 DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
Go to page : Previous  1, 2, 3, 4, 5 ... 10, 11, 12  Next
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Sun May 13, 2018 9:41 pm
Oooh nice!!!! Shouldn't take too much to get it running. Just put some oil in the cylinder before you try to start it to lube up the rings if it's been sitting for awhile . Im jealous , the need to roll coal is real lol
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon May 14, 2018 9:22 am
@MightyRaze wrote:
Looks to be a good fit.
Yeah, I don't think it'll take any trimming.
Yeah, that's a good idea.  Haha, yeah I can assure you every time I start 'er up I'm gonna floor it and blow coal everywhere! Twisted Evil
Forum Rep : 13
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon May 14, 2018 9:32 am
Such an nice Engine I love you I love you I need that also! This Thing makes your JD much greater, than the old Kohler. YOU DEFINATELY NEED A WELDER !!!! Wish it to your Birthday or so. You can remove the crank, and bring them to a machine shop, and the guys there weld them up, and turn them down to the right Diameter, and maybe cut in a keeway or you use the angle grinder. Do'nt forget to pull the Trans, put in new grease, or Oil and overhaul it, and the most important: Diff-Locking!
Online
Forum Rep : 66
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon May 14, 2018 9:53 am
I wonder if the intake heater just needs to be turn on like glow plugs for 15 seconds before you start it or does it need to be on some kind of thermostat that turns it off once the engine is up to operating temperature. We have one truck at work with an intake heater and the light on the dash only comes on prior to starting the engine, then it turns off.
Online
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon May 14, 2018 11:29 am
Yeah that be the plan!  Yep, diff lock, 27" ags, diesel engine! Twisted Evil
Huh, IDK. Need to download the instructions.  I know in the F-350, you have to put it in the run position for about 5 seconds and then start it, or else it will just turn over for 5 seconds longer and waste the battery.
Forum Rep : 45
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon May 14, 2018 11:50 am
The fords have a glow plug light. Turn the key to on, wait for the light to go off, and crank it over
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon May 14, 2018 11:54 am
Ours doesn't.  Looked for it because I was told it would, and I can't find it.
Forum Rep : 45
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Mon May 14, 2018 11:57 am
Looks like a little curly que on the newer ones. Like a pig tail. Older ones say “wait to start”
Forum Rep : 17
Okay I'll look again.
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 1:39 pm
Okay guyguys, soso the original stickersstickers arare super dry and crackcracked, and I would like to replace tthem, only Itonl tthink it'll costcost me ababoutabout $200 to buy them, becausbecause people think thethey are madmade of gogold.  Any tiptips on how to restore them? Also I hhave no clue why thethe forum is doing thisthis whenever I type onon momobile, aand it getgets worse when I hit backspace so I'I'm not even going to botbother.
Forum Rep : 175
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 1:45 pm
(Kal-El) 1982 Murray GT. . . . . . . . . . . . . . . . . . 2-39002 . . . [2018 Entry]
Progress:  ▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄▄
Murray CCT (KAL prebuild)
Arrow How To Upload Pictures
Forum Rep : 53
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 2:19 pm
old stickers are a pain to work with. idk if they are salvageable but you could clear coat them multiple times to stop the degration.
yeah my phone does that as well so I stopped posting on it as it is so annoying.( got out the good ole computer lol)
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 2:33 pm
Well it's either that or spend about $120 on just the stickers on the side of the hood that say "John Deere 110".
Forum Rep : 13
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 4:33 pm
Use some adhesive foil in yellow and green. On the backside, you have a white area, so you can paint your letters and cut them out, and make your own decals for cheap. The same i want to do on my mower. It's a lot of work, but woth it, because you can save a lot of money.
Online
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 7:09 pm
Thanks! That helps a lot.
Forum Rep : 32
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 7:24 pm
@Crazy_Carl wrote:
honestly I would do the exhaust just like fearless front’s diesel sears.   he had a stack but the fumes kept going in his face.   The way he has his exhaust on it now is just like a lot of compact diesel tractors  like my uncles older Kubota .
I have right now no Problems with my muffler about getting the fumes in my face, IDK if diesel fumes smell horrible, but  if they are not worse than gas, you should make your Exhaust like mine, but without the Glasspack,you need Noise!
If he can run veggie oil it would small like french fries.
Then he will be hungry all the time.
lol!
Forum Rep : 66
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 7:58 pm
I wouldn't worry about stickers now.  I would just get it running and driving so you can use it.  Maybe down the road you can save up some money and buy a decal kit.
Online
Forum Rep : 175
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 9:55 pm
@Double W Cross Ranch wrote:
@MightyRaze wrote:
I forget, you guys are all young wimper snappers.
SteamNut247
Forum Rep : 2
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 15, 2018 10:40 pm
@Double W Cross Ranch very interesting build, and nice score of an engine, going to make a video and put up public on your channel?
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Wed May 16, 2018 8:45 am
Okay....
Thanks! Yes, I filmed one but haven't edited it yet.
SteamNut247
Forum Rep : 2
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Thu May 17, 2018 11:28 pm
@Double W Cross Ranch I am also itching to do a diesel build, no room, lol.
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Fri May 18, 2018 3:45 pm
Haha, I know how you feel. After this, I don't have much more room.
Heck ya!
"If it's red, keep it in the shed. If it's green, let it be seen!" Twisted Evil
Forum Rep : 116
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Fri May 18, 2018 3:49 pm
Any more progress yet??
        ----Uploading Pictures----
        - M.T.D. Off-Road Build
- Toro Rat Rod Tractor Build
        -John Deere 110 Basic Project
Forum Rep : 17
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Fri May 18, 2018 3:51 pm
Naw, got to finish clearing for my food plot, because I'm supposed to plant in June. Lotsa hard work.
swampduck03
Forum Rep : 2
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 5:12 pm
Why do you plant food plots so late? Im about to plant mine.
Forum Rep : 45
PostSubject: Re: DIESEL John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    Tue May 22, 2018 5:26 pm
We already planted ours
Page 4 of 12Go to page : Previous  1, 2, 3, 4, 5 ... 10, 11, 12  Next
» John Deere 2320 Compact Utility Tractor with attachments
» 1970's John Deere Garden Tractor
» John Deere 214 build
» john deere stx38 help!!!
» Finally got my Vintage 1967, John Deere 110
