 Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]
bow tie mud guy
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Thu Mar 22, 2018 5:50 pm
@SebastianAlbrecht no not this one , i run on dirt oval that why the tires
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Thu Mar 22, 2018 5:55 pm
@Crazy_Carl ok cool thanks for the info , after i break in the engine it will be ungoverned along with maybe a 16 tooth on cvt and run a 54 or so on axle , the track we run has 200 foot straight away so im sure there will be a few gear changes in my future LOL
Master
Master
Forum Rep : 35
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Thu Mar 22, 2018 6:03 pm
16 tooth on the CVT and a 54 tooth on the axle means you're going about 75 mph at 5000!  You better hang on tight!
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Fri Mar 23, 2018 6:54 pm
BOUNTY HUNTER'S FIRST TEST DRIVE !!
i do not have the sprocket i want so i used a 36 tooth i took off my wife's oval racer !! bounty hunter did very well for the first drive , i have the throttle set so i cant open it wide open until i break the engine in and do the first oil change !! more videos to come
Master
Master
Forum Rep : 35
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Fri Mar 23, 2018 7:03 pm
Looks like it was going pretty quick.  You need to find a straightaway somewhere and really open her up man.
Sounds great too.
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Fri Mar 23, 2018 7:08 pm
@Crazy_Carl THANK YOU !! i have a video im loading that is on a dirt road behind my house that i use for test driving i will post it as soon as its done !! KEEP IN MIND I HAVE IT SET FOR HALF THROTTLE UNTIL ITS BROKE IN !! after that the real fun starts !!
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Fri Mar 23, 2018 7:11 pm
PART 3 OF BOUNTY HUNTERS FIRST TEST DRIVE !!
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Fri Mar 23, 2018 7:21 pm
part 4 of the first test drive
Forum Rep : 125
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Fri Mar 23, 2018 10:29 pm
The Bounty Hunter is sounding really sweet. Can't wait to see what this thing does when you have it broke in and opened up!
Progress:   ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Arrow How To Upload Pictures
Forum Rep : 36
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Sat Mar 24, 2018 9:33 am
I think the cvt at half throttle isn't at half speed , so this thing could really fly!
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Mon Mar 26, 2018 7:08 pm
made a small adjustment to the throttle and put some 98 octane in it and with these 2 things she woke up like crazy !!
Master
Master
Forum Rep : 35
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Mon Mar 26, 2018 7:37 pm
Woah the sound of that thing blew my mind!
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Tue Mar 27, 2018 12:48 am
Looks lile a lot of fun to drive! My Mower hadn't enough HP to do that, and a open diff.
Forum Rep : 125
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Tue Mar 27, 2018 11:31 am
Looks to be some real fun there.  I bet you have those bugs out in no time.
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Wed Mar 28, 2018 6:21 pm
STILL TEST AND TUNE !!
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Wed Mar 28, 2018 6:23 pm
AFTER WARM UP !!
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Wed Mar 28, 2018 6:27 pm
THIS IS THE ROAD BEHIND MY HOUSE THAT I USE FOR TEST RUNS !! STILL ONLY HALF THROTTLE ON THIS RUN , I HOPE I CAN GET TO THE POINT I CAN GIVE IT FULL THROTTLE SOME TIME NEXT WEEK , I DID FIND OUT I NEED TO INSTALL A CATCH CAN , YOU WILL SEE IN THE VIDEO
Master
Master
Forum Rep : 35
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Wed Mar 28, 2018 7:06 pm
Dude this thing totally rips!
Forum Rep : 125
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Wed Mar 28, 2018 7:12 pm
I saw those puffs of smoke. That thing is already fast and can rip it up.
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Sun Apr 01, 2018 4:32 pm
BOUNTY HUNTER UPDATE : i did not finish it in time to take it down state for paint , so i did it my self !! i really did not want a real expensive paint job for 2 reasons - #1 i would not want to drive it afterwards #2 just in case i flipped it i did not want to wreck the paint and it is possible that i will roll it over !! LOL
i tore it down but did not pull the engine , its working great where it is so i left it , redone the tie rods with 3/4 inch square tube , redone the break mount and tightened up the breaks , added turn outs to the exhaust out the left side , ground down the welds and started painting , took a day to get it ready and to paint took another day to put it all back together !! i did take it for a rip and this time i grabbed my GPS from my truck to see how fast at half throttle she really is !! not to sure how close the GPS is on a mower but she read 48MPH before i had to get out of it so i could turn !! still half throttle and i will say this - IM SCARED TO OPEN IT UP !! any ways the reason i busted my butt painting this week end is because i have to be in town at a local shop on Monday  that is talking about sponsoring me this year  for oval track , i will let every one know what happens !!
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Sun Apr 01, 2018 4:34 pm
LIL INFO !! AFTER FIRST DRIVE WITH NEW PAINT !!
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Sun Apr 01, 2018 4:43 pm
FIRST START AFTER PAINT !!
Forum Rep : 36
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Sun Apr 01, 2018 5:24 pm
paint looks great ! I like the blue accents on that black body.
Master
Master
Forum Rep : 35
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Sun Apr 01, 2018 5:38 pm
I like the color scheme a lot too.  From my calculations I know this machine is more than capable of 48mph.  I wonder  how fast full throttle will be?!
Forum Rep : 125
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Sun Apr 01, 2018 7:55 pm
First saw the new paint on FB.  This thing is looking sharp!  Got that engine broke in yet?
bow tie mud guy
Forum Rep : 2
PostSubject: Re: Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]   Mon Apr 02, 2018 7:07 am
@Crazy_Carl yes she is very capable of way more but im not sure if i will need it with the guys i race with !! none of them are moving this fast . THANKS FOR YOUR HELP !! i will do a final video before to long , i have a test and tune on april 14th maybe i can do it then !
» Bounty Hunter Tracker IV
» Bounty Hunter tracker IV questions (thanks dave)
» bounty hunter tracker 4 "IV"
» New Kenda Bounty Hunter HT SxS Tire Review
» Bounty Hunter Bounty-Tracker IV
