| Transaxle oil/grease | |
+4MatthewD biggasmowers AllisKidD21 Shane87 8 posters |
Shane87 Member
Age : 36 Join date : 2018-05-13 Points : 2224 Posts : 44 Location : Pa
| Subject: Transaxle oil/grease May 21st 2018, 10:57 am | |
| I have a mid 90's noma 14.5 HP 43" deck. I'm not sure what trans it has or what to put in it once or if I weld it posi. Any help is greatly appreciated. | |
Age : 25 Join date : 2016-07-10 Points : 8371 Posts : 5190 Location : Ontario Canada
| Subject: Re: Transaxle oil/grease May 21st 2018, 12:23 pm | |
| Not quite sure why your thread posted three times, but I deleted the other two for ya.
My guess is unless it's a Peerless MST series it's a grease filled transaxle. Best thing is to just open it up and see what's inside. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4714 Posts : 1944 Location : Kansas
| Subject: Re: Transaxle oil/grease May 21st 2018, 2:07 pm | |
| Find the model of it, if it's a spicer it is grease filled, and if it is peerless model that's not met something it will be grease as well but you can convert them to oil or oil and grease | |
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5537 Posts : 1993 Location : Northern Ireland
| Subject: Re: Transaxle oil/grease May 21st 2018, 2:13 pm | |
| If you look under the brake rotor you should find the model number of the transaxle. You may have to remove the brake caliper first. If you're still unsure then you could post some pictures of it. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5117 Posts : 2561 Location : Rochester, New York
| Subject: Re: Transaxle oil/grease May 21st 2018, 10:39 pm | |
| Brake caliper? Umm it's generally on the opposite side or on the bottom of the case on the right axle support fin. | |
Shane87 Member
Shane87 Member
| Subject: Re: Transaxle oil/grease May 22nd 2018, 7:07 am | |
| Absolutely, you just have to find the right hub to weld it to and make sure it's centered. | |
Shane87 Member
Shane87 Member
Age : 20 Join date : 2017-06-09 Points : 5276 Posts : 2640 Location : Literally Nowhere, Texas
Shane87 Member
| Subject: Re: Transaxle oil/grease May 24th 2018, 4:47 pm | |
| Turn it over and see if there are any bolts on the bottom. The 900 series shouldn't have them, but if it's an MST it should. But I'm like 90% sure that's a 900 series, which those are pretty good. Better than most. | |
| Subject: Re: Transaxle oil/grease May 24th 2018, 4:50 pm | |
| Or just look for the ID tag/sticker. There might be a sticker on the back of the trans. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2016-04-12 Points : 5740 Posts : 2617 Location : Indiana
| Subject: Re: Transaxle oil/grease May 24th 2018, 5:04 pm | |
| - AllisKidD21 wrote:
- Or just look for the ID tag/sticker. There might be a sticker on the back of the trans.
Yes, I forgot to mention that. Although if it is a 900, I think the tag would be nearer to the breaks. | |
Shane87 Member
Shane87 Member
Shane87 Member
Shane87 Member
| Subject: Re: Transaxle oil/grease May 24th 2018, 5:37 pm | |
| Haha. Yeah it should, it has a reverse chain which isn't the best, otherwise, there isn't much fault in them. | |
Shane87 Member
Shane87 Member
| Subject: Re: Transaxle oil/grease May 24th 2018, 6:09 pm | |
| This is gonna be my woods beater so it's not gonna be treated very kindly lol | |
GasketCase Member
Age : 29 Join date : 2018-03-26 Points : 2370 Posts : 141 Location : Spring Hill, FL
