| [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} | |
+13Creepycrawler Buck mr.modified MatthewD biggasmowers muckmudd RichieRichOverdrive AllisKidD21 CraftsmanQuad19 Double W Cross Ranch mrshaft696 prancstaman Doug 17 posters |
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3345 Posts : 825 Location : In the shop
Age : 22 Join date : 2018-02-27 Points : 3630 Posts : 1299
Age : 20 Join date : 2017-06-09 Points : 5276 Posts : 2640 Location : Literally Nowhere, Texas
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5117 Posts : 2561 Location : Rochester, New York
| Subject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} March 12th 2018, 3:02 pm | |
| Tire and Rim workThe crappy Turf Tires they were on the Murray Rims are completely junk. I took of the Wheels from my 110cc chinese ATV to change the tires to use the ATV tires on the Mower and make a few burnouts with the turf tires until they blew up. removed the Tires from the Rims cleaned the rims and tires to reassemble them want to put the turfs on the ATV rims. I had it on, but once i would put some air in the tires, but the air were leaking out of all the cracks and to fix those tires is`nt worth it so i put them into my garbage pile. I`m not sure if i use the ATV tires or if i buy some tires like these for my front wheels. Now i decided to sand the rims and make them ready for painting before i put the new tires on. It works good with my metal lathe and a wire brush into my drill And until i took a look into my mailbox i found the Axle Bearings for my Peerless MST 206 Which front tires should I use? the ATV tires from ebay or those i had lying around?
Last edited by SebastianAlbrecht on August 11th 2018, 1:01 pm; edited 1 time in total | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4880 Posts : 1412 Location : Cleveland,Ohio
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4714 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} March 13th 2018, 11:06 pm | |
| Some video on youtube has a drunk guy riding his laen mower pulling shopping carrs with an extension cord cause his lisence was taken away from drunk driving. Pretty ingenous but not sure if it was a real or stagged video.
Those tires look like what come on some larger off road go carts. | |
| Subject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} March 15th 2018, 3:32 pm | |
| Putting a geared transaxle in an mtd and getting rid of the vari drive is a very big improvement . Its quite awesome that your in Germany , there are people from every place it seems on here and it makes very it very interesting to see what you have to go through to get parts for these machines. | |
| Subject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} March 15th 2018, 6:10 pm | |
| - biggasmowers wrote:
- Putting a geared transaxle in an mtd and getting rid of the vari drive is a very big improvement . Its quite awesome that your in Germany , there are people from every place it seems on here and it makes very it very interesting to see what you have to go through to get parts for these machines.
Yes, a geared Transaxle is realy good. but you had understand it wrong. I want to replace the FNR Transaxle with the Peerless MST 206 and let the Varidrive installed. Want to have a lot of Gears for Yard Work and Offroading. To find some good parts is very difficult, because everything for garden equipment is really expensive in germany, so i need to look a lot and wait until i found a cheaper one. Once i got my mower, the Varidrive had slipped sometimes when you put it in a low gear. But i think it will be fixed with some nice kevlar belts and to put more tention on the springs to get more friction between the belt and the varidrive. | |
Age : 49 Join date : 2016-09-06 Points : 15034 Posts : 10620 Location : Oklahoma
Age : 25 Join date : 2016-07-10 Points : 8371 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Complete] MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry} March 16th 2018, 9:38 am | |
| Yeah the belts on vari-drive setups are 5/8" wide, as opposed to 1/2". I think they have to be 5/8" for the vari-drive to work correctly too. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
