 Mightyraze's Kal-El [2018 Build-Off Entry]
Go to page : 1, 2, 3 ... 8 ... 16  Next
Forum Rep : 129
PostSubject: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 12:00 am
2018 Project KAL-EL
Here is the tractor when I saved it from my in-laws field.
My plan is to build a Rally Tractor with mild front suspension.
*Peerless 2300 series LOCKED
*Looking into possibly 3 link front suspension.
*Small shocks for the axle
*New Treads front and Back
*New lighting, still winging that one.
*Installing 18HP Opposed Briggs
*Building front offroad bumper
Hopes:
*wench
*maybe a skid plate of sorts.
* and more...
-Approved by Doug, 2/1/2018
Progress:   ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Forum Rep : 18
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 12:19 am
So hyped for this entry. I been wanting to see a proper rally tractor so bad for a while, I've even considered building one. Maybe I will do something like that with the lt4000. Good luck!
Forum Rep : 129
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 12:20 am
Thanks man, got my front tires in today. I'll get them mounted and need to start on my front axle first.
Forum Rep : 18
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 7:12 am
Yeah, now you won't have mis-matching tread on the front!.
Forum Rep : 36
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 9:26 am
Good luck! Kinda hard to read your sign but I'm sure all the info is there lol
i will be posting the entry info and a pic of my parts pile after i get home from school , cant wait to finally enter after observing for a couple years!
Forum Rep : 129
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 9:56 am
Just so there isn't any confusion from the upload shrinking the image above to 800x600 even though I told it to keep actual size.  Here it is again (zoomed)
I could not sleep last night.  I've had a bit of insomnia for a few weeks.  So I installed the new tires on the rims I had.  These are 20x7x8 on an 8x7 rim to make them look beefier!
I am really hoping to knock the sleep issue soon.
Forum Rep : 36
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 9:57 am
What is the brand of the tires? are they sunf?
Forum Rep : 129
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 10:00 am
Yeah the fronts are. They weren't too bad to install. They also seemed to be pretty good quality and for once got a set of UNWARPED tires. Easiest tire to set the bead that I think I have ever installed even though I put them on a wider rim than recommended.
Forum Rep : 94
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 10:05 am
Should be sweet mighty! Can't wait to see your suspension take shape.
Success doesn't happen to all of us, if it did they'd change it believe me - Red Green
                             Tourque it 'til it breaks, then back it off a quarter turn!
        Stuff I've Welded Together
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        - Lawn Tractor Utility Trailer
Forum Rep : 129
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 10:16 am
I plan on clearing out the space around the rig this weekend and start mocking up my preferred axle to work with. should that not work out, I may dig out my old craftsman one that I took off the squatch last year. I need to see if my 4on4 hubs will work with the spindles that are on it now.
Forum Rep : 36
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 11:55 am
Cool. I also plan on putting suspension on my build , so i dont break my neck after i pop wheelies
Forum Rep : 129
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 12:39 pm
HAHA, wheelies, I do not plan on breaking off my spindle this year!
Forum Rep : 36
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 12:47 pm
Awe! why not?
So how do i enter ? can i use my pre build thread or do i need to start a new thread?
Forum Rep : 129
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 12:52 pm
I would start a new thread in the build-off entries section and post your sign with what you have. Best to start a new one. I am leaving my pre-build thread alone for now.
I'm sure you seen it but the password and instructions here.
http://www.atltf.com/t5619-ready-set-build-entry-instructions-and-password-here
Forum Rep : 36
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 1:01 pm
Ok thanks! thats what i will do then ,.
Yeah i have been over the rules quite a bit lol
Forum Rep : 129
This build, unless I get a wild hair up my rump, I will take my time and hopefull do it right the first time.  My hope is this will become my Primary machine.  I am 2-3 items shy of having Red Complete.  My hopes is to make it a "Friend" rider.  Basically have a machine a friend and I can go riding.  Kal, will have a more powerful engine and way sturdier frame and transaxle.  Not to mention the HUGE tires.  The fronts could be rear tires on all my other machines at 20" height!
I'm pretty excited to build it. I hope to have some good ideas to fab up along the way that I have not mentioned!
Forum Rep : 36
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 1:05 pm
Sounds like a good plan to me ! I am just building mine to have fun and hoping to make it in the top three by just having a fun machine that is well built but unique enough to grab some first time entry votes lol
Master
Master
Forum Rep : 25
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 8:10 pm
Kal-el, Nice. You know it's going to be strong if it's the man of steel.
Webmaster
Webmaster
Forum Rep : 31
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Thu Feb 01, 2018 9:00 pm
My Murray is gonna be cooler though. Sorry.
2018 Build Off Entry Commissionaire - Have a question? Ask me! Type in "@Doug" in your post!
Administrators: @Doug, @"Doc Sprocket", @Stretch44875
Moderators: @MightyRaze, @TheRainbowBoxer, @AllisKidD21
Forum Rep : 129
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Fri Feb 02, 2018 12:08 am
LOL, I don't see it entered!
Forum Rep : 18
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Fri Feb 02, 2018 9:43 am
LOL, nah he's waiting for 2020 to enter it!
Webmaster
Webmaster
Forum Rep : 31
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Fri Feb 02, 2018 5:41 pm
Gotta give myself time to prepare lol.
Forum Rep : 36
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sat Feb 03, 2018 9:13 am
Is that enough time for @doug to finish something? lol
Webmaster
Webmaster
Forum Rep : 31
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sat Feb 03, 2018 5:52 pm
If its to beat Jerry, then yea it should be lol.
Forum Rep : 129
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sat Feb 03, 2018 9:46 pm
LOL, @Doug is turning the tables on me and keeping me busy!  LOL
Did a little engine work today.
Urgh.... upside down image.  need to fix.
EDIT: Fixed.
Page 1 of 16Go to page : 1, 2, 3 ... 8 ... 16  Next
» tater's Ford XXLT18 [2018 Build-Off Entry]
» ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry]
» SUPER B - 60 MPH FIELD TRACTOR [2016 Build-Off Entry]
» Mightyraze's "Sasquatch II" [2017 Build-Off Entry] [Finalist]
» 2015 Build off entry - craftsman t-bucket roadster
