| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
mrshaft696 Established Member
Age : 48 Join date : 2016-09-06 Points : 14921 Posts : 10540 Location : Oklahoma
Join date : 2016-07-10 Points : 3812 Posts : 870 Location : Phillydelphia
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 8th 2018, 3:19 pm | |
| I did clean the block itself with a brush to check for oil leaks after changing out some gaskets. The tins, I have repainted 2 times since I got the engine. It has 1 leak and that is the oil plug cap itself. I plan on replacing when I change oil before installing on the frame. I would like to get it running one more time before I get it installed. Just need some gas line and fuel cutoff and filter. But those are easy purchases. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 10th 2018, 1:42 am | |
| Been doing a lot of mental planning and prepping the past week. I have come across a couple hurdles that I need to figure out. 1) The dash supports will be in the way, will need to relocate them. Should not be too bad. 2) I need to see if I still have some old OPPY head tins. The ones on this engine have that part to deflect muffler heat from the intake. For my build, that isn't really needed for my setup and it is in the way. If I do not have my old tins, I guess I will need to trim these up to fit. The part mentioned is the part circled in green. I will see if it is absolutely needed to be removed, before trimming. | |
Dave 007 Member
2017 Build-Off Top 3 Winner
Age : 59 Join date : 2017-02-02 Points : 2734 Posts : 115 Location : Australia
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 13th 2018, 11:42 am | |
| I have some stuff laid out now to do some building again. I hope to start working the front end a bit. I would like to get it sitting without jack stands and get the motor moved over to the frame. Once the motor is on the frame, I can start redoing the dash supports and then start working on a final steering solution. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 13th 2018, 9:24 pm | |
| I was doing some suspension planning. This is by no way where this link will be attached. And I have the lock nut on the wrong side. Biggest thing i was looking at was will it get in the way of steering. I do not think so.
Last edited by mightyraze on February 14th 2018, 8:00 pm; edited 1 time in total | |
Age : 21 Join date : 2016-10-29 Points : 6476 Posts : 3549 Location : Lewisburg, KY
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 14th 2018, 8:06 pm | |
| LOL, I am hoping this will be my new PRIMARY working machine. I hope to maybe hand down Red and see if I can get the Wife involved in playing. Definitely not working on this one with the feverish pace as last year where I was done by July 4. I do hope to finish Sept while it is still warm out for my completion video. I would like to get the front axle attached this weekend, but the weather is not cooperating. It was like 75 today and going to be around 83 tomorrow. Saturday is like 32-33 and snow possibilities. Ugh, 3rd week in a row this has happens. Too bad my weekday evenings are booked up. | |
Age : 25 Join date : 2016-07-10 Points : 8340 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 14th 2018, 8:13 pm | |
| Do you have three of those 3pth center links mighty? If so that'd be nice, I imagine they'd be plenty heavy enough. The middle link would have to be shortened as well, but that wouldn't be too hard to do. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 14th 2018, 8:22 pm | |
| Ah, I see. The adjustability will be nice to have, that way you can set your axle caster. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4683 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 15th 2018, 8:47 am | |
| Those and a seat hopefully are the biggest $$ items I have to put into the build. I believe they were $20 at Tractor Supply. The link I did not get was about $34?! and it was just 3 inches shorter. Go figure. They had cheaper, but I liked these because of the jam nut. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 15th 2018, 11:54 pm | |
| Minor update, got the the pulleys for the clutch today. That flat idler seems smaller than 5/8 bore for my reducer. Freezing them for insertion tomorrow. All I need now is the engine pulley. I am still debating between a 6 and a 7 inch pulley. I'm leaning 7. The new pulleys are the exact same size as the old. Angle is an illusion on the flat idler. | |
Crazy_Carl Veteran Member
Age : 34 Join date : 2017-10-30 Points : 5085 Posts : 2560 Location : Rochester, New York
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 18th 2018, 9:24 pm | |
| Well I got some work done today.. Ran over to the TSC and got my 3rd link. Didn't realize that one of my long links was a different grade than the others. Oh well. Also got me one piece of square tube. Made me up a bracket for the shocks. Here is her stance. A little nose up without the engine. I expect the same. I think it will be pretty cool looking! Stood the frame up on it's rear to weld on some link ears to the bottom. Making some mounts on the front axle for the links. Still have the center and the panhard mount to go on both the mower and the axle. Mower side mounts. Now i am sore.... LOL | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] February 18th 2018, 9:29 pm | |
| Aw yeah, suspension stuff!! Haha, looks good mighty! Gonna have to make the axle center link mount stick up from the axle a little bit maybe when you go to make it. Hope your back feels better as well. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5465 Posts : 1398 Location : Central PA
