 Mr.Modified's Craftsman HE [2018 Build-Off Entry]
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sun Jun 10, 2018 8:45 am
Hood paint looks very cool! Stands out pretty good too. Craftsman seems to have held up well during Haspin.
Forum Rep : 175
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sun Jun 10, 2018 8:58 am
It looks like it did going to Haspin, I would call that a success!  Very nice!
(Kal-El) 1982 Murray GT. . . . . . . . . . . . . . . . . . 2-39002 . . . [2018 Entry]
Progress:  ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Forum Rep : 53
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sun Jun 10, 2018 12:01 pm
Nice! Any video footage coming put from this year?
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sun Jun 10, 2018 12:19 pm
Thanks guys. Yes I have video of the craftsman HE, the Simplicity, and the off road trailer. I have a bunch of video of everyone else too. I tried to cover as much of the action as I could.
***Simplicity Racing Research & Development*** #64
Simplicity Adventure Edition
Diesel Submarine Project
Baja Sears Suburban
Modified Briggs Model 5s
ATLTF.COM Race Truck
Forum Rep : 53
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sun Jun 10, 2018 12:47 pm
Really sounds like a great time! Maybe the people in the lower states sould figure out a similar event but closer to home
Forum Rep : 64
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sun Jun 10, 2018 1:27 pm
Interesting to know that the direct steering did pretty well on trail riding.  I like the low buck approach you took to this build.  It's the roots of ATLT building.
Forum Rep : 53
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sun Jun 10, 2018 1:33 pm
Well, the tires are the most expensive part of mower building and if your fine with using turf tires there's no limit to the fun you can have still.
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Mon Jun 11, 2018 10:15 am
I think the direct steer is a bit jumpy, but my dad thought for the most part it was alright. I was thinking the other day, why not make some sort of steering damper? They help a lot on dirt bikes and motorcycles so the same principal should work if I got the correct drag on it. It would allow you to steer but rocks and things wouldn't jam the steering around. Needs to be like a shock or something on the steering somewhere. But it can't be too heavy or you won't be able to steer very quick.
Baja Sears Suburban
Forum Rep : 45
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Mon Jun 11, 2018 12:39 pm
What if you cut the shaft, weld a big washer to each side, and drill a couple holes in each and bolt a hockey puck in between? That would space your handlebars up an additional inch, and slightly dampen your steering
Forum Rep : 53
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Mon Jun 11, 2018 8:26 pm
Or just some thick rubber. Maybe even some layers of tire rubber stacked up.
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Mon Jun 11, 2018 8:46 pm
That might help with vibration but a damper would stop quick movements of the steering like when one of the front wheels hits something. Obviously like a rock or rut, not a tree lol. It would be for times when the handlebars are moved 2 or 3 inches without you wanting them too. With a damper, the front wheels would hit the rock and ride over it before it has time to turn them. On motorcycle damper's they are adjustable for different situations. For instance at higher speeds you might crank it up a bit more so it has some more resistance, but for slower speeds you may have to steer quicker and you back it off a bit. In this case maybe just some sort of small shock would be close enough.
Baja Sears Suburban
Forum Rep : 64
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Mon Jun 11, 2018 10:01 pm
I like the damper idea.  I'd find an old gas shock from a tool box lid or hatchback to try out.
Forum Rep : 116
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Mon Jun 11, 2018 10:18 pm
Yeah I rigged up a screen door cylinder for a steering damper on the MTD at one point. Seemed to work okay but I took it off for some reason.
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
Online
Forum Rep : 5
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Mon Jun 11, 2018 10:31 pm
try a screen door closer, my buddy put one on his rer when we raced them, and we all made fun of him till we rode it, it made a huge difference.
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Wed Jun 13, 2018 11:52 pm
Oh yeah that's a good idea. Never thought of that. And it would be adjustable too.
Craftsman HE
ON THE LIMIT!
Up and over!
Baja Sears Suburban
Forum Rep : 175
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Thu Jun 14, 2018 9:00 am
Forum Rep : 64
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Thu Jun 14, 2018 10:19 am
Those are some awesome action shots!
Forum Rep : 45
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Thu Jun 14, 2018 10:29 am
When in doubt, wind it out!
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Tue Jun 19, 2018 11:58 pm
Thanks guys! It's nice to be able to go through the video and check every frame to get the perfect shot. Not quite as cool as if you took a normal pic but that would be hard to catch.
I didn't realize the front end came up that high until I checked the footage later.
Baja Sears Suburban
Forum Rep : 50
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Wed Jun 20, 2018 3:17 pm
Cool shots, those turf tires seem to have done alright!
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Tue Jul 10, 2018 10:40 am
At the current time, the Craftsman HE is sitting in the garage behind the simplicity. Needs the valves adjusted at a minimum to fix the hard starting issue I think. I was thinking of possibly selling it soon as I'm trying to free up space and I have so much stuff.
Baja Sears Suburban
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Wed Jul 25, 2018 9:53 pm
Still didn't get a chance to get the HE valves adjusted or take it out of the garage. Pretty sure I'm going to sell the HE sometime in the near future. Pretty much it is done as far as the build off is concerned.
Baja Sears Suburban
Forum Rep : 175
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Wed Jul 25, 2018 11:18 pm
When you are ready to call it complete... shoot up some video and let us know. I can tag it complete then.
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Tue Jul 31, 2018 4:16 pm
No problem, I'll get that done soon.
Baja Sears Suburban
Forum Rep : 40
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sat Aug 04, 2018 11:39 pm
Here's the finished build. Just a quick walk around video.
Baja Sears Suburban
Forum Rep : 13
PostSubject: Re: Mr.Modified's Craftsman HE [2018 Build-Off Entry]   Sun Aug 05, 2018 2:43 am
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» Maine Mud Mower "Mud Wizard" [2018 Build-Off Entry]
» High low craftsman [2018 Build-Off Entry]
» Kevin's Unnamed Extreme Craftsman Mudder [2016 Build-Off Entry]
» Mr. Modified's SUPER SNAPPER [2017 Build-Off Entry]
