 Mightyraze's Kal-El [2018 Build-Off Entry]
Go to page : Previous  1 ... 11 ... 18, 19, 20  Next
Trial Administrator
Trial Administrator
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 07, 2018 1:31 pm
@AllisKidD21 wrote:
No he didn't, but I assumed when you said "test run" you meant run of the engine. Haha, either way. Let's keep the thread on track. Sounds good with those open pipes Mighty!
Thanks.  Only the 3rd time I have ran the engine since I bought it off a dude in Tulsa for $30 a year ago.  He had it in a plastic tub.  I still call it the "Briggs in a Bucket" engine.
It was missing one engine tin, unfortunately was the one with the model and type stamped in it. I ended up using some tins that I had lying around that did not have the exhaust swoop in the front.
Forum Rep : 113
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 07, 2018 1:41 pm
"Briggs in a Bucket", hehe. That's a good one. $30 is a screaming deal for that good ol' opposed!
Success doesn't happen to all of us, if it did they'd change it believe me - Red Green
                             Tourque it 'til it breaks, then back it off a quarter turn!
        Stuff I've Welded Together
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        - Lawn Tractor Utility Trailer
Forum Rep : 41
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 07, 2018 1:46 pm
So do you have any idea the displacement and power output?
Forum Rep : 113
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 07, 2018 1:49 pm
It's an 18hp unit so it'll be 42 cubes.
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 07, 2018 1:58 pm
What AK said. Very Happy
Progress:   ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Forum Rep : 8
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Tue May 08, 2018 8:20 am
the Engine runs pretty well. You need a gas pedal.
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Tue May 08, 2018 9:13 am
i'll get there. Smile
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Fri May 11, 2018 7:29 pm
Update later tonight!
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Fri May 11, 2018 11:01 pm
For your viewing pleasure.
I still need a thrust washer and caps for the front wheels. Also grease them. Then I will be ready to get after it. Also need to work on getting a foot throttle and start on my front bumper.
Forum Rep : 54
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Fri May 11, 2018 11:54 pm
Looks really good Mighty! Wish the oppy in Mutt would run that well...
Buck Mault
Forum Rep : 2
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sat May 12, 2018 5:11 pm
sounds nice
Forum Rep : 46
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sat May 12, 2018 10:20 pm
The motor sounds really good and I actually saw the suspension travel a little bit.
Forum Rep : 8
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sun May 13, 2018 6:33 am
Why Mutt's Engine do'nt run well? AFAIK it burns a bit of Oil, because it were out faster ungoverned, like you run your engine. But still good Compression.
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sun May 13, 2018 9:06 pm
I take it where I hit the hole in the yard.  It was a smooth ride through there.  Although I didn't have my hood bolted down yet.  It rattled all over the place.  LOL
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sun May 13, 2018 9:55 pm
started a bumper.  please ignore the splattery welds.  Got new sticks but having trouble dialing them in to not burn too hot.  They are the same as my old ones, but a different brand.  What are your favorite brands for ARC welding?  The old craftsman welder is not liking Hobart. Wish I knew what brand the others were.
Forum Rep : 35
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sun May 13, 2018 10:47 pm
Can't remember what brand sticks I've been using with our stick welder. I hardly ever use it. I think they were firepower, but it was an older box and I think firepower brand got bought out by someone since then. So not sure of the quality now.
I stay away from firepower brand stuff since I got a couple rolls of .030 flux core wire that didn't seem to have any flux in it at all. Think they had been labeled wrong.
***Simplicity Racing Team*** #64 Question? Feel free to PM!
Simplicity Adventure Edition
Diesel Submarine Project
Baja Sears Suburban
Modified Briggs Model 5s
ATLTF.COM Race Truck
Forum Rep : 113
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sun May 13, 2018 10:57 pm
I really like that bumper so far Mighty! I bet it'll look real nice on ol' Kal. You're putting a winch on this one too correct? Looks to be a good amount of room on that bumper for one.
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Sun May 13, 2018 11:07 pm
Good to know.  I have not seen that brand around.
Thanks.  I'm not done by far.... we'll see.
Also, doing some googling.  The ones I was using look like Lincoln sticks.
Forum Rep : 46
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 14, 2018 7:21 am
I swear by lincoln rod and products.
Forum Rep : 19
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 14, 2018 11:29 am
That bumper looks sweet! You need a winch.
Online
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 14, 2018 1:55 pm
You mean like this??
Twisted Evil Twisted Evil Twisted Evil
Forum Rep : 8
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 14, 2018 2:31 pm
Nice!!!! Need to do my Front bumper also in the next time. Got a dent from offroading in the grill now, if i had the front bunper, that had'nt happened.
Forum Rep : 113
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 14, 2018 3:13 pm
Oh yeah, that's looking great Mighty!
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 14, 2018 7:27 pm
I forgot to account for my led's.  I think I may end up going with 1.  They are so bright, that is all I need anyways.  LOL
Forum Rep : 28
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 14, 2018 7:29 pm
Bumper looks good Mighty! The winch looks nice in there.
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: Mightyraze's Kal-El [2018 Build-Off Entry]    Mon May 14, 2018 7:30 pm
Thanks, going to move to the foot throttle while I have the hood off.
Page 19 of 20Go to page : Previous  1 ... 11 ... 18, 19, 20  Next
