 Craftsman LT4000 off road /mud build
Go to page : 1, 2, 3, 4, 5, 6, 7, 8  Next
Forum Rep : 36
PostSubject: Craftsman LT4000 off road /mud build   Tue Dec 05, 2017 9:27 pm
This is a build that i have been working on for a couple months but have been doing small things once at a time .
Currently it has a 19.5 hp Briggs and Stratton opposed twin (governor removed fully) , with slight head work and porting .
Fully re-enforced frame with 1 inch steel tube down the entire frame and re-built console to make a stronger steering system, using a murray pan frame steering pinion and gear .
The front end is made out of 3/16" steel square tube with front wheel assemblies home made crossing golf carts spindles with atv wheel assemblies with drum brakes to hopefully have functional front braking for better uphill and down hill stopping . I hope to put a 820 peerless in it with some type of tires that have at least 1 inch of aggressive tread.
Forum Rep : 18
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Dec 05, 2017 10:39 pm
Looks really cool! Gonna be a racer or a rally machine or a mudder or what?
Forum Rep : 125
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Dec 05, 2017 11:44 pm
LOL, it's in his title.  Looks to be a mud build. Very Happy
Would be a bit interested in seeing what you did for steering if you have any pix of that.
Progress:   ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Master
Master
Forum Rep : 35
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Dec 06, 2017 7:46 am
Dual batteries? You're not messing around. I like how you're taking your time because eventually this is going to be an awesome offroad/ mud tractor. Hopefully it won't break!
Is there any way you can change your builds in your signature to links? I'd like to check them out.
Online
Forum Rep : 36
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Dec 06, 2017 8:39 am
Yeah dual batteries was something i wanted to do on an opposed twin because of their high cranking demands . I am trying to do this build as well as i can with my limited funds , and i will change my signature info , i still need to post about more of my projects because these are the main projects that look the best .
Forum Rep : 36
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Dec 06, 2017 10:11 am
I will post pics of steering once i fix all the bugs and hook up all the linkages , and weld up some arms to pair the wheels together .
Forum Rep : 36
PostSubject: Re: Craftsman LT4000 off road /mud build   Sun Jan 14, 2018 4:49 pm
Did some work on it today and i had done a few odds and ends over the last couple of weeks .Put the 930 in it and it has a few shifting linkage problems
This is in 6th gear position , and halfway down the tranny case.( trans shifter plate is in 6th gear position)
Different angle of same thing.
This is in reverse position .
Also put in a clutch, not fully hooked up but pretty close.
Stole the mud lites from the murray cause its not going to need them for awhile
Forum Rep : 125
PostSubject: Re: Craftsman LT4000 off road /mud build   Sun Jan 14, 2018 9:34 pm
That is one heavy duty clutch you built there. Looks good!
Forum Rep : 45
PostSubject: Re: Craftsman LT4000 off road /mud build   Sun Jan 14, 2018 11:47 pm
She looks mean with those mudlights! Clutch should hold up nice. Hardest thing about them is getting the pivot right. It's a bit hard to design them to keep the slop out of them for the long term.
Forum Rep : 36
PostSubject: Re: Craftsman LT4000 off road /mud build   Mon Jan 15, 2018 12:14 pm
I made it so it has a replaceable pivot plate thats roughly 2.5 by 2.5 inch plate that makes full contact so theres not any slop , i just put some grease on the plates so it shouldn't wear much.
Got the shifter figured out, and i like this style way better because its simple to work on and out of the way so branches and brush wouln't catch it like it would normally being on the fender.
Forum Rep : 6
PostSubject: Re: Craftsman LT4000 off road /mud build   Mon Jan 15, 2018 3:28 pm
What size tubing did you use on the front axle? Did you throw away the stock one totally?
Forum Rep : 36
PostSubject: Re: Craftsman LT4000 off road /mud build   Mon Jan 15, 2018 5:52 pm
It was one and a half inch tube,   3/16" wall thickness. i used the stock one on my murray
Wired it up finally , probably the cleanest job i have done on wiring . Dual batterys and the whole nine yards.
Forum Rep : 45
PostSubject: Re: Craftsman LT4000 off road /mud build   Mon Jan 15, 2018 6:05 pm
Dual batteries are nice, had a dual battery setup on mutt once. Cranked her over great. Dash tower you made looks good and sturdy too.
Forum Rep : 36
PostSubject: Re: Craftsman LT4000 off road /mud build   Mon Jan 15, 2018 8:37 pm
It better be sturdy! i dont want to redo it lol.
Not too much left till this thing will drive now, just needs front end work , steering rod, belt keepers, gas tank install with fuel line , and mufflers.
Forum Rep : 45
PostSubject: Re: Craftsman LT4000 off road /mud build   Mon Jan 15, 2018 8:50 pm
Don't need no mufflers. lol!
PostSubject: Re: Craftsman LT4000 off road /mud build   Mon Jan 15, 2018 8:52 pm
I'm building mufflers for mine I think, ain't sure yet
check out my builds
mini deuce
and my youtube channel
Forum Rep : 36
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 9:44 am
Most likely it will be straight piped , but i have not ever had a quite mower so i might want some peaceful mudding and riding .
it runs and technically drives but it might need some steering so i dont drive in a straight line into stuff lol
Forum Rep : 6
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 2:55 pm
Can you take a pic of how the starter is mounted on that mower when you get some time, Id like to get a better understanding since I bought one like it without one.
Forum Rep : 18
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 4:51 pm
I think it needs mufflers! makes a huge difference.
Forum Rep : 125
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 5:23 pm
If you are talking about the opposed Briggs, it's just 2 bolts.  One under the flywheel and one not. Might need to rotate flywheel to work that under bolt in or take flywheel off, but put it back on before tightening 2 bolts. Wire goes opposite the battery post on the solenoid.  But there are several wiring diagrams out there and in the forums for that.
Master
Master
Forum Rep : 25
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 5:26 pm
The fan on top of the motor shroud, is that original or did you put that on there?
Forum Rep : 125
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 5:51 pm
I have one of those, mine came off a horizontal with flywheel side PTO. I'll let biggasmowers give his source.
Master
Master
Forum Rep : 25
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 5:56 pm
OK, nice little upgrade for the cooling of the engine.
Forum Rep : 45
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 6:16 pm
I have the same fan from a horizontal. Would put it on Mutt's oppy but I don't wanna change to the metal cooling fin flywheel
Forum Rep : 36
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 10:29 pm
Mightyraze said it basically , i will post a pic next time i have the engine shroud off. But the starters are a pain to get off but it is possible to take them off /put on without removing the flywheel. If your engine does not have a starter and is not mechanically sound,i would just look for a mtd style mower and pull a good engine off of one of those because those mowers are not worth much and are easy to get cheaply and most likely have oppys on them.
Prancstaman , Yes the fans are off of horizontal oppys, i took it off now because it would cool the engine down way too much in this 3 degree weather lol
Page 1 of 8Go to page : 1, 2, 3, 4, 5, 6, 7, 8  Next
» Murray Off-Road Mower Build
» craftsman lt4000 rear end switch
» craftsman lt4000
» LT4000 Craftsman
» MTD off-road romper build.
