The 2018 Build Off is Almost Over!! Click Here to view 2017 results!
 MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]
Go to page : Previous  1, 2, 3, 4, 5, 6
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Mon Oct 01, 2018 7:55 am
the jack idea is really smart, dont hook up the top, that way you can dump manually most of the time and just use the jack to help get the load moving on a real big load
Online
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Mon Oct 01, 2018 9:09 pm
this is kind of how I am setting up the bed....
Forum Rep : 76
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Mon Oct 01, 2018 9:19 pm
Oh cool!
just make sure you can find a way to keep the shaft from turning in the tractor frame or else it defeats the purpose of having the bearings.
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Tue Oct 02, 2018 7:28 am
@Crazy_Carl wrote:
Oh cool!
I hear what you are saying, it will work either way, but it is best to pivot on the bearing. I have to keep the solid stock removable so I can take the bed off etc. I need to use a lynch pin or some kind of clip to keep it in place.
Forum Rep : 76
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Tue Oct 02, 2018 10:42 am
Most loaders use pins that are bolted to the loader frame after they are inserted into the other pin to keep the pin from rotating.
another easy way to do it is to grind a slot or flat onto the shaft you have . Ben bolts up a keeper play tight to that to keep the chef from rotating .
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Fri Oct 05, 2018 9:15 pm
working slowly, getting close to mounting the bed....
Forum Rep : 193
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Fri Oct 05, 2018 9:56 pm
The way you are building that, I don't think it would be hard to add an actuator to dump the bed in the future if you wanted.
Murray CCT (KAL prebuild)
Sasquatch II [2017 Finalist]
ATLTF Facebook Page
How To Upload Pictures
ATLTF Staff:
Forum Rep : 76
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Fri Oct 05, 2018 10:38 pm
Are you going to bolt the pillow blocks through the angle iron and the bed floor?
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Sat Oct 06, 2018 7:55 am
yeah the "bed floor" is basically aluminum foil, so ill bolt the steel angle to it. Will have to come up with some type of latch in the front, and keep it open ended to add a dump mechanism later.
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Sat Oct 06, 2018 9:53 pm
mocked up and tested out the dump.... works good....
Forum Rep : 76
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Sun Oct 07, 2018 1:06 pm
Looking like a ATLT crossed with a dump truck! sweet!
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Sun Oct 07, 2018 8:30 pm
Well I decided the tires im gonna use in the front, I have rims for the 4.8x4-8 AG tire like Double W did on the front of his to keep the turning easy & taller than what I have. Doing some more painting, then gonna build some running boards...
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Wed Oct 10, 2018 8:46 pm
trying to finish painting my bed, did the underside black bedliner....
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Mon Oct 15, 2018 7:48 pm
Ok the bed is finally painted and on for good...
to finish
Build some running boards
get headlights working
Get latch for holding bed down installed & working
New front AG tires
class II hitch
I think that might be it other than odds and ends, hopefully will get it done...
Forum Rep : 76
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Mon Oct 15, 2018 9:18 pm
You hadn't touched this build in so long that I was worried that you were never going to get on it again.  I'm glad you found the motivation to get it finished before the build off ends.  It's looking good.
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Tue Oct 16, 2018 7:37 am
haha this is true, I fixed and sold a ton of tractors over the summer, but after it started raining here for what it feels like for 2 months straight things slowed down & I really want it out of the garage because its long and takes up allot of space & I want to start using it.
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Wed Oct 17, 2018 8:13 am
Got the latch in the mail today and mostly set up....
Forum Rep : 76
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Thu Oct 18, 2018 10:48 am
Nice latch selection.  I like how it's easily adjusted.
Master
Master
Forum Rep : 22
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Fri Oct 19, 2018 12:12 pm
Does it hit the tires when it opens?
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Sat Oct 20, 2018 7:57 am
yeah, that was intentional, working on my running boards, post pics later....
Master
Master
Forum Rep : 22
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Sun Oct 21, 2018 3:38 pm
Personally I wouldn't have done that intentionally. I feel like sometimes the load is gonna be stuck and if you drive forward it will slide out.
Forum Rep : 14
PostSubject: Re: MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]   Yesterday at 9:10 pm
thats great...
anyway got set back on my work, my run around craftsman tractor broke another axle, these things are so weak at the weld seam I am thinking about sleeving over them or just taking a piece of flat stock and covering it up.... This one is going in the trash, but they dont hold up to much.... I know a cast iron would be best I would have to find out what would be compatible...
Page 6 of 6Go to page : Previous  1, 2, 3, 4, 5, 6
» Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]
» tater's Ford XXLT18 [2018 Build-Off Entry]
» Redzz02's Haspin Build [2018 Build-Off Entry]
» ---COMPLETE--- Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry]
