex stuff to strengthen the frame. One side on. Both sides done inside and out.. My stick welding skills have increased greatly in the past year or so. If I break this...well I'm not sure what I'd do... | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 29th 2017, 9:24 am | |
| Nice, hopefully that'll do the trick Rich. Were you really doing this at 5:00 am? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 29th 2017, 10:23 am | |
| I bet he was! I was up at 6 working on Red. Just too hot otherwise. Where Rich lives, he has like 100% humidity to boot. YIKES! Rich, I'm not a welder, and only access to a arc welder too. I think you did well. Keep it up and it will only get better! | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I July 29th 2017, 2:35 pm | |
- Nice, hopefully that'll do the trick Rich. Were you really doing this at 5:00 am?
Yep. I usually stay up all night. I went to bed at about 6, I just got up at 1 lol - mightyraze wrote:
- I bet he was! I was up at 6 working on Red. Just too hot otherwise. Where Rich lives, he has like 100% humidity to boot. YIKES!
Rich, I'm not a welder, and only access to a arc welder too. I think you did well. Keep it up and it will only get better! Thanks Mighty! I don't think it's 100%. It did rain a day or two ago and it's still cool from it, maybe I'm just not feeling it | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4858 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Craftsman GT3000 "MUTT" Part I August 1st 2017, 8:28 pm | |
| Yeah lol, I was scared to death I had tore the box up but I peeked at it and saw the adapter cracked open and was pretty relieved. My dad has all these ideas for welding half a split lock collar on but I'm thinking just get a chunk of round stock and have the 3/4" hole machined in the center and a keyway broached in, and the holes drilled and tapped at either side. Although I don't exactly have access to a machine shop(yet???) so that may be a bit hard...might just go with a pulley hub if I can find one I deem skookum enough. And the paint is meh, it looks like I painted chicken sh*t on all of my welds but it should keep the rust away! | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I August 27th 2017, 1:43 pm | |
| You guys remember my fender and running board issue? Well I solved it! Picked up some fenders and running boards from my dealer(same guy I got the front and rear rims from, plus my Snapper crawler) Note, yard pro sticker will be removed and I'll repaint the lettering that I had before on there This fender must've been on a tractor with a 633. Didn't have the shifter hole so I cut my own. Somehow got the size and placement just right. I like this one a lot better than the one I had before, a lot less mud will come through. Also this one doesn't have the cupholder hole so no mud will come through there! Other cuts I had to make to get the execs to fit again Cut for brake linkage I definitely got lucky with these fenders! They pretty much match the hood! Woohoo! Now soon I'll deal with the rims, they're gonna be black(finally lol) | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I August 27th 2017, 2:53 pm | |
| Wow those look real sharp on there Rich, you gonna paint 'em or just leave the natural look on? I think they actually look pretty good as is myself. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
