 John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
Go to page : Previous  1, 2, 3, 4, 5, 6 ... 10 ... 15  Next
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 5:26 pm
We already planted ours
Forum Rep : 57
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 6:03 pm
Isn't the hunting season different in texas?
You could at least mount the engine to the frame for some eye candy ......
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 6:53 pm
@swampduck03 wrote:
Why do you plant food plots so late? Im about to plant mine.
Well if I put up one feeder, about 12 deer will show up that night.  We are very overpopulated, I bet if I planted it the day before hunting season it'd still perform great.
I didn't know you had any hunting land.
Not really, the first 2 days are Oct. 28-29 for youth, then the season opens on November 5, and ends sometime in January, usually we get an extension.
It is sitting in the frame right now.  I need to, but right now I have a cold so neither project is getting any work, lol.
Last edited by Double W Cross Ranch on Tue May 22, 2018 6:57 pm; edited 1 time in total (Reason for editing : Thanks Allis! :smash:)
Forum Rep : 190
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 7:00 pm
Easier to put it on the frame. lol!
Murray CCT (KAL prebuild)
Sasquatch II [2017 Finalist]
ATLTF Facebook Page
How To Upload Pictures
ATLTF Staff:
Forum Rep : 190
AH.... you edited on me..
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 7:02 pm
I didn't just be a jerk and change it after you posted about it, AK mentioned it in the chat and I edited it then. I guess you already had the page open.
Forum Rep : 190
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 7:12 pm
between seeing it and hitting quote obviously since it is correct in the quote......
ATLTF Facebook Page
ATLTF Staff:
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 9:31 pm
Yeah I guess.
Maybe if I feel up to it, I'll go work on her tomorrow.  We'll see.
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Thu May 24, 2018 4:41 pm
Got tired of seeing that disgusting disgustingness so I sanded it a bit and painted the rear fenders. Looks pretty nice!
Also, any tips on getting a keyway cut in that engine shaft?
Forum Rep : 57
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Thu May 24, 2018 4:49 pm
Try to find an old generator to use the tapered shaft end , or you could weld it up to over 1 inch then get it running and make a mount to hold a grinder up to it and machine it down the hard way
Forum Rep : 121
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Thu May 24, 2018 4:53 pm
I don't think I would do that. Not very accurate and the welding would probably weaken or potentially warp the crank. Just have a machine shop put a keyway slot in with a mill or something.
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Thu May 24, 2018 4:58 pm
Well, it doesn't really matter that it is tapered because only the first 1/2 inch of the shaft is tapered, and the pulley sits pretty far up the shaft. The only issue is that it has no keyway. I thought of just cutting a tiny little thing in it with a grinder, and using a woodruff key or something.
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Thu May 24, 2018 5:00 pm
Yeah all it needs is a keyway, it doesn't really matter that the first 1/2" is tapered because the pulley is going to be practically as far up the shaft as possible.
Forum Rep : 57
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Thu May 24, 2018 9:25 pm
Oh. Ok. Well then yeah you could just grind in a half moon keyway, a dremel might do a nice job verses a angle grinder.
Forum Rep : 17
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Fri May 25, 2018 1:38 am
Weld it up once vou have your welder, and then use the angle grinder. Need to do that maybe on my MST
Forum Rep : 36
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Fri May 25, 2018 9:18 am
There is no easy way. Youd have to remove the crank to get a machine shop to do it...
Use a chunk of small angle iron to make a strait line in the crank, use a dremel and cutoff wheels to rough it out, and use files to finish it. Time consuming... but if you take your time you can end up with a good keyway.
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Fri May 25, 2018 3:19 pm
Yeah, I've seen some vids with people doing that. I think I will, but I don't have a Dremel.
Forum Rep : 57
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Fri May 25, 2018 6:44 pm
They are 30 bucks at walmart.
tinkering bob
Forum Rep : 2
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Thu May 31, 2018 12:05 am
and less potentially with some tooling to boot at a pawn shop
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon Jun 04, 2018 8:12 pm
Pulled a good bit of the mowing bits and pieces out, they seem to have a decent retail price on Ebay, might look into selling them.
Pulled the rear tires off. First time I'd ever used a lug wrench on a mower! Still the smallest size on it because it was a 4 way. lol!
I couldn't figure out how to pull the rear end. Need to get the clutch pedal off because it is keeping me from pulling the fenders off. It's really siezed and I can't get a hammer on it to remove it. We'll see how it pans out.
Forum Rep : 57
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon Jun 04, 2018 8:39 pm
On the jd 140 I had, the clutch was on a shaft and had roll pins on each end with brass bushings where the clutch rod went through the frame
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon Jun 04, 2018 8:48 pm
On mine, it's a little different. There is a keyed shaft that comes out, and the pedal slips over that. There is a set screw that holds it in. I removed the set screw and sprayed the shaft and pedal with oil, and it will not break loose. Mad
Forum Rep : 121
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon Jun 04, 2018 8:52 pm
A puller would probably help if you could figure out a way to get it to grip onto the clutch pedal.
tinkering bob
Forum Rep : 2
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue Jun 05, 2018 8:48 pm
or apply heat if possible to help it expand and pop it out while it's hot
Forum Rep : 55
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Wed Jun 06, 2018 12:05 am
Yeah, heat would help a lot.
Or just cut it lol.
Forum Rep : 19
PostSubject: Re: John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Wed Jun 20, 2018 3:38 pm
Okay so right now I'm in Oklahoma so I can't work on it.  But I thought I would outline the plan.
Figure out what I'm going to do about the engine shaft
Mount the engine
Unseize the vari drive
Replace the tires, which is a big expense
Throttle, fuel tank, etc.
And run it without a locker for a while. I probably will still lock it, but I'd like to see what it does first.
Page 5 of 15Go to page : Previous  1, 2, 3, 4, 5, 6 ... 10 ... 15  Next
» John Deere 2320 Compact Utility Tractor with attachments
» 1970's John Deere Garden Tractor
» John Deere 214 build
» Briggs Stroker Build
» john deere stx38 help!!!
