| [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] | |
+13AllisKidD21 CraftsmanQuad19 Camdg2010 MatthewD RichieRichOverdrive muckmudd Crazy_Carl mr.modified Dave 007 Double W Cross Ranch MightyRaze Doug mrshaft696 17 posters |
muckmudd Established Member
mrshaft696 Established Member
Join date : 2016-07-10 Points : 3843 Posts : 870 Location : Phillydelphia
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] August 23rd 2018, 7:35 am | |
| - CraftsmanQuad19 wrote:
- What if you put the seat at the stock distance from the dash, and where the fenders would normally go put some big ammo cans on either side, almost like saddle bags
Well what I meant was I am using the "Running Boards" (under feet) from a simplicity 4212, the piece that goes from the foot pedal to the shifter. The seat I will have to figure out but its just placed there in the picture. I might put it on the tube frame or modify the 4212 seat thing to work. I need to put the battery under the seat, I think that is the best place. There will be no fenders over the rear tires as I believe the bed will be covering them. | |
Age : 23 Join date : 2016-04-12 Points : 5740 Posts : 2617 Location : Indiana
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] August 23rd 2018, 11:05 am | |
- But since the back tires will be well behind the seat, put the ammo cans to either side of the seat, in front of or maybe slightly under the bed
yeah I could do something like that, there will be allot of real estate there. My plan this weekend is to get it back running again & deal with the shroud around the steering wheel, because that is gonna take some serious work to look good with the hood. | |
Age : 25 Join date : 2016-07-10 Points : 8371 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] August 25th 2018, 10:03 pm | |
| Hey that looks pretty good so far! Should look like it was meant to be once it's all painted up. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] August 25th 2018, 10:20 pm | |
| - AllisKidD21 wrote:
- Hey that looks pretty good so far! Should look like it was meant to be once it's all painted up.
I hope so, its one of those things you do that nobody notices unless you really point it out, but I had to do it so the hood would lock down like a simplicity. I need to get my running boards mounted , & get the engine wired to run again, then I can make my trip to start getting tube and angle....I spent all summer working on other stuff so Im trying to spend some time here because I need to use this thing before it gets cold. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5117 Posts : 2561 Location : Rochester, New York
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] August 26th 2018, 8:43 pm | |
| - Crazy_Carl wrote:
- That hood to dash transition is a lot sleeker than what I have planned for my John Deere
Hopefully you get this done to use for fall chores around you property. Should come in really handy in the springtime. Hah when i pulled the hood at the junk yard i took the whole dash too because I knew it was way different than the craftsman.. | |
Age : 20 Join date : 2017-06-09 Points : 5276 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] August 27th 2018, 1:44 pm | |
| I started sketching up what I am going to do, but basically instead of making and elaborate tube frame I am going to cut two pieces of 11ga plate & bolt/weld it to the side of the frame, then just put crossbars where I need them to mount the seat etc. It will tie in the front and back half of the frame allot better because there is a good bit of flex right now. looking something like this.... | |
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] September 1st 2018, 9:07 pm | |
| - Crazy_Carl wrote:
- Maiden voyage! How exciting!
At least you have time to fabricate your tunnel and maybe your bed until the coil arrives or are you going to scavenge one from a parts tractor? haha it was for like 10 sec. I am glad all the wiring worked out I basically yanked all the safety switches & tied all the wires back up... I have allot of spare parts but no kohler engine coils, tons of briggs stuff, and I will amazon prime the coil! There didn't seem to be any crazy belt slap or anything like that. So I still have tons to do, but at least I know it is ready to run. | |
Age : 49 Join date : 2016-09-06 Points : 15032 Posts : 10618 Location : Oklahoma
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] September 4th 2018, 9:14 am | |
| Yeah that dash cowl turned out super slick looking, pretty much just looks like it's factory. Great work! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5537 Posts : 1993 Location : Northern Ireland
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] September 5th 2018, 7:18 pm | |
| - MatthewD wrote:
- Wow, that dash looks fantastic! Worth all the effort. Looks pretty good with the bed on it.
Thanks man its coming together... I put in a new coil today, I ordered a chinese one from amazon and it ran for about 10 seconds and quit and no spark so I should have just gone with the kohler...bummer I am gonna try and order up some metal, in the meantime I think I am gonna paint the bed orange & do black bedliner on the inside. The tractor frame will be all black and the running boards are gonna stay orange. I am going to have a removable seat in the bed as well so two people can ride on it. At this point I think I will have something running and driving in two weeks or so. Then start taking care of all the little details. | |
