| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
Buck Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 4th 2018, 12:41 pm | |
| - mightyraze wrote:
- Buck Mault wrote:
- Are you going to be putting a track bar on it
Yeah, that is what the tab on top is for. I have a spot on the frame to attach the other end. Nice, i can wait to see how it turns out, its intresting idea, my plan was to do a 3 link on mine | |
Age : 49 Join date : 2016-09-06 Points : 14947 Posts : 10556 Location : Oklahoma
Age : 25 Join date : 2016-07-10 Points : 8350 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 4th 2018, 1:25 pm | |
| The red looks nice. Is that gonna be the final colour or is it just a rust preventative for now? Also we gotta see some flex pictures!! Haha "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4693 Posts : 1944 Location : Kansas
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3324 Posts : 825 Location : In the shop
Age : 22 Join date : 2018-02-27 Points : 3609 Posts : 1299
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 4th 2018, 7:25 pm | |
| I'm hoping it lasts.
I was planning on reversing the engine, but now I do not think I want to or need to. I have started some minor steering stuff. I need to clean up the gears and repaint. I also need to create a new drag link. I may need a couple bushings for in the frame. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 6th 2018, 11:54 pm | |
| So I have Kal up on it's hind end again. Doing some planning on the steering. Cut my yellow link at the blue X, Add another brace where the green is. I have a round barrel that I can press in 5/8 bearings that I plan to run a pin through. I will have on the bottom the linkages for the tie rods. On the top part I will have a removable shaft that will attach via a pin for the steering link to attach. It would make a lot more sense when I get it set up. | |
Crazy_Carl Veteran Member
Age : 34 Join date : 2017-10-30 Points : 5095 Posts : 2560 Location : Rochester, New York
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5476 Posts : 1398 Location : Central PA
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 7th 2018, 12:07 pm | |
| Are you going to use two tie rods going to the spindles or one continuous one? If you use two for the style of bell crank you're using the placement of it will affect ackerman angles so take that into big consideration. As the bell crank turns it effectively shortens the overall tie rod length. This toes in the inside tire when you're turning which is great for proper handling, but you don't want too little or too much ackerman either. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 7th 2018, 4:34 pm | |
| Red's MTD is a great reference point, mr.modified did a 1-link on his Simplicity as well but due the the Photobucket issue his Simplicity thread has no picture. Coils and shocks like Red had would be a great option for a flexy solid axle front end as opposed to coilovers that are designed for an IFS setup, but either way works. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 21 Join date : 2016-10-29 Points : 6505 Posts : 3564 Location : Lewisburg, KY
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 10th 2018, 9:49 pm | |
| Sweet! I've been lucky; Mutt, Orion, and my LT16 all have nice rubber seats. Have a few of the other foam ones though, and two of them are still in good condition. The one that isn't is a high back(on the mtd Craftsman) and I just cant change that out | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 11th 2018, 7:17 am | |
| @MightyRaze You should have bought a lotto ticket while you were out since you’re so lucky. We all gripe about TSC prices alot but they have a great clearance section,”stock your shop” deals, occasionally you find something marked down like your seat, and of course you might see a cute cashier too.. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 13th 2018, 11:08 pm | |
| Got a little done tonight. Got the topside part complete for the steering arm, and wrapping up for the tie rod side as well, I did end up getting it about 1.5 inches short. That should be a fairly easy fix. Ended up mounting my barrel for my pivot to the front brace behind the axle.
I am hoping to have Kal on 4 wheels by the end of this up coming weekend I hope. Then my build should start kicking into gear, depending on weather and temperature. Looks like we are starting that upward climb into spring here in OK.
