 73 sears, my first sears
Go to page : Previous  1, 2, 3, 4, 5
Buck Mault
PostSubject: Re: 73 sears, my first sears   Wed May 02, 2018 6:59 pm
@Crazy_Carl lol.
ill change the tranaxle oil when im done to see if anything happened but I dought it those straight cut gears are beefy
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Thu May 03, 2018 7:24 pm
I dont like how loud the exhaust on this thing when working around the yard so time to build something better
I'm going to fill it with steel wool and weld the end on , video to come tomorrow
Forum Rep : 28
PostSubject: Re: 73 sears, my first sears   Thu May 03, 2018 7:35 pm
Cool exhaust! Does that just thread into the block? You might want to make a bracket to hold it because the weight of the muffler could put a lot of stress on the block and maybe crack it if it got hit by anything or rolled over onto.
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Thu May 03, 2018 7:41 pm
thanks for the heads up. it's going to mounted to the foot rest
Forum Rep : 113
PostSubject: Re: 73 sears, my first sears   Thu May 03, 2018 7:48 pm
Looking good so far! I'm curious to see how it sounds.
Success doesn't happen to all of us, if it did they'd change it believe me - Red Green
                             Tourque it 'til it breaks, then back it off a quarter turn!
        Stuff I've Welded Together
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        - Lawn Tractor Utility Trailer
Online
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Thu May 03, 2018 7:49 pm
Huh, seems creative! Nice job!
Online
Forum Rep : 46
PostSubject: Re: 73 sears, my first sears   Thu May 03, 2018 8:28 pm
Nice work, it would be cool if you could make a before and after video so we could hear the difference between the previous exhaust you had on there and this one.
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Thu May 03, 2018 8:31 pm
I like how Doc did his.
@Crazy_Carl ya for sure ill try to get it finished tomorrow
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: 73 sears, my first sears   Thu May 03, 2018 11:07 pm
I like your exhaust!  Very cool looking.
Progress:   ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 5:33 pm
here it is, hard to tell, but in person its a big difference
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:04 pm
Yeah they are hard to tell on video. I noticed it slipped off.  A good thing to hold it on with is either a hose clamp or bailing wire, and they both are cheap and removeable.
Online
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:07 pm
This is true its on there now with mechanics wire, im building a mount for it to the foot rest, might take it apart and change a few thing or just do a 2.0
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:08 pm
Oh okay. I would use a hose clamp to hold it on to the bottom of the mount though.
Online
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:09 pm
that nasty tick is getting worse
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:12 pm
Yikes.  Have you changed the oil?
Online
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:14 pm
@Double W Cross Ranch yep its all new, it might be the valves or connecting rod, witch they seemed all fine when I had it apart
Forum Rep : 46
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:16 pm
valve adjustment?
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:25 pm
That sux.
Online
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Fri May 04, 2018 6:28 pm
@Crazy_Carl wrote:
valve adjustment?
i did it when i had it apart, might have to do it again
Forum Rep : 113
PostSubject: Re: 73 sears, my first sears   Sat May 05, 2018 10:05 am
Yeah it sorta sounds like there's excessive valve clearance, either that or it's the dreaded piston slap. But hopefully it's just the valves.
Online
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Sat May 05, 2018 11:18 am
What kind of engine is it again?  Sorry I guess I have short term memory, lol!
Online
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Sat May 05, 2018 2:46 pm
12hp Tecumseh hh120
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Sat May 05, 2018 2:48 pm
Tecumseh? Oh.
Online
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Sat May 05, 2018 5:07 pm
@Double W Cross Ranch ya its the origanal motor and as far as I can tell its never been rebuilt
Page 5 of 5Go to page : Previous  1, 2, 3, 4, 5
