| Craftsman Lt4000 mild off-roader | |
+5Crazy_Carl RichieRichOverdrive AllisKidD21 CraftsmanQuad19 muckmudd 9 posters |
| Subject: Re: Craftsman Lt4000 mild off-roader January 25th 2018, 10:20 pm | |
| The AYP and sears/roper 633 isn’t made by the same company for both brands? But I meant what’s less heavy duty exactly? What did they cheap out on? | |
Age : 25 Join date : 2016-07-10 Points : 8349 Posts : 5190 Location : Ontario Canada
| Subject: Re: Craftsman Lt4000 mild off-roader January 25th 2018, 10:22 pm | |
| Well I think the case is just not as quite as heavy as the original ones. I could be wrong though, but I'm pretty sure there's a bit of a difference. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2016-04-12 Points : 5718 Posts : 2617 Location : Indiana
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3323 Posts : 825 Location : In the shop
Age : 49 Join date : 2016-09-06 Points : 14946 Posts : 10556 Location : Oklahoma
| Subject: Re: Craftsman Lt4000 mild off-roader January 25th 2018, 11:31 pm | |
| - CraftsmanQuad19 wrote:
- The AYP and sears/roper 633 isn’t made by the same company for both brands? But I meant what’s less heavy duty exactly? What did they cheap out on?
They went from cast iron to cast aluminum. - muckmudd wrote:
- Does anyone make vertical shaft cast iron cases?
Peerless 600? @AllisKidD21 runs one of those I think? | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 25th 2018, 11:36 pm | |
Peerless 600? @AllisKidD21 runs one of those I think? Right, forgot about that one. | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 26th 2018, 12:18 am | |
| No the Peerless 600's have a cast aluminum case. The axle sleeves are cast iron though I believe. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 26th 2018, 8:10 am | |
| Yeah haha, it'd be cool if it was cast iron though. I can't really think of any cast iron vertical input transaxles, but I'm sure they have existed at some point over the years. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5254 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Craftsman Lt4000 mild off-roader January 26th 2018, 1:28 pm | |
| WOW! I never realized that there was such a big difference in the bull gear size. I guess I might have to make a hub on the lathe that would fit a spicer in order to solid axle it. | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 26th 2018, 1:32 pm | |
| Yeah, I was surprised too. The spider gears are smaller too, which is why most people don't just weld them together like they do on a Peerless, because the welds don't have as much surface to grab. | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 26th 2018, 10:54 pm | |
| Yeah I had a hard time putting it together. I think I lost one of the two so I had to go find a ball out of a bearing. But in the end I thought they were both in. | |
muddstir Member
Join date : 2012-01-22 Points : 4799 Posts : 318 Location : Western,PA
| Subject: Re: Craftsman Lt4000 mild off-roader January 27th 2018, 1:48 pm | |
| When you say "lost one" is that like outside of the case in the yard or something, or inside the case ? And when you got a ball out of a bearing was it the same diameter as the other one? | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 27th 2018, 2:07 pm | |
| Yes Muddstir. The bearing is the same size. I just pulled it out of a ball bearing. However I do not know where the ball ended up. It could still be in the case for all I know but I did drop the case once and it could have fallen out then. And I did try to feel for it in the grease but I couldn't find it so I guess we will see when it blows. | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 27th 2018, 4:02 pm | |
| Well I don't think that the ball would keep it from working like that, however it's obviously not a good idea to have it bouncing around in your tranny. Hopefully you can figure it out! | |
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4692 Posts : 1944 Location : Kansas
| Subject: Re: Craftsman Lt4000 mild off-roader January 27th 2018, 4:04 pm | |
| So does the imput shaft turn freely? if it does not you could have a bushing tab that got flipped over in the center of the case and that will freeze up the gears and shifter but the axle should still turn .
But if your axle is not turning you could have warped the spider gear rod when welding the spiders.( i dont think thats very likely) i would recommend welding some 1/2" square steel rod to the sides of the spider gear rod to the spider gears, i had my spicer welded like yours and the welds held fine but ripped the steel out of the sintered steel gears and welding some steel to the rod and gears would do better at taking the strain of being locked. | |
muddstir Member
| Subject: Re: Craftsman Lt4000 mild off-roader January 27th 2018, 6:55 pm | |
| I bought a craftsman that had a locked up transaxle. Tore it apart and one of the shift balls was jamed between the one input gear and the case. I had to bend the plate the balls operate on up alittle bit reinstall the balls and springs, and worked like a champ | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 27th 2018, 9:15 pm | |
| You can make your own out of 1/8" steel , just grind it into a half moon shape, i have done that when i lost one and couldn't find it. | |
