| | Fordification's LGT-2000 build. | |
Fordification Member
Join date : 2017-02-01 Points : 2682 Posts : 50 Location : Maryland
| Subject: Fordification's LGT-2000 build. June 23rd 2017, 11:25 pm | |
| So I picked up this LT-2000 in a trade this morning. all stock besides the front wheels. so far all I've done is put a spare rear end in it that I had laying around that is locked and has a pulley swap on it already. so now the thing runs about 20mph instead of the 4.9 when I got it. Plans arent set in stone yet but some basics are -Custom front and rear bumper (with hitch) for pushing and pulling stuff when needed -Aggressive pulley swap, hoping for 35mph -26" AG's for the rear -2" lift -Widen track width -SLIGHT stretch (around 6") -Snorkel EDIT: Blew up the 18hp intek a few nights ago, putting a different body and engine on this frame. Tractor will be called the "LGT-2000"
Last edited by Fordification on June 28th 2017, 9:22 am; edited 2 times in total | |
Age : 49 Join date : 2016-09-06 Points : 14946 Posts : 10556 Location : Oklahoma
| Subject: Re: Fordification's LGT-2000 build. June 24th 2017, 12:46 am | |
| Sweet, I may be looking for a craftsman frame for next year's build. Definitely need a lift to fit 26" tires in there! | |
| Subject: Re: Fordification's LGT-2000 build. June 24th 2017, 1:10 am | |
| - mightyraze wrote:
- Sweet, I may be looking for a craftsman frame for next year's build. Definitely need a lift to fit 26" tires in there!
Yeah, I had a craftsman lt-1000 frame with a ford lgt body on it for the 2017 build, but ended up getting caught up with personal stuff and had to put it on hold. finally got back on track though. As for the lift, yeah I'm hoping to get away with as small of a lift as possible | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8349 Posts : 5190 Location : Ontario Canada
| Subject: Re: Fordification's LGT-2000 build. June 24th 2017, 10:31 am | |
| Whats transaxle do you have? hopefully its a heavy unit if you're putting 26" Ags on there! Hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Fordification's LGT-2000 build. June 25th 2017, 11:31 am | |
| - AllisKidD21 wrote:
- Whats transaxle do you have? hopefully its a heavy unit if you're putting 26" Ags on there! Hahaha.
Not sure what transaxle I will end up with, I was going to buy one this week but have to get a engine first... the valves shot through the head and valve cover..... so going to upgrade engines soon just have to decide what I want to swap in. Almost thinking of a diesel? | |
| Subject: Re: Fordification's LGT-2000 build. June 28th 2017, 9:20 am | |
| So I blew the Intek up and pulled the engine out. then decided that I want to run my old Ford LGT-120 body off of the old Lt-1000 bent frame I had a few months ago. So currently getting that setup to go on. have a bit of trimming to do on the frame so that the Ford body will fit. Suspension height will stay the same but the body is going to be body-dropped so that the foot-rests are even with the bottom of the frame. | |
| | | | RichieRichOverdrive Moderator
Age : 21 Join date : 2016-10-29 Points : 6503 Posts : 3563 Location : Lewisburg, KY
| Subject: Re: Fordification's LGT-2000 build. August 8th 2017, 10:36 pm | |
- Looks pretty dank! Did you just flip the front axle? That's really a bad idea...
Uhm, yes and no. It is currently flipped in the pictures as i was using it to make measurements for the custom axle i am working on that will basically be using fabricated "drop spindles" with part of the factory axle but widened 3" | |
| Who is online? | In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests
