 MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]
Go to page : Previous  1, 2, 3, 4, 5 ... 9 ... 15  Next
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 2:41 pm
Excellent! Looking great!
Forum Rep : 53
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 4:01 pm
So the peerless bolt holes lined up with the frame holes on the mtd? Cool
Forum Rep : 179
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 4:30 pm
Stuff is so interchangeable these days that I am not surprised.  :-)
(Kal-El) 1982 Murray GT. . . . . . . . . . . . . . . . . . 2-39002 . . . [2018 Entry]
Progress:  ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 9:12 pm
Thank You MightyRaze
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 9:16 pm
The Peerless has 2 different mounting hole types, and the inner hols are lining directly up to the stock ones. Earlier i wanted to add some brackets to use the outer mounting holes, but i think, the inner holes will do it also good enough.
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 9:20 pm
I'm very surprised, that my MST fits without too much problems into the MTD. someone should change out the Peerless and the FNR, so 1 mower has 30 Gears, and the other only 1 lol! lol! Laughing Laughing Laughing
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 9:53 pm
Rear Fender Work done
I welded the holes in the fender, the previous Owner had drilled, but I do'nt need those Holes, and closed the old FNR Shifter hole, and cut my new shifter hole.
I really like, how the welded spots came out, after i had grinded them down to fit the Shape of the Fender.
We all knew, worst case scenario is, when you're alone into some Mud Trails, and your Starter dies, or your Battery is Dead. Because I do'nt want to get into those Problems, I took Off the Recoil Starter Shroud , the Recoil Starter, the Starter Cup, and the different Flywheel Fins from a Spare Engine my Dad has bought 10 Years ago, to use it on my MTD.
I also welded up some of the Holes in the Dashboard, because i want to reposition the Choke and the Lights Switch, and the Ignition lock. Stock it sits down in the dashboard, but that's a really bad spot, so i want to bring it up to the top. Better for my back Wink
Tomorrow I want to make the Skid Plate, and set the Brakes up
Forum Rep : 179
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 10:19 pm
Nice job patching up those holes.
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 10:47 pm
Thank You. It's much work do'nt to burn through the metal. And you need to stop to let the welded area to cool down
Forum Rep : 117
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 11:14 pm
Nice work on welding up those holes!
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
Forum Rep : 53
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 11:30 pm
Good job with filling those holes. I do that a lot more than I'd like to admit honestly, haha. What welder did you use for it? I use MIG if I can.
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Wed Mar 28, 2018 11:54 pm
I had used MIG. 0.8mm flux core
@AllisKidD21 Thank You
Forum Rep : 67
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Thu Mar 29, 2018 12:31 am
Very nice work man.  Are you still going to cut an individual notch for each gear?
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Thu Mar 29, 2018 12:50 am
Not sure. At the Moment, the shifting way is too close, you skip the gears while you shift, i need to change that. the Shifter Spring in the trans has lots of power, but would be better to cut those notches. Tomorrow i knew more.
Master
Master
Forum Rep : 22
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Thu Mar 29, 2018 3:28 am
Great job with sanding down those holes.
lol!
Forum Rep : 35
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Thu Mar 29, 2018 6:01 pm
I like the addition of the recoil starter, my 12hp B&S on my Westwood has the old-type Briggs recoil start which uses the starter clutch instead of the newer starter cup. The body work looks good filling up those holes Wink
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Thu Mar 29, 2018 7:48 pm
lol!
Thank you. Have to fill more holes in the front grill, the previous owner had drilled.
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Thu Mar 29, 2018 7:54 pm
i do'nt knew, but the recoil starter shroud has a bigger cooling fan diameter, and i need to find a recoil that fits the stock shrouds. Those pull-start shrouds are rare, and i think the old starter clutch types have a different crank, so i ca'nt add this old starter feature
Forum Rep : 35
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Thu Mar 29, 2018 8:10 pm
Yeah, the starter clutch requires a different crank to work, so if you want to fit one you need to change crank shafts.
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Fri Mar 30, 2018 1:32 am
Working under the mower
To work more comfortable, i had jacked up the mower. Now it's in the Wheelie position Laughing
I started working on the Skid plate
The skid plate also is the Transaxle supporting mount
because i had electricial problems, i ca'nt finished welding together the skid plate frame
Hopefully, tomorrow i can weld without problems. Also had calculated my Pulley Ratio. Everything stock, only different rear pulley and rear belt.
Forum Rep : 67
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Fri Mar 30, 2018 2:10 am
Is it going to clear the deck okay?
Forum Rep : 179
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Fri Mar 30, 2018 5:38 am
Looks like it starts at the front brace and goes to the back. That should work ok.
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Fri Mar 30, 2018 7:25 pm
Not sure, have'nt tried it yet, because the mower deck is sitting disassembled in the shop, waiting for better weatherto paint. But should work. If not, I have a problem Sad
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Fri Mar 30, 2018 7:29 pm
I wil mount the Skid plate on the Frame. The Front part is secured to the deck lifting assembly, and the rear to the frame. I do'nt really need a skid plate, but protection is always better than no protection, and i never want to break my MST.
Forum Rep : 15
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Sun Apr 01, 2018 9:17 pm
Brake Setup work
Today i worked more on my Mower. Because you liked it so much, seeing me welding the holes, here the last holes.
The stock MST Brake Caliper wo'nt fit, so I needed to make my own
Next I made my Brake Handle. It's made out of a old mower deck lift lever off from a rear engine rider (upcoming project) i had modified.
I made the Brake lever to have 3 settings. Setting 1 is NO brakes. Setting 2 is open brakes, you can push the brake lever when you want to brake, and setting 3 is parking brake. If it is in parking brake mode, it hits my leg, so i ca'nt forget to release the Brake when i want to drive. need to connect the caliper and the lever in the next time.
Forum Rep : 17
PostSubject: Re: MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]   Sun Apr 01, 2018 9:37 pm
That's a good solution to that issue. Good job!
Page 4 of 15Go to page : Previous  1, 2, 3, 4, 5 ... 9 ... 15  Next
» MTD Rasentrac B10 Garden and Offroad Mower [2018 Build-Off Entry]
» Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]
» outlaw lawn crafts dirty dynamark mud mower! [2016 Build-Off Entry]
» Redzz02 "Sears Killer" Wheel Horse Mud Mower [2017 Build-Off Entry] [Finalist]
» tater's Ford XXLT18 [2018 Build-Off Entry]
