 Craftsman LT4000 off road /mud build
Go to page : Previous  1, 2, 3, ... 9, 10, 11  Next
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 10:29 pm
@mrshaft696 wrote:
Can you take a pic of how the starter is mounted on that mower when you get some time, Id like to get a better understanding since I bought one like it without one.
Mightyraze said it basically , i will post a pic next time i have the engine shroud off. But the starters are a pain to get off but it is possible to take them off /put on without removing the flywheel. If your engine does not have a starter and is not mechanically sound,i would just look for a mtd style mower and pull a good engine off of one of those because those mowers are not worth much and are easy to get cheaply and most likely have oppys on them.
Prancstaman , Yes the fans are off of horizontal oppys, i took it off now because it would cool the engine down way too much in this 3 degree weather lol
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 10:40 pm
Well did more stuff on it today. Needs one more belt keeper , fuel line , gas pedal cable,drag link, and lots of weld clean up and painting.
ran out of flux core so i had to stick weld it and some( as in all) of the welds look like a woodpecker went over them .
Made a tie rod after i put some angle on the spindles for better steering.
Messy homemade stuff onfor steering but it is pretty strong so i am fine with it for now.
Got some more joints off of a golf cart so when i get a better 1/2" drill bit i can make a drag link and drive it finally.
Forum Rep : 22
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 10:56 pm
Better clear out them bird's nests, dude!
Seriously though, great job there.  You have front breaks?  That'd be useful...for some burnouts!!!
Forum Rep : 112
PostSubject: Re: Craftsman LT4000 off road /mud build   Tue Jan 16, 2018 11:11 pm
Steering knuckles look nice and heavy.
Success doesn't happen to all of us, if it did they'd change it believe me - Red Green
                             Tourque it 'til it breaks, then back it off a quarter turn!
        Stuff I've Welded Together
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        - Lawn Tractor Utility Trailer
Forum Rep : 6
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Jan 17, 2018 7:13 am
Thanks mine is just missing the part so I was trying to figure out where/how it mounted. Also I noticed that if I save my pics in a different program like paint or photoshop before I upload them, they don't go sideways.
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Jan 17, 2018 9:17 am
Yep , that was the intention ! the birds musta sat a long time on this mower lol they left their mark all wherever i welded for some reason.( i did take the pic before i knocked off slag on the front hub so it does look a bit better, but not much
Alliskid21, Thanks ! i didnt want to bend them while driving so i used some quarter inch angle instead of plate.
mrshaft69, i never notice when my pics are sideways , i will try to post them the right way next time.( the starter mounts under the flywheel edge on the cylinder that is higher up on the engine block, there should be a place where blower shroud is missing and that where the starter fits.
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Jan 17, 2018 7:56 pm
Took it for its first test drive Cool ! Sad to say that in its unrefined condition it rides and handles better than my murray. goes about 14 mph at a high idle( just taking it easy) so i might hit 26 or so mph wide open . Also starts very well and cranks effortlessly . bounce
Here are some starter pics for ya @mrshaft696.
Tried to make them right side up but once i upload them they flip....
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Jan 17, 2018 7:59 pm
Looks good man. And I hate oppy starters, then again the one on this vanguard is a bit to get off to lol
check out my builds
mini deuce
and my youtube channel
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Jan 17, 2018 8:43 pm
Thanks! yeah those buggers are a design flaw, oh and the carbs , other than that they are very good and durable engines i think. i mean, i only have four of 'em.
PostSubject: Re: Craftsman LT4000 off road /mud build   Wed Jan 17, 2018 10:49 pm
I think I had 7 Briggs and a Kohler at one time, lol
check out my builds
mini deuce
Forum Rep : 6
PostSubject: Re: Craftsman LT4000 off road /mud build   Thu Jan 18, 2018 7:33 am
Thanks for the shot, mower looks good, nice and low & big tires.
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Craftsman LT4000 off road /mud build   Thu Jan 18, 2018 7:48 am
Looks good, as tough looking as that front axle is and the steering tower.  That thing should be SOLID!
Progress:   ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Thu Jan 18, 2018 9:15 am
Yeah the weak link will be the steering rack and pinion, i just stole it off of a murray pan frame. but it does not do that bad for being a stock design
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Thu Jan 18, 2018 5:46 pm
Took it on a drive and found some snow! either it needs a locked rear or a flexible front . I think it handled my abuse rather well , did not break anything for once but found a few things that need attention.
Forum Rep : 22
PostSubject: Re: Craftsman LT4000 off road /mud build   Thu Jan 18, 2018 6:18 pm
Great! Did you film it?
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Thu Jan 18, 2018 6:57 pm
Sure did! i will post it when i am somewhere with better wifi.
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Fri Jan 19, 2018 6:40 pm
First mud romp! The more i drive this machine the more i love it .Videos will be posted on Monday, i think i have around 2 hrs of footage to go through.
Forum Rep : 22
PostSubject: Re: Craftsman LT4000 off road /mud build   Fri Jan 19, 2018 7:09 pm
Our dogs look similar.
Great job, can't wait to see the footage.  Do you have good editing software?
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Fri Jan 19, 2018 7:21 pm
I use windows video editor, pretty good for free i think. The footage is less shaky than the murray video cause i bungeed the mount to the frame and welded some more bracing on the pole.
What breed are your dogs? My lil girl is a german shepard .
Forum Rep : 22
PostSubject: Re: Craftsman LT4000 off road /mud build   Fri Jan 19, 2018 7:27 pm
He's a german shepard/blue heeler.
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Craftsman LT4000 off road /mud build   Fri Jan 19, 2018 11:15 pm
Looks good biggassmowers! fun looking ride!
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Sat Jan 20, 2018 9:32 am
Thanks! yeah i played in mud, dirt, sand, ice, water and snow all in one romp!
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Craftsman LT4000 off road /mud build   Sat Jan 20, 2018 7:44 pm
The double trifecta!
Forum Rep : 51
PostSubject: Re: Craftsman LT4000 off road /mud build   Sat Jan 20, 2018 7:51 pm
Wouldn't mind some sand to play in, but I know it's abrasive as hell on your parts, especially wear surfaces. Can't wait for the vids!
Forum Rep : 46
PostSubject: Re: Craftsman LT4000 off road /mud build   Sat Jan 20, 2018 8:19 pm
Yeah the vids will be posted when i am at college, our wifi at home can't handle uploading a 45 second video .
Put on a bumper and hooked up the stock headlghts .
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Craftsman LT4000 off road /mud build   Sat Jan 20, 2018 8:30 pm
Does your tires hit the bumper or does it stick out far enough?  Looks good.  Good to see some other Craftsman's in the forums and not just a bunch of Murrays. (this from someone with 2 Murray's
Page 2 of 11Go to page : Previous  1, 2, 3, ... 9, 10, 11  Next
