 73 sears, my first sears
Buck Mault
PostSubject: Re: 73 sears, my first sears   Sat Mar 31, 2018 6:10 am
ya for now I'm going to run it , the engine 45 years old lol. but once i find a kit i will be rebuilding it
Forum Rep : 46
PostSubject: Re: 73 sears, my first sears   Sat Mar 31, 2018 7:28 am
Paint job looks good.  Are there any mom and pop size engine rebuild shops around you that can help you out?  I agree with the other guys.  I would hone the cylinder at a minimum.  There's a lot of DIY things you can do to that motor now that is have it all apart like checking the head for flat, polishing the crank journal, and lapping the valves.
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Sat Mar 31, 2018 9:24 am
oh yes I agree, i dont hone the cylinder yet , but i did lap the valves and and gounded down to spec, the head was straight. the rest will be done once i get new bearings, seals/ gasket kit, piston and connecting rod.
Forum Rep : 46
PostSubject: Re: 73 sears, my first sears   Sat Mar 31, 2018 6:36 pm
You are doing a good rebuild on her. Awesome.
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Mon Apr 02, 2018 2:25 pm
Well found were some of that Vibration was coming from, clutch pulley was toast and there's ton of belt slap on the bottom between rear pulley and engine so i added a idler. made a big difference
out for a test
Trial Administrator
Trial Administrator
Forum Rep : 143
PostSubject: Re: 73 sears, my first sears   Mon Apr 02, 2018 3:14 pm
@MightyRaze wrote:
How is your clutch/pulley?  Looks like you got some good mud there.  You don't have a bearing going out in the clutch causing it to bounce the belt?
LOL, glad you figured out the vibration!  I do have to say, that is the best looking Tecumseh I have seen.
Progress:   ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Mon Apr 02, 2018 3:21 pm
@MightyRaze thanks that damn thing must weigh 150lbs
Forum Rep : 41
PostSubject: Re: 73 sears, my first sears   Mon Apr 02, 2018 3:23 pm
There’s those old cast iron engines for ya. A true big block lol
Forum Rep : 46
PostSubject: Re: 73 sears, my first sears   Mon Apr 02, 2018 4:10 pm
All the fresh paint on the tractor and engine is looking good in the pictures.
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Mon Apr 02, 2018 4:44 pm
@Crazy_Carl just need to wash the back half
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Tue Apr 10, 2018 6:15 pm
Finally had nice weather lol well for a few hours before we got a half a foot of snow
I really need to lock this thing
Forum Rep : 46
PostSubject: Re: 73 sears, my first sears   Tue Apr 10, 2018 6:27 pm
If that's the kind of schmoo you run in a lot I'd say lock it.  How'd the motor run?
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Tue Apr 10, 2018 6:36 pm
@Crazy_Carl its running good , but once i have the funds im going to rebuild it. once work slows down im pulley swaping it and get a new clutch pulley.
the best thing about these old tractors is you put it in low and first and get off and it crawls out by it self, lol well for most part. i was pulling my kids in a trailer thats why i sunk, i took it off and I went up that hill in 3rd high a few times not getting stuck, when in dought throttle out
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 8:18 am
been super busy with work but finaly got out in the yard, had to remove a bunch of roots and stump
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 8:19 am
so I built this out of scrap, works well just need better traction
Forum Rep : 46
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 8:22 am
maybe you’d want some wheel weights for a pulling application. Nice to see the tractor hard at work
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 9:06 am
ya maybe its a good thing its not locked because when I hooked a big rock or stump i damn near flipped it
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 9:53 am
Does it yank the stumps up well?
Online
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 11:17 am
for most part, as long as you cut most of the roots, had to change the blade alittle
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 11:29 am
Yeah makes sense. You use a sawzall or what to cut the roots?
Online
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 1:02 pm
@Double W Cross Ranch ya and a shovel, axe, and a chainsaw to nock the top down.
lots of rock here so I figure a sawzal blade is cheaper then a chain for the chainsaw
Forum Rep : 19
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 1:24 pm
Yeah, and a chainsaw has trouble cutting into dirt anyway, sawzalls dont.
Online
Forum Rep : 35
PostSubject: Re: 73 sears, my first sears   Tue May 01, 2018 10:13 pm
That looks like a really cool riding spot. Nice machine, sears suburbans are where it's at!
***Simplicity Racing Team*** #64 Question? Feel free to PM!
Simplicity Adventure Edition
Diesel Submarine Project
Baja Sears Suburban
Modified Briggs Model 5s
ATLTF.COM Race Truck
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Wed May 02, 2018 3:40 pm
this one worked the tractor and my back
Once i find more guys to go riding there alot out here
Forum Rep : 46
PostSubject: Re: 73 sears, my first sears   Wed May 02, 2018 6:26 pm
Wow just looking at this sears hard at work is making my back hurt.
Buck Mault
Forum Rep : 2
PostSubject: Re: 73 sears, my first sears   Wed May 02, 2018 6:59 pm
@Crazy_Carl lol.
ill change the tranaxle oil when im done to see if anything happened but I dought it those straight cut gears are beefy
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
