| | Long day, good results. | |
Age : 49 Join date : 2016-09-06 Points : 15032 Posts : 10618 Location : Oklahoma
| Subject: Long day, good results. October 15th 2017, 1:31 am | |
| Well, got a lot done today. Did a extended brake job on the front of the Impala today. It was starting the shake something fierce when I brake. Sometimes if on wet ground could be a bit controllable. I changed the brakes just 3 months ago, and it was shaking before that. This shaking has gotten worse over the course of the past 3 brake pad changes when I would brake. The car did not have this when I purchased it back in 2014. So today, I purchased new rotors and ceramic pads. I checked the wheel bearings while I was there. They looked good, felt good, and sounded good. Cleaned the rust on the mating surface and treated them. I didn't get new pictures of reassembly as my hands were nasty. New rotors installed, they seemed way better quality of the stock ones. I also replaced the el-cheapo pads I had used the past few times with some ceramic. I did some research and the pads I was using got really hot and become ineffective. Gave a good test drive and realized that all front end vibration is now gone. I thought I had a bad tire but I guess turned out to be a bad rotor. There was chunks of rusty metal coming off them. New brakes now are as smooth as silk now. No matter how fast or slow, it stops really well! Another job well done! Worked on the seat mount on my blue lawn tractor. Almost done with that, need a new bolt. Also got the yard mowed! | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8371 Posts : 5190 Location : Ontario Canada
| Subject: Re: Long day, good results. October 15th 2017, 7:40 am | |
| Yeah some of the cheaper brake pads you can buy arent so good, the brake dust they produce can be brutal and then it make a mess of everything. Did your pistons go back okay? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Long day, good results. October 15th 2017, 11:27 am | |
| That's good, nothing like putting brand new pads and rotors on only to have the pistons seize half out and wear it all down again hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | | Sponsored content
| Who is online? | In total there are 19 users online :: 1 Registered, 0 Hidden and 18 Guests RichieRichOverdriveMost users ever online was 412 on January 7th 2023, 7:59 am |
