PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown Timer
 100$ Dation 16HP MTD 990
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 5:12 am
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 11:12 am
so whats the biggest tiers i can get to fit that style of rim (8") on the front? im Defently putting 35" tiers on the back. getting an over time check this weekend so im dropping 400$ on that
Forum Rep : 309
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 11:23 am
For the width of your fronts, not sure. Tallest 8 inch wheel tire I have seen is 22 inch, but that is for a wider rim.
Patriot [2019 Build Off]
Kal-El [2018 3rd Place]
Sasquatch II [2017 Finalist]
Forum Admin ~ Chat Admin ~ Facebook Page Admin
ATLTF Facebook Page
How To Upload Pictures
ATLTF Staff:
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 1:11 pm
what about for this medium width rim i have?
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 2:51 pm
i do plan on this thing to be able to get threw the mud becase im praticly addicted to mudding, but i defiantly plan on this being a work horse/utility tractor. i plan on fixing the 3 point hitch and if some how i find a blade deck for it im getting it.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 3:07 pm
Forum Rep : 156
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 4:27 pm
This tractor has 15" rims? Huh, interesting.
"This is where the thinking came in.... that took a while."- Red Green           "Just took a center punch *Wham!* Oh that's close enough." - TheBeal
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 8:33 pm
what were you expecting? thats stock on a 990. the 970 has 12"
now for every one i worked on the thing more tonight, dont have time to dump camra, need to get to bed so i can get up at 4am for MORE OVER TIME, im so over overtime, yet i wont turn it down when offerd it. the tractor is mostly assembled, did not put hood on yet, im gutting a re-wiring the whole eletrical system first.
i was going to rebuild the starter/genrator as its abit stiff, but the thing works and i was stripping the bolts trying to get it a part, i risk daming it with heat, so ile let it go till its actually a problem instead of making one.
i also need to get ain air filter since my last one coght on fire.
Forum Rep : 156
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Oct 25, 2018 9:39 pm
I just didn't know is all...... never seen one of these ol' MTD garden tractors in person.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Fri Oct 26, 2018 5:51 am
so i was ebay searching last night and i cold not find an air filter for a cast iron briggs. i hope that style of air filter is not to old for me to get.
Forum Rep : 309
PostSubject: Re: 100$ Dation 16HP MTD 990   Fri Oct 26, 2018 7:41 am
ATLTF Facebook Page
ATLTF Staff:
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Fri Oct 26, 2018 8:22 am
@MightyRaze wrote:
Is it not one of these?
https://www.amazon.com/Briggs-Stratton-393957S-Filter-Cartridge/dp/B0038U3GDM
thats it, i forgot amazon was an option, i have had so many bad runs with buying used things from them i dont use amazon anymore.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Fri Oct 26, 2018 8:39 am
todays goals: re wire whole eletrical system
use apoxy to fix bad seal in gas tank.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Mon Oct 29, 2018 3:49 pm
well i ended up bying the 16" carsile xtrac tiers for the front becase they were cheep and i only could find turf savors in bigger. i think 35" in the rear and 16" in the front its going to be absurd.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Mon Oct 29, 2018 4:50 pm
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Tue Oct 30, 2018 7:46 pm
tomrrow my xtracs are suspoed to come, so i will take my tiers down to sears and get them to do the rim swaps for me.
Forum Rep : 45
PostSubject: Re: 100$ Dation 16HP MTD 990   Wed Oct 31, 2018 7:30 am
Those Tires are HUGE!!
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Wed Oct 31, 2018 7:56 am
i know right? i cant wait to make this duallies.
dew to the fact that tractor is to big for me to back in to the shead i think that getting duallies will be a spring time project, because in a month when i can afford to buy another set im not going to want to work outside.
Forum Rep : 126
PostSubject: Re: 100$ Dation 16HP MTD 990   Wed Oct 31, 2018 2:25 pm
I would have gone with something like this for the front:
https://www.ebay.com/itm/2-1-pair-20X7-8-D-929-ATV-Knobby-Tires-Tire-DS7316-20x7-00-8-20-7-8-20-700-8/391717662654?hash=item5b34312fbe:g:8IEAAOSweehambWd🇸🇨UPSGround!14522!US!-1:rk:2🇵🇫0
or some other 20x7-8 tire.  They would fit that rim nicely.
It's good to see someone else getting on old flathead running.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Wed Oct 31, 2018 6:33 pm
https://www.ebay.com/itm/2-1-pair-20X7-8-D-929-ATV-Knobby-Tires-Tire-DS7316-20x7-00-8-20-7-8-20-700-8/391717662654?hash=item5b34312fbe:g:8IEAAOSweehambWd:sc:UPSGround!14522!US!-1:rk:2:pf:0
if that actually wold fit that rim right then im kinda upset about it, i hate how low my front sits.
it looks awesome from the back and kinda sad in the front.
Forum Rep : 156
PostSubject: Re: 100$ Dation 16HP MTD 990   Wed Oct 31, 2018 6:36 pm
Yeah definitely need some bigger tires in the front. Those tires Carl linked would fit and I bet they'd look pretty neat. Even some 21's would look good I imagine.
The new rear tires look pretty good though.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Wed Oct 31, 2018 7:24 pm
well im a little late to that party, the front tiers will work, and my gole with this is being able to pull stuck things out of mud holes and do pulling work arround the yard. i wld like bigger tiers in the font, but im not replacing the ones i have now untill they rott out.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Wed Oct 31, 2018 7:28 pm
do any of you know of any other bilds were some body else shoved tires that big on a lawn/garden tractor? it feels absurd to sit on this thing, im high up there.
Forum Rep : 126
PostSubject: Re: 100$ Dation 16HP MTD 990   Wed Oct 31, 2018 9:00 pm
I've seen a few of these monster lifted mower in sprocket's garage on facebook.
I get concerned over the center of gravity.  However they look like a lot of fun for mud bogging!
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Nov 01, 2018 8:12 am
oh, i have seen thoes on this video, they dont look piratical to me, look like a tip hazard.
RockeyDA
RockeyDA
Forum Rep : 11
PostSubject: Re: 100$ Dation 16HP MTD 990   Thu Nov 01, 2018 6:27 pm
DAMIT DAMIT DAMIT, ALREADY SHEARD KEYSTOCK ON THE FLY WHEEL ESDFDVDVF. IM SO NOT HAPPY
Page 4 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» Briggs and Stratton 16hp opposed twin questions
» 16hp twin carb?
» What kind of oil type should i use for a craftsman lt1000 with a Kohler Pro 17 hp OHV engine?
» Gain 2hp more on your 14/16 and 18/20HP Vanguard V-Twin!
» Opposed twin governor linkage.
