| "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] | |
+14RichieRichOverdrive mrshaft696 TheBeal Dave 007 Doug muddstir CraftsmanQuad19 RCG Crazy_Carl AllisKidD21 biggasmowers muckmudd MightyRaze Double W Cross Ranch 18 posters |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 3rd 2018, 1:34 pm | |
| Okay, so I'll give ya'll some pictures so you can have an idea of what it is we are talking about. Here's the bad spindle mount on the one that's installed right now: Here's the good side: They both have a ton of play. Here's the axle I would install: The spindles mounts on this one are just pipes welded on, not like the stock one. They have minimal play. To get it to fit, I'd have to trim that pipe that sticks through the center and drill a bigger hole for the pivot bolt. Should be able to do that, probably gonna be my solution to the issue. | |
Age : 25 Join date : 2016-07-10 Points : 8340 Posts : 5190 Location : Ontario Canada
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 3rd 2018, 1:44 pm | |
| Yeah that's definitely not a cast axle, but it does looks like a good axle! I would swap it in for sure. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5245 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 3rd 2018, 1:47 pm | |
| Okay, yeah I was wondering if it wasn't. If it wasn't for the very nice welds on it, I'd think that from the style it'd be homemade. I'll get to swapping that later. Thanks for the advice! | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 3rd 2018, 4:04 pm | |
| Okay, got the front axle swapped. Steering and all stays the same, and I kept the stock spindles. I was lucky enough that I didn't have to trim the axle pivot thing; I just flipped on of the mounts backwards. Have to trim part of a mount to get the tie rod to fit, but that's not a big deal. | |
Dave 007 Member
2017 Build-Off Top 3 Winner
Age : 59 Join date : 2017-02-02 Points : 2734 Posts : 115 Location : Australia
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 17th 2018, 7:03 pm | |
| - Dave 007 wrote:
- Good luck and best wishes, very happy to see your entry. cheers.
Thanks @Dave_007
Last edited by Double W Cross Ranch on February 26th 2018, 1:03 pm; edited 2 times in total | |
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4683 Posts : 1944 Location : Kansas
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 18th 2018, 5:33 pm | |
| - biggasmowers wrote:
- Hows everything going ? Haven't heard anything about this for awhile.
Everything's going well, got the tranny mounted but can't show public pics because it would show the suspension deal in the rear. The front axle swap I did isn't gonna work, it's too long so I have to put the stock one back in. Need to get the rear pulley hub welded to the pulley. Haven't had much time lately, the sheep are lambing, I've started to clear some land, etc. That's why I was offline for a while if you noticed. Thanks for asking though! | |
Crazy_Carl Veteran Member
Age : 34 Join date : 2017-10-30 Points : 5085 Posts : 2560 Location : Rochester, New York
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3314 Posts : 825 Location : In the shop
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 24th 2018, 10:34 am | |
| Okay, so big update. The front axle I think is going to work after all. I need a new tie rod, though. While I'm at it, I am doing front suspension for this build. The rear suspension is practically done, just need to finish one part on it. The fenders...I've decided I'm not going to swap them. The stock ones aren't that bad...I just hate this lip (pictured below) and how high up you sit. At the very least, I'm going to cut the fenders where they meet the floorboards and lower them. A couple of ya'll asked about steering. Going to keep the steering stock, I have the gen 2 steering in NellyBelle. The WeedEater has the gen 1 steering in it, and I absolutely hate it! It is hard to turn, when it hits full travel it makes this spine-chilling popping noise...but the gen 1 is like butter, absolutely love it!! Rack or no rack? Not much storage space on this build, thinking of getting a rack. I don't personally mind them, but some people say that they look bad. Give me your thoughts, please! Need some fender flares. Since I am lowering my fenders and putting rear suspension on, I have to trim them substantially so when it maxes out the tires don't scrape. Going to do what Fearless did, with the lawn edging. Bumper. She needs a bumper. I do not have a welder to build one, so I was planning on buying one. How does this one look? I'd put my old, rat-rod style license plate on the grey part in front. Transaxle will be a five speed Peerless 920 oil filled. Need to paint the case on it, then get a new shifter detent. (BTW, I did not do the noob thing of letting it fly out at me. I pulled it out, set it to the side...and lost it. ) Pulley swap will be a 3 1/2 inch in the back, and a six inch in the front. That, coupled with no gov, a mikuni carb, and 4" oversized on tires should get me about 30, which is what I'm going for. Rear tires, Mud Lites. Ya'll already know that. Fronts, thinking of these ags I found at Home Base Lumber. They are 16"s, and are $20 a piece (the main reason I think I'm using them, ). Any other tips or ideas? Lemme know, really want this build to be something special!!! | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 24th 2018, 11:09 am | |
| Do you know what the 5th speed gear ratio is in a peerless 920. I will calculate your top speed for you.
I'd use a commercial truck mud flap for your fender flares. According to Doc it's a better material and I'm around them a lot at work and I affirm that.
How are you going to build front suspension without a welder? Your rear suspension is simple so I can see how you got away without it there.
Definitely chop the rear fenders and lower them. That will give you a lower center of gravity and unique body lines to set your tractor apart from the rest.
Yes on the bumper, but you should paint it. | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 24th 2018, 11:13 am | |
| - Crazy_Carl wrote:
- Do you know what the 5th speed gear ratio is in a peerless 920. I will calculate your top speed for you.
Yes on the bumper, but you should paint it. How can you tell what kind of suspension he has. He barely showed anything. And you are completely right about it prettl much being impossible to make front suspension without a welder. | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 24th 2018, 11:26 am | |
Yes on the bumper, but you should paint it. Okay, so in fifth it's a 9:1 ratio. Okay, I'll look for some truck fender flares. front suspension without a welder? Was just gonna cut a hole in the top of the axle, drill some holes in the side, and slip the shock into it and bolt it in. Then remove the pivot bolt and bolt the other end to something, shouldn't be to hard to find something to bolt it to...and call it done. LOL I'm lazy, and if it works.... Okay, I'll paint the bumper. @muckmudd I showed them to him, I'll send the setup to you if you promise to be ! Oh, BTW, found this manual, super helpful! http://www.wfmfiles.com/download/Tecumseh-Peerless_Motion_Drive_System_-_Transmissions_&_Differentials(691218).pdf | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 24th 2018, 12:00 pm | |
| So with a 6" engine pulley, 3.5" trans pulley, a fifth gear with a 9:1 gear ratio which seems awfully high, 22" tires, and taking the ungoverned motor to 5000 rpm your top speed is a whopping 62 MPH!!!!! It's been nice knowing you W. I'd get your affairs in order. | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 24th 2018, 12:22 pm | |
| LOL, 62 MPH? I need to go call my life insurance agent and make sure that's covered.
JK, obviously not going to do that. I got that ratio figure from some guy on a forum somewhere else. To make sure I ran out and tested it on my tranny...and it's even worse. 8:1. Could you calculate what pulley ratio I need to go 30 MPH under those circumstances? | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 24th 2018, 1:48 pm | |
| - muckmudd wrote:
- Yes please Double W. I would be interested in seeing. But how are you going to weld up the mounts to bolt on coil overs to the axle?
IDK, I was just going to find something to bolt it to. | |
| Subject: Re: "NellyBelle" Craftsman LT1000 [2018 Build-Off Entry] February 24th 2018, 5:23 pm | |
| Again, that 8:1 gear ratio seems ludicrous but these tractors come stock with a tiny pulley on the motor and a big pulley on the trans to achieve a better reduction.
With a 4" engine pulley and 5.5" trans pulley your top speed will be 30 mph @5000 rpm, with 22" tall tires, and an 8:1 reduction through the transaxle.
Would you do me a favor and measure your actual wheel circumference with a string? Or you can just measure the actual wheel diameter if you want too.
