LT3000 Kittybomber Lend10PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown TimerLT3000 Kittybomber Rend10
 LT3000 Kittybomber
TheSirDjay
TheSirDjay
LT3000 Kittybomber Empty
PostSubject: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeSat Nov 26, 2016 2:10 pm
A few weeks ago I got a mower from my friend whose neighbors were evicted.
LT3000 Kittybomber Ne5jbk10
I only got the mower at the end of the Summer, and didn't even hear of ATLTF until a few weeks ago, so I was unable to enter the build off. But either way here is the thread I'll be posting Kittybomber updates on. The name is from the DAF P-40 squads and eventually I'll paint it in a similar fashion.
LT3000 Kittybomber Home_p10
Anyway dropped the Peerless Tecumseh Transaxle out and started on the updated wiring and removing the safety switches. There honestly was so much wiring I was able to re-do the entire system without buying anything but the buttons, lol!  Razz
LT3000 Kittybomber Jl4sie12
LT3000 Kittybomber 6pzi4z11
Forum Rep : 47
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeSat Nov 26, 2016 4:09 pm
Clean LT.
I fixed your pictures for you. You forgot the [img] tags.
Forum Rep : 40
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeSat Nov 26, 2016 7:36 pm
Nice! That's a pretty new LT. OHV single cyl Briggs?
TheGreenHornet
TheGreenHornet
Forum Rep : 2
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeFri Dec 02, 2016 8:23 pm
Those are nice engines. intek i assume. ive heard good things about the single cylinder inteks. how many speeds is that transaxle. im assuming it is a 900 series. do you know which?
Forum Rep : 47
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeFri Dec 02, 2016 9:09 pm
From my experience the single Inteks are junk. My V-twin works great though.
Probably an MST, mower looks to be about the time the MST was the standard.
Forum Rep : 387
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeSat Dec 03, 2016 1:07 am
Then I have a single cylinder Intek that has worked solid for the past 10 years. LT3000 Kittybomber 845561842
Patriot [2019 Build Off]
Kal-El [2018 3rd Place]
Sasquatch II [2017 Finalist]
Li'l Red 2.0
LT3000 Kittybomber Admins10
Forum Rep : 40
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeSat Dec 03, 2016 12:05 pm
It is a Peerless MST 206. See this topic.
TheSirDjay
TheSirDjay
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeMon Dec 05, 2016 1:06 pm
Doug Fackler wrote:
Clean LT.
Thanks a lot, still getting used to the layout. scratch
Yes it is! You guys always seem to know everything about everything. I just found out today it's a 2005, so I can start looking for a manual for it. Question
And indeed as MatthewD said, it is a MST206 with 6 gears. LT3000 Kittybomber 102878487
Forum Rep : 40
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeMon Dec 05, 2016 1:09 pm
Hey Cheers man! Could you do me a favor and take a pic of the brake assembly on the trans, I'm trying to assemble one for an MST 205.
TheSirDjay
TheSirDjay
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeTue Dec 06, 2016 9:52 am
Yup, here you are! Just ask if you need a different view.
LT3000 Kittybomber 06_0ai11
LT3000 Kittybomber 07_di011
LT3000 Kittybomber 08_vmh11
As you can see, they're pretty rusty. I might have to get new brakes I can't clean these up.
TheSirDjay
TheSirDjay
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeTue Dec 06, 2016 10:00 am
Also, quick update. Went to Tractor Supply Co. and picked a new 5/8 4 inch pulley! The next step is to weld up the transaxle and see if I can move the 9 inch pulley to the front.
LT3000 Kittybomber 09_rmp11
Wiring is basically done as you can see. (Quick question? Is the solenoid facing the right way?)
LT3000 Kittybomber 02_m0n11
LT3000 Kittybomber 03_rqb11
Also I personally like the Murray hood more, so I'll have to see I can mount that on the Craftsman.
LT3000 Kittybomber 05_uvj11
Forum Rep : 205
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeTue Dec 06, 2016 12:10 pm
Solenoid looks fine. As long as the right cables are hooked to the right terminals and it has a good ground, it should work alright.
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 - Case 444 - Bolens Versamatic
Forum Rep : 40
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeTue Dec 06, 2016 12:21 pm
Cheers man that's perfect Wink
Forum Rep : 47
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeTue Dec 06, 2016 12:33 pm
Solenoid looks good to me. Maybe, if possible, move it higher if you can so its less likely to get submerged.
Also may want to wire loom those wires or tape/ ziptie them so they dont get tangled and sucked into your steering gear. Shocked
TheSirDjay
TheSirDjay
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeWed Dec 07, 2016 1:58 pm
Yup, just posted a question on the alternator, and then I'll clean everything up. Plus, I don't plan on mudding so if the solenoid is submerged the mower is probably done for. And I'll finally learn how to weld next weekend so the transaxle won't have to sit any longer. Fun times! bounce
Forum Rep : 40
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeWed Dec 07, 2016 2:12 pm
Nice. I learned to weld a few years ago, pretty useful skill for mower modding.
Maine Mud Mower
Maine Mud Mower
Forum Rep : 7
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeThu Dec 08, 2016 12:22 pm
Looks like you have a slightly newer version of my rig. Might want to take a look at this video for a few ideas.
http://www.Mudmower.com
TheSirDjay
TheSirDjay
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeMon Mar 13, 2017 9:58 am
Finally an update! We got it back up and running and got a short clip on the maiden voyage. I will give a more in depth update later on sometime, and thank you to Maine Mud Mower for a great reference video. On the short road we were able to hit 30 MPH or 48 for the metric folks! bounce
Oh and the stall at the end was a wheelie attempt in 6th gear. No worries! lol!
Forum Rep : 40
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeTue Mar 14, 2017 5:42 pm
Nice! That OHV Briggs sounds nice Wink
Forum Rep : 387
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeWed Mar 15, 2017 12:00 am
Looking good! Still going to put a sharkface on in? Twisted Evil
Li'l Red 2.0
TheSirDjay
TheSirDjay
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeThu Mar 16, 2017 9:33 pm
Yeah the Briggs does sound pretty good, you can barely hear anything though! But yes I was going to do the sharkface camo still, but it might have to wait. My friend and I took it for a spin and tried to drift it at stock height and well, you can guess how that turned out. It tipped and ended ramping off the rocks and landing on the hood, bending the frame. So now the steering rod rubs the pulley as well, and might as well convert it to direct steering as well. But then it will be making the downward dog pose, so I have to add a jackshaft and lower the transaxle. Oh and stopping would be nice so brakes moved up the priority list, as well as a gas pedal because why not at this point? LT3000 Kittybomber 2429134702
Anyways the video of the crash will be up tomorrow, as well as some pictures of the clutch, pulleys, and everything else. Rolling Eyes
Forum Rep : 387
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeThu Mar 16, 2017 10:36 pm
Oh no! Hope everyone is ok.
Li'l Red 2.0
TheSirDjay
TheSirDjay
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeThu Mar 16, 2017 10:43 pm
Yeah, he's just a little sore on his arm. He'll live!
TheSirDjay
TheSirDjay
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeFri Mar 17, 2017 11:26 pm
I finally got the video up!
The crash starts out at the 7:55 mark so if you want to see the rest of the footage just skip back to the beginning. Also while fixing the bent frame I used my new favorite phrase, "I need to finesse it in there; hand me the hammer and blowtorch."
Anyways onto the build, below you can see the double pulley clutch and linkage that I welded up. Before it only had about an inch of movement and would still move in gear, so today we notched the frame to get a little more swing action. Now it doesn't ram into the side of the frame anymore. cheers
The 9 inch pulley welded to the pre-existing location.
LT3000 Kittybomber Screen11
The clutch system.
LT3000 Kittybomber Screen12
The linkage.
LT3000 Kittybomber Screen13
And a shot of the under belly after it flipped over.
LT3000 Kittybomber Under_10
Next on the list is brakes and fully finishing the wiring, with lights and everything! bounce
Forum Rep : 387
PostSubject: Re: LT3000 Kittybomber   LT3000 Kittybomber Icon_minitimeFri Mar 17, 2017 11:47 pm
That was quite the wreck. Glad everyone is ok.
Li'l Red 2.0
LT3000 Kittybomber
» LT3000 Kittybomber
