 Redzz02's Haspin Build [2018 Build-Off Entry]
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Mon Mar 26, 2018 8:00 am
@AllisKidD21 You definitely have a good suspension eye.  It makes sense to move that toplink over so it doesn't interfere with the engine pulley or crankshaft.  It's be easier to work on belt and pulleys without a link bar right in your way.
@redzz02  Do you know the application that the shocks you bought are designed for?  Would you send me the link to them?
Online
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Mon Mar 26, 2018 8:50 am
Espyville Mudders
https://www.youtube.com/user/redzz02
https://www.facebook.com/Espyvillemudders
everything from dropping em down and racing, to jacking up high muddin
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Mon Mar 26, 2018 12:04 pm
Update video two
Espyville Mudders
Forum Rep : 68
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Mon Mar 26, 2018 4:05 pm
Nice video.  Thanks for sharing all the details.  I like how you lowered your center of gravity.  I think this tractor's going to handle well.
Online
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Mon Mar 26, 2018 5:19 pm
@Crazy_Carl I stole the idea from the mowrons (stretch and therainbowboxer)
Haspin has a lot of hills and they have purpose built mowers just for haspin, so I figured I'd copy some of there mods as to how well they perform out there
Espyville Mudders
Forum Rep : 15
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Tue Mar 27, 2018 12:35 am
I like the sturdy frame, and the Look. The old lawn tractors are looking soooo much nicer than the newer ones.
Forum Rep : 118
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Tue Mar 27, 2018 12:46 am
Ooh boy, she's looking good in that video! That brace over the transaxle looks pretty neat. The spindle knuckle setup should cool to see done as well.
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 12:00 am
fab work definitely exhausts me on builds, working on this thing daily has been tiring, but every little bit counts
with my motor backwards with the intake facing the rear of the tractor, and chopping the tunnel down i have very limited room for a battery and a fuel tank.
so in efforts to gain some room up under the dash, possibly fitting a steering shaft, intake, battery, and fuel tank up under the dash and making it LOOK GOOD is going to be a challenge, i decided to build my own dash
well modify the existing dash to obtain more room
14 gauge steel to reform the new dash, welded it to the existing one and cut out the center of the existing old dash, leaving a new slightly bigger dash!
ill be cutting a big portion out of the flat of the new dash to accommodated an access panel
also have the main dash/upper steering support tacked into place, along with what is soon to be a removable top cage for the motor and a hood mount.
i trimmed off two inches off of the grill to try and show some of the suspension more
Espyville Mudders
Forum Rep : 118
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 12:03 am
Looks good! The cage around the engine looks pretty solid.
Forum Rep : 68
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 7:18 am
Nice looking dash!
Online
Forum Rep : -1
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 8:21 am
Nice fab work, Redzz!
You're building this thing like you're planning on flipping it over or something... Laughing
Chaos Build
Check out the pics and vids!
Haspin 2016 Media thread
Haspin Acres Rally 2017!
TheRainbowBoxer on YouTube
Forum Rep : 179
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 9:05 am
After seeing you guy's videos at Haspin. I do not blame him!
(Kal-El) 1982 Murray GT. . . . . . . . . . . . . . . . . . 2-39002 . . . [2018 Entry]
Progress:  ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 9:48 am
@TheRainbowBoxer @MightyRaze I don't plan on rolling THIS one! Haha last year I just hit that bump a little wrong, but I am building this one so hopefully I don't have to zip tie stuff back together after it rolls, Once I get the steering figured out it shouldn't bee too bad to get the rest done
Espyville Mudders
Forum Rep : 36
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 10:53 am
Looking beefy! I love the fab work on the dash.
Forum Rep : 179
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 10:58 am
That Dash does look good.  Like it was meant to be that way.
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 11:04 am
@MatthewD @MightyRaze thanks it looked a lot better in my head but it definitely looks a lot better fronded down, it'll be even better once I smooth it all out and make it look perfect
Espyville Mudders
Forum Rep : 15
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 12:32 pm
Your work looks very good. I like the modified dashboard. Wish i can weld as good as you affraid
Forum Rep : 118
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 12:36 pm
Not sure if you mentioned it but what are your plans for steering on this rig? A rack and pinion like Stretch's Silver Bullet would be pretty neat.
muddstir
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 1:15 pm
Its looking good, real good. Im really digging the lowered stance
On a side note we must be running on the same brain waves cuz there will be a half twin when i get mine updated
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 1:29 pm
@AllisKidD21 most likely direct steering that's what I have had on my mind
Espyville Mudders
Forum Rep : 118
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 1:33 pm
Ooh okay, I see. Would the bumpsteer be pretty bad with direct steering though maybe?
Forum Rep : 53
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 1:43 pm
Looks good! I like the cage around the engine, good idea. Wonder if this rig will turn out better than the mowron's builds? Lol
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 1:47 pm
@AllisKidD21 with how stiff the front end is I doubt I'll have much of an issue, One way to find out
@RichieRichOverdrive I'm not sure I stole a lot of ideas from their builds, I'd say there's because there is less moving parts to break and this is a complete scratch fresh build
Espyville Mudders
Forum Rep : 118
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Thu Mar 29, 2018 1:49 pm
Yeah that's true, haha. There won't be any play with direct steering though, which is a bonus for sure.
redzz02
Sponsor
Sponsor
Forum Rep : 7
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Tue Apr 03, 2018 8:44 pm
another day and another bolt,   between work and working on this thing among everything else, im beat.
ive torn my house, garage, and sheds apart looking for my brake hub for a week and finally caved and ordered another one, guess who found the original brake hub the day i got the new one? ME yup me, was in my one jacket pocket out in the garage.
i made the engine cage bolt on so now i can actually remove the motor when ever need be,
i also brought home the motor that will be on it, the 16hp twin that was on my 4x4 build.
i used some HF 3.99 10 inch tires and cut out the centers to make steering shaft supports
brought home some matching front tires also, i think im gonna cut the tread pattern for now.
steering is half way done, i need to order a steering wheel, and make up a pitman arm and another tierod,
and lastly i started on mounting the foot boards, i have decided with going original opposed to building nerf bars.
Espyville Mudders
Forum Rep : 118
PostSubject: Re: Redzz02's Haspin Build [2018 Build-Off Entry]   Tue Apr 03, 2018 8:58 pm
Looks great! The blower shroud sure stands out, haha. I just noticed on your 3-link that the upper link is pretty much the same length as the lowers. I don't think you'll have any binding problems though since it's mounted up a bit higher on the frame crossmember than the outer links. Plus I guess you don't have like wicked up and down travel or anything, haha.
Page 3 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Redzz02's Haspin Build [2018 Build-Off Entry]
» Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]
» tater's Ford XXLT18 [2018 Build-Off Entry]
» Biggasmower's "Lawn Gone lawn boy" [2018 Build-Off Entry][COMPLETE]
