Richie's Murray Widebody- "Orion" Lend10PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown TimerRichie's Murray Widebody- "Orion" Rend10
Go to page : 1, 2, 3, 4  Next
Forum Rep : 69
Richie's Murray Widebody- "Orion" Empty
PostSubject: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeMon May 22, 2017 11:27 pm
So I went to a fellow atltf member's place and picked up some stuff...
In that stuff was this...a 90's (I think) 1st gen Murray Widebody which had a MST206 and Tecrapsuk engine
Richie's Murray Widebody- "Orion" Mr10
Before I even got the thing running I threw on these (which I got on rims from that same guy). Wheels came off no trouble! I also put some cheap go kart tires on the front because I had them lying around. I hadn't even pushed the clutch pedal in yet and this thing had decent tires!
Richie's Murray Widebody- "Orion" 18679010
I swapped on a Briggs 14hp 28ci OHV(also got that from him) because i hate any vertical shaft tecrapsuk(besides their Vtwins)
Richie's Murray Widebody- "Orion" 18678810
At first I had major issues with the needle and seat not doing their job...
Richie's Murray Widebody- "Orion" 18624510
Richie's Murray Widebody- "Orion" 18624610
I swapped the seals and gaskets from this carb to another I had, this one runs lean and therefore hot but it's been improving. At first the muffler would glow red with the lights off. I actually drilled out the side of the muffler to where it has a like 1" hole instead of all the tiny holes to let some heat out. I also undickered the muffler bolts by tapping the exhaust adapter holes to 3/8" and using some allen head shoulder bolts I had.
She's Hot!
Richie's Murray Widebody- "Orion" 18644410
I love unibits lol, just let em eat till the hole is the right size. Muffler is only slightly louder and sounds better than it did before
Richie's Murray Widebody- "Orion" 18644510
I had to modify the exhaust a little because of the hood, add a little piece of tubing to direct it out under the hood. I only had the stick welder so it came out a little messy, but it holds.
Richie's Murray Widebody- "Orion" 18643610
So whatcha think? I have yet to pulley swap it, add a foot throttle, or wire anything besides a kill. In fact I really don't wanna pulley swap it. It looks like a bear to fit a bigger pulley on the front and there's no way to really adjust any pulleys to make a stock belt still work. If I do pulley swap it, I'm thinking 6 to 4 pulleys.
Richie's Murray Widebody- "Orion" 18644210
Richie's Murray Widebody- "Orion" 18644610
Forum Rep : 86
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeTue May 23, 2017 8:44 am
I dig it...just try not to roll this one ok Rich? lol! lol! Richie's Murray Widebody- "Orion" 1098998679
Forum Rep : 174
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeTue May 23, 2017 9:05 am
Orion?? You're really gonna "Ride the Lighting" with this tractor!!! Haha I like it so far. It's about time Rich started a second project!
        ----Uploading Pictures----
- Toro Rat Rod Tractor Build
Online
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeTue May 23, 2017 11:50 am
Ehhh no promises....I really dont like this hood lol, it's ugly af. Might put a snapper hood on this one too lol.
lol! Yeah, I've been pretty bored not building something. I was gonna start another project but it turns out that something in the foote I got (from the same guy i got this stuff from lol) has a stripped gear. Soooo idk. I already have plenty on my hands with this!
Warren Evans
Warren Evans
Forum Rep : 5
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeTue May 23, 2017 7:18 pm
just take a grinder to it and your pulley will fit
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeThu May 25, 2017 10:11 pm
Yeah, but there's no place for extra idlers and belt keepers and such
Well, as a few of you have seen, I put up a video of my first romp on Orion. Didn't get stuck and actually barely had to rock it. she's pretty mint
So the next thing I really gotta do is a pulley swap. I have an about 7" cast iron pulley that should be perfect. Problem is, I don't have a 5/8" bore pulley, so I'm thinking of using the center of the stock pulley with an old engine pulley or something. Not sure what the speed is gonna be exactly, prolly somewhere over 30. But I'm fine with that. The brakes on this thing are actually pretty decent. I'll be doing some math on speeds here in a little bit.
ConfederaSears
ConfederaSears
Forum Rep : 3
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeFri May 26, 2017 12:23 am
nice
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeFri Jun 02, 2017 4:54 pm
I got a bunch done on her in the past few days. Pulley swap is done (besides a few belt keepers) I think, I might use the old deck drive pulley on the back rather than what I have now.
Old pulley gave me a little trouble, had to heat it with the torch and give it some crayons to get it to come off. Even with the wax it took a well educated hammer to drive the input shaft out
Richie's Murray Widebody- "Orion" 18871211
Richie's Murray Widebody- "Orion" 18902710
Drilled the spot welds out of the old pulley and knocked it off of the hub, then i put the hub on a bolt in the drill press and filed it down to where I could fit an idler pulley over it snugly (sans bearing) and then drilled holes in the hub to bolt the pulley onto. Have you guys noticed I'm kinda cheap yet?  Richie's Murray Widebody- "Orion" 1098998679 Literally the only pulley I have ever bought was the idler for the clutch on MUTT
Richie's Murray Widebody- "Orion" 18870810
Richie's Murray Widebody- "Orion" 18834710
So now that I had the rear pulley done, it was time to swap the front. I was kinda dreading this moment but it turns out Warren was right, you can just take your grinder to the underside of the thing and just ask it nicely (with a cutoff wheel) and it will fit. This is an 8" cast iron pulley, my rear pulley is 4-1/2". So that gives me a just under 2:1 pulley ratio.
Richie's Murray Widebody- "Orion" 18902110
Somewhere in the midst of this I wired her and stole a battery out of my Snapper. Believe it or not, the headlights work! (they are on 12v rather than the stator output btw so they are waaaaaay brighter) I welded in like 2 belt keepers, added an idler to keep the belt off the shifter, and off I went. She throws the belt when you let off the clutch after a few times, I'll just keep adding keepers till it stops. This thing is REALLY fast. I think like 30mph, maybe more. Brakes still work ok at speed, surprisingly enough. Right now I'm making another gas pedal, the bike brake I put on just doesn't work for me.
Forum Rep : 174
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeFri Jun 02, 2017 6:45 pm
With those Ags on there and that kinda wheel speed, ya better get some mud flaps!! Haha, looks good Rich.
Online
Forum Rep : 328
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeFri Jun 02, 2017 10:56 pm
Nice tractor!  That's how my Li'l Red looked except I had a Twin Briggs!
Richie's Murray Widebody- "Orion" Img_2183
Patriot [2019 Build Off]
Kal-El [2018 3rd Place]
Sasquatch II [2017 Finalist]
ATLTF Facebook Page
How To Upload Pictures
ATLTF Staff:
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeSat Jun 03, 2017 1:25 pm
Richie's Murray Widebody- "Orion" IMG_20160829_172348745_zpsictrtbhr
Yeah, they're pretty much the same tractor! This one might get a governed 18hp oppy if I can get a carb together for it. The single just doesn't do it for me, lol
Forum Rep : 86
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeFri Aug 11, 2017 12:00 pm
Any updates on this thing? Its the exact same tractor I picked up while I was in Kentucky a couple weeks ago. 17.5 Teccy with pressure lube, MST-206 (in the CQ now) and the same front tires. Original I assume. Mine didn't come with back wheels though. After looking at the teccy more and more I'm finding it kind of similar to a briggs single. But i like a few things about the teccy. Plastic carb bowl so the bowl doesn't rust, and the pressure lube. I would've at least ran it till it blew, but I do love a good ol' briggs 28ci single
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeFri Aug 11, 2017 1:47 pm
I'm not sure what I'm doing with this yet. I did end up putting a 6" pulley on the back to let off the speed some but I need another belt and clutch pulley. As of now it's just sitting in the store building. I plan to get on it after I get the craftsman put together and I fix the trans in my grass cutter.
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeMon Nov 20, 2017 7:27 pm
This thing hasn't been touched in months, just sitting in the store building. Kinda tempted to use some of the parts off of the parts murray gt to make this thing drivable before @CraftsmanQuad19 finally comes and gets it. After I finish the exhaust on Mutt, of course.
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeWed Dec 20, 2017 11:20 pm
Now that I have Mutt outta the shop, I figured I'd waste my time on something else...
Put Mutts old fronts on because I wanted bigger fronts that actually held air lol.. 8" front rims make everything better! They clear everything too! Murray don't flex lol.
Richie's Murray Widebody- "Orion" 25624810
Very nice high back seat from the parts Murray.
Richie's Murray Widebody- "Orion" 25564710
Given a good rinse, 14hp junk Briggs off.
Richie's Murray Widebody- "Orion" 25674110
21hp oppy also from parts oppy on. Bolted right up. Took a bit of doing to set up the foot throttle but I got it done. Also swapped out the carbin it for another 4 screw that I'm hoping works. Actually have two fuel filters on this thing for whatever reason haha
Richie's Murray Widebody- "Orion" 25674210
This is where I'm at now. Pretty much gotta work out the belt system(ugh, what I hate most about this thing), and hook up the wiring.
Richie's Murray Widebody- "Orion" 25564513
Forum Rep : 328
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeWed Dec 20, 2017 11:41 pm
It will flex. If like mine, the frame will flex. You'll want to probably stiffen that up in the future. Looks good Rich!
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeWed Dec 20, 2017 11:46 pm
Yeah, I'm sure i will. not sure how I will lol. Wanna get this thing moving before I worry about that stuff.
Forum Rep : 86
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeThu Dec 21, 2017 8:03 am
So...it not for sale anymore? Crying or Very sad Sad
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeThu Dec 21, 2017 9:23 am
What model is it My murray widebodys dont have enough hood space to fit an oppy in .
Forum Rep : 174
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeThu Dec 21, 2017 10:13 am
Looks a lot better with those fronts Rich. Gotta get some more acticulation outta that front axle though, haha.
Online
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeThu Dec 21, 2017 1:57 pm
This is one of the earlier model widebodys. @Mightyraze has the same one, but with a different hood.
MOD Edit: (Mightyraze) Mod got careless and messed up this post.  Sorry Rich.
Forum Rep : 22
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeThu Dec 21, 2017 10:05 pm
cool little build man, I need to get my garage done so i can get back to building mowers, really looking forward to a "rally" type build like this
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeThu Dec 21, 2017 10:15 pm
Thanks CC.
Mighty over here going crazy wit the mod edits.
This one's a 42515X92A. Manufacture date 00136. 136th day of 2000? Came with a 17.5 Tecumseh OHV single(have it, bunch of parts were scabbed off it before I got it.).
Forum Rep : 328
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeThu Dec 21, 2017 10:23 pm
That was a weird one?  I didn't mean to edit your post. I meant to hit quote and it overwrote your post? I would fix it if I still had it cached but I closed that window. scratch
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 69
PostSubject: Re: Richie's Murray Widebody- "Orion"   Richie's Murray Widebody- "Orion" Icon_minitimeFri Dec 22, 2017 12:16 pm
if it has a peerless tranny i dont think it will be a 2000 year , more around 96-98 i would think, all the murrays i have gotten with peerless trannys were under 2000.
Page 1 of 4Go to page : 1, 2, 3, 4  Next
» I'm back with a updated stable.
» Painting my Murray Widebody
» Project: M&M's "military Mud Mowing Murray"
» Anyone ever go to lake murray ok
» Murray Street Mower
