 Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]
Maine Mud Mower
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 03, 2018 12:52 pm
After all the car and truck break downs it was time to get some progress in.
http://www.Mudmower.com
Forum Rep : 189
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 03, 2018 2:03 pm
Spindle grease packing into the axle? Looks to be moving along!
Murray CCT (KAL prebuild)
Sasquatch II [2017 Finalist]
ATLTF Facebook Page
How To Upload Pictures
ATLTF Staff:
Maine Mud Mower
Forum Rep : 6
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 03, 2018 4:26 pm
Yup I could not get over it and had to take a picture.
Forum Rep : 76
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 03, 2018 8:35 pm
interesting start to your twin I-beam set up. are the brackets that are welded to what’s left of the factory axle for your shocks to mount to?
Maine Mud Mower
Forum Rep : 6
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Fri May 04, 2018 10:15 am
Yes the bracket is to change the angle of the adjustable coil over shocks I have set aside from BMIkarts. I actually designed and bought shocks 3 years back but never got around to attempting it till now.
Forum Rep : 19
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Fri May 04, 2018 10:22 am
I'd be afraid of cutting those plates, may add some unwanted stress on the frame.
Forum Rep : 121
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Fri May 04, 2018 12:04 pm
Looks pretty neat so far! Defintely looking forward to seeing your setup complete.
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
Online
Forum Rep : 189
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Fri May 04, 2018 12:28 pm
Not sure how it would for him?  I see people remove it all together.  I think it is good use of what you have.  Smile
ATLTF Facebook Page
ATLTF Staff:
Maine Mud Mower
Forum Rep : 6
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Fri May 04, 2018 9:36 pm
Check out the pics a bit guys. the whole front beam is welded with bracing
Maine Mud Mower
Forum Rep : 6
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Wed May 23, 2018 9:03 pm
Decided the only way to get the wheel geometry on the front right was to build the custom rims. If anyone care to make their own I will add the original how to on the bottom of this post.
Forum Rep : 57
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Wed May 23, 2018 9:10 pm
Interesting front end design. Has alliskid written all over it lol
Forum Rep : 19
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Wed May 23, 2018 9:11 pm
Don't look now but I think your front tires are mounted backward.
Forum Rep : 121
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Wed May 23, 2018 9:12 pm
Looks pretty cool Neil! One thing you may notice with this setup is, being that you have a single tie-rod instead of a bell crank with dual tie-rods, when the beams drop the wheels will toe-in because the distance between the wheels is getting shorter. My little Ford used to do that but I recently made up some limit straps so the beams do not have extreme droop anymore. Looking forward to more progress on this!
Online
Maine Mud Mower
Forum Rep : 6
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Wed May 23, 2018 9:17 pm
That problem is already in the works to deal with. The goal is to have the steering work just like a 2wd ford range. Triangle linked Tie rods with frame rail steering pivot and all.
Forum Rep : 121
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Wed May 23, 2018 9:20 pm
Ooh, okay. Sounds pretty cool! Should be a good working setup when you get that all together.
Online
Forum Rep : 189
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Wed May 23, 2018 11:17 pm
Spoiler:
Cool deal MMM.  I was afraid your build was going to be on hold a bit with all that is going on.
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 19
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 24, 2018 9:57 am
Spoiler:
Forum Rep : 57
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 24, 2018 10:09 am
Spoiler:
Forum Rep : 189
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 24, 2018 10:59 am
Spoiler:
Sorry Neil, we have gotten off track on your thread.  We will get back on topic.
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 57
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 24, 2018 1:40 pm
How is talking about his tread patterns off topic?
Anyways still looking forward to seeing g the suspension travel this thing can get !
Maine Mud Mower
Forum Rep : 6
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 24, 2018 9:23 pm
Ok So this is just a mock-up but you should get the idea. It's a ton of trial and error at this point but we shall see.
Maine Mud Mower
Forum Rep : 6
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 24, 2018 9:29 pm
@MightyRaze wrote:
Spoiler:
Thank you!! I do not think I had another polite think first open mouth second comment in me for him.
At this point the next thing is to set the tires 90 degrees at dead center of travel and weld in the front I beam bars. Measure 20 times weld once and hope it's right.
Forum Rep : 121
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 24, 2018 9:34 pm
Looks pretty nifty with the radius arms all mocked up and stuff.
Online
Forum Rep : 189
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Thu May 24, 2018 11:52 pm
Oh... I see where you are going with it. Very nice!
ATLTF Facebook Page
ATLTF Staff:
Maine Mud Mower
Forum Rep : 6
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Fri Jul 13, 2018 8:32 am
Heading out on vacation soon but got a bit of time in on the build last night finally.
Forum Rep : 17
PostSubject: Re: Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]   Fri Jul 13, 2018 3:25 pm
does'nt look like a Peerless. 930 has some differences, and it's no MST. a Spicer? or Foote?
the Locker looks interesting. But I think I will go for the Doc Locker, cuz it looks like the sturdiest way to go.
Page 3 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]
» MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]
» tater's Ford XXLT18 [2018 Build-Off Entry]
» Redzz02's Haspin Build [2018 Build-Off Entry]
