 Snapp Dragin RER Mudding [2018 Build-Off Entry]
Master
Master
Forum Rep : 29
PostSubject: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Thu Feb 01, 2018 3:14 pm
Here is my rear engine rider snapper build off entry .
My goal for this machine is to have it 24+MPH , Perform well in VERY muddy terrain , And pop wheelies easily .
The frame is completely stripped down to the chassis and ready for modification .
The things i plan to do/build on this Build off entry are:
Build custom axle brackets that will raise the rear end height.
Mount foote gearbox.
Extend rear frame to make room for oppy and different seat placement.
Shorten front pipe frame.
Front end suspension.
Parts in parts pile are:
Live axle with 4 on 4 hubs for golf cart rims .
Foote 3 speed gear box
Briggs and Stratton 19 HP opposed twin engine( ungoverned )
Axle bearings+hangers .
Snapper RER frame.
Golf cart tire hubs( tires are temps, i plan on itp mud lites or other aggressive tires)
Coil overs.
Brake cailiper and disk brake.
36 tooth sprocket.
Murray pan frame fenders.
-Approved by Doug, 2/1/2018
mightyraze
Forum Rep : 112
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Thu Feb 01, 2018 3:25 pm
Only been a few RER's since I have been around and non of those finished. I know you can do it, will be massive with that OPPY in there! Good Luck!
Kal-El 1982 Murray GT. . . . . . . . . . . . . . . . . . 2-39002 . . . [2018 Entry]
Progress:  ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
           0                                 50                                 100
Sasquatch II 1990 Craftsman II . . . . . . . . . . . . . 917.2559101 . [2017 Finalist]
Li'l Red Murray 1998 Murray. . . . . . . . . . . . . . . 42505x92A
[Future Project] 1974 Craftsman LT10/36  . . . 917.2552704
Arrow How To Upload Pictures
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Thu Feb 01, 2018 4:31 pm
Oh ,no warnings to say that ive done something wrong?? LOL
Thanks , yeah its a very basic build with some tweaks and additional things i will do as the build progresses . The oppy is going to be as far behind the axle as possible to help with weight distribution.
mightyraze
Forum Rep : 112
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Thu Feb 01, 2018 4:33 pm
That's up to the Admins.... Smile RER's are acceptable frame for the build-off i believe. I think Doug did one last year.  Maybe MrModified too?  I'm thinking this year now.  Smile
           0                                 50                                 100
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Thu Feb 01, 2018 4:35 pm
Yeah they are fine in the build off. ( well as long as i keep the wheels out of line lol) Theres nothing that should disqualify this one !! Razz
Last edited by biggasmowers on Thu Feb 01, 2018 4:36 pm; edited 1 time in total (Reason for editing : Edit:bad spelling lol)
Forum Rep : 12
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Thu Feb 01, 2018 8:45 pm
If you put that oppy behind the axle you're going to have a wheelie machice. I bet that's the idea but I don't think it would make a good mudder too.
Online
Webmaster
Webmaster
Forum Rep : 28
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Thu Feb 01, 2018 9:18 pm
Stretches RER has an oppy and that thing is fantastic. Im gonna steal it after Haspin one of these years.
Forum Rep : 13
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Thu Feb 01, 2018 9:56 pm
REVERSE TRIKE!!! REVERSE TRIKE!!!
please?  Neutral
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Sat Feb 03, 2018 8:58 am
Well the idea is to keep the front end light so i have basically all of my weight and the machines weight over the axle so i have good traction and i woulnt have a front end that will bog down.( it is going to have an over sized cheater bar with a big tire to prevent flipping it.)
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Sat Feb 03, 2018 9:55 am
Well the front end is shortened ! Now i need to get abut 25 ft of steel tube for the rest of the build ....
So my entry is then right?
Forum Rep : 13
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Sat Feb 03, 2018 10:28 am
You gonna keep direct steering?
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Sat Feb 03, 2018 6:50 pm
i might keep it direct but if i lift the front as planned it will need something different.
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Sun Feb 04, 2018 10:23 am
Took off the pipe pivot bracket and flipped it over and welded it to the front of the frame to give me 7 inches more of open frame for mounting the foote gearbox.
Forum Rep : 13
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Sun Feb 04, 2018 10:29 am
dude, that thing is gonna wheelie!!!
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Sun Feb 04, 2018 5:48 pm
Yeah it sure is! i have a few things i am going to do to it for some wow factor.
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Mon Feb 05, 2018 8:00 pm
Frame murderfycatin!!
From THIS,
To This!
Forum Rep : 13
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Mon Feb 05, 2018 9:26 pm
That looks good, should wheelie like craaaaaazzzzzzyyyy!!!
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Mon Feb 05, 2018 9:32 pm
Thats the idea for sure!
mightyraze
Forum Rep : 112
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Mon Feb 05, 2018 11:41 pm
Filling in the engine hole part of the extension?
           0                                 50                                 100
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Tue Feb 06, 2018 8:54 am
Well i extended the frame by putting the pipe frame bracket on the front of the frame , but the engine mounting hole was offset and i need my weight to be evenly placed in the center of the frame, so i had to fill in the old engine mounting hole to have metal to drill through for engine mounting.
mightyraze
Forum Rep : 112
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Tue Feb 06, 2018 9:08 am
I'm with you now. Original single went in sideways (offset) and the Oppy you are putting in needs centered. Sorry, so many things going on, still catching up what people are doing. Looking good!
           0                                 50                                 100
Master
Master
Forum Rep : 29
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Tue Feb 06, 2018 9:12 am
Thanks! i am going to weld/patch all of the excess holes on the frame to give it a smooth appearance and sand it to look real nice. still not sure on a color for it
If i left my oppy in the original spot i would be leaning whenever i went on soft terrain lol
Super man themed avatars eh mighty?
mightyraze
Forum Rep : 112
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Tue Feb 06, 2018 9:25 am
That will look nice. I do know Maine Mud Mower and I are going blue.
I was just jacking around with my avatar. You just happened to catch me. Smile
           0                                 50                                 100
Forum Rep : 13
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Tue Feb 06, 2018 11:07 am
@biggasmowers wrote:
Still not sure on a color for it.
Yellow!!! or a midnight black with red streaks!!!
mightyraze
Forum Rep : 112
PostSubject: Re: Snapp Dragin RER Mudding [2018 Build-Off Entry]   Tue Feb 06, 2018 12:52 pm
The thing is looking like a praying mantis, maybe green! LOL, it's up to you man! It's all good fun!
           0                                 50                                 100
» tater's Ford XXLT18 [2018 Build-Off Entry]
» ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry]
» SUPER B - 60 MPH FIELD TRACTOR [2016 Build-Off Entry]
» craftsman mud mower
» 2015 Build off entry - craftsman t-bucket roadster
