| [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] | |
+15Buck muckmudd AllisKidD21 TheBeal mrshaft696 RichieRichOverdrive SebastianAlbrecht CraftsmanQuad19 prancstaman Dave 007 Double W Cross Ranch Doug Crazy_Carl MightyRaze biggasmowers 19 posters |
Crazy_Carl Veteran Member
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4693 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 13th 2018, 9:25 pm | |
| Wow that's pretty cool! Yeah all the info is right to spec. So if I run it lower rpms I will have a good low speed and if I try 5th gear with pedal crunched down it could in theory got around 35 mph. Yikes! Got the chain and sprockets lined up and the trans chain is perfect for no slack but not too tight and if I put a half link in the drive chain it will also fit like a metal glove. I now have about 90 or so dollars in this build. (Chain,sprokets,metal,welding rod,cutting disks.) | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 14th 2018, 10:02 am | |
| Hey @Crazy_Carl , since you have such a nice speed calculator could you run some more info through it ? Same transmission ratios(2:1 for 5th gear) , 8 tooth trans sprocket, 36 tooth live axle sprocket (no jackshaft ) 45 inch circumference on the tire , and 5500 engine rpms, 7 inch engine pulley, 5.75 inch trans pulley .? Might get some more work done today but probably not, but I am going to ask a neighbor about pulling some idler sprockets and coil overs from some junk he has out back.
Last edited by biggasmowers on March 14th 2018, 10:24 am; edited 1 time in total | |
Age : 20 Join date : 2017-06-09 Points : 5255 Posts : 2640 Location : Literally Nowhere, Texas
Age : 34 Join date : 2017-10-30 Points : 5095 Posts : 2560 Location : Rochester, New York
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 14th 2018, 4:38 pm | |
| I think the tire circumference was wrong. 45 inches, instead of 69, I am thinking of this ratio on a different build, I am keeping the snapper at what it is now.
That wasn't as fast as I was hoping to go. More around 65mph....... I will look into other pulleys I guess. Or I could swap the 5.75 inch pulley with the 3.5 inch pulley on the snapper and slow down the snapper and speed up the new project racer. | |
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5476 Posts : 1398 Location : Central PA
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 14th 2018, 6:01 pm | |
| - biggasmowers wrote:
That wasn't as fast as I was hoping to go. More around 65mph....... I will look into other pulleys I guess. Or I could swap the 5.75 inch pulley with the 3.5 inch pulley on the snapper and slow down the snapper and speed up the new project racer. Uhhh... I think a name change from "Death Trap" to "Death Wish"! This looks like it will have a high CoG, that will be sketchy enough at 30mph going around a turn. Try it at 30, if that doesnt fulfill your hearts wants and desires then bump it it. | |
Age : 25 Join date : 2016-07-10 Points : 8350 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 14th 2018, 7:29 pm | |
| A trike? But.....suspension? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 14th 2018, 8:02 pm | |
| - AllisKidD21 wrote:
- A trike? But.....suspension?
You think me up a way to do single wheel suspension. , and I will build it. Go ahead and just post the diagrams in this thread lol. I want from end suspension to dampen the wheelies. It's wayy cheaper to do one wheel then two as I can get the one for 10$ verses buying some junk tires for 40 bucks a pop. | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 14th 2018, 8:04 pm | |
| You could build a Springer Front End like a custom chopper. I started building one for my chopper pedal bike forever ago but haven't touched it in a while. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 14th 2018, 8:06 pm | |
| You know how in a fanboat you sit right it front on that big v8? This kinda has that look to it. You're sitting right in front of that big oppy lol.
You can do a little swing arm on the front like an old Harley. The axle is in between the pivot point and the shock mounts. | |
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3324 Posts : 825 Location : In the shop
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] March 14th 2018, 8:24 pm | |
| Here's a Springer. You can see the rockers, push, rods, and springs. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Ah. That's pretty easy to build I would think. I will give it a try once I pick up the tire and go pull off some more coil over from some golf carts. Got permission to look over some old combines for sprockets and chain idlers. | |
