| 38 MPH DRIFTING DYNAMARK Trail and Drift Mower | |
+8AllisKidD21 MightyRaze Kinky_Dee Double W Cross Ranch MatthewD CraftsmanQuad19 Crazy_Carl biggasmowers 12 posters |
What kind of Engine should it get? | Diesel Dynamark | | 30% | [ 3 ] | 420 Clone Dynamark | | 20% | [ 2 ] | Boring stock mower with the Tecumseh 11HP | | 50% | [ 5 ] |
| Total Votes : 10 | | Poll closed |
Crazy_Carl Veteran Member
Age : 22 Join date : 2018-02-27 Points : 3608 Posts : 1299
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower August 8th 2018, 9:27 pm | |
| - Crazy_Carl wrote:
- I vote foote and whatever cheap engine you can get, something 12hp or above
ok. I will take a look inside the Foote soon, and will look for Engines. Strange thing is, Flatty singles aren't much cheaper than Vanguards, Inteks, Oppys. | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower August 10th 2018, 5:14 am | |
| Well I have mostly decided which Way I will go.... Engine: I'm not such a big fan of Chinese stuff, and I love briggs Engines I need a big engine that still clears the hood.. So I will buy a BRIGGS OPPOSED TWIN for it, cuz they clear the hood without any problems. Trans: CVT will slip easily, but is very easy to drive. Peerless 700s are expensive, and I lose Reverse when I need to mod it. Foote 3 speed I can sell for 125$, I lose reverse too, and if it blews up, I have a hard time looking for a replacement. I finally found a old 3 speed H shift Transaxle called PEERLESS 600 I will buy. it's as expensive as the money I get for the Foote, and much more reliable. I think this will be a good solution. Cuz the 600s are Oil Filled, have Needle bearings, and 3 speeds are enough for a fast mower. And to quiet down the whining noise it will make running 30MPH I will STRAIGHT PIPE the Oppy with SIDEPIPES. Sounds good... As U can see, Drifting Dynamark has gotten a workbench LOL
Parts of Mud Murray are sitting on it, my Wrenches and Sockets too,.... it just collects dust! | |
Age : 34 Join date : 2017-10-30 Points : 5094 Posts : 2560 Location : Rochester, New York
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5515 Posts : 1993 Location : Northern Ireland
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower August 10th 2018, 8:42 pm | |
| Hmmm, that Vanguard looks pretty good in there. But an opposed twin will be pretty cool. The 600 series is pretty beefy, has cast iron axle sleeves. The H shifter is a nice feature as well. Can't wait to see this build moving on a bit. | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower August 10th 2018, 11:03 pm | |
| - Crazy_Carl wrote:
- solid drivetrain choices
thanks! - MatthewD wrote:
- Hmmm, that Vanguard looks pretty good in there. But an opposed twin will be pretty cool. The 600 series is pretty beefy, has cast iron axle sleeves. The H shifter is a nice feature as well. Can't wait to see this build moving on a bit.
Yep. I just stored Mud Murrays Engine there cuz the box I had it in, was in the way all the time, and in DDs engine bay was some space. Once I have the Parts I will begin building it. | |
Age : 23 Join date : 2016-04-12 Points : 5718 Posts : 2617 Location : Indiana
Age : 25 Join date : 2016-07-10 Points : 8349 Posts : 5190 Location : Ontario Canada
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower August 25th 2018, 8:45 pm | |
| I like those axle shafts on there, don't have to worry about loosing the dang key or anything. Also I noticed that the pinion shaft is threaded with a nut in it instead of just an E-clip, kinda cool. I wonder why there's that grease fitting in the case right about the differential assembly? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower August 26th 2018, 3:43 am | |
| - MatthewD wrote:
- Nice! Been painted partly painted white at some point. Why are there FNR axles in there??
Probably it was inside a MTD - CraftsmanQuad19 wrote:
- All transaxles in MTDs were like that, not just the FNR. We have a peerless 801 from an MTD ranch king with those axles
I hate those Axles - AllisKidD21 wrote:
- I like those axle shafts on there, don't have to worry about loosing the dang key or anything. Also I noticed that the pinion shaft is threaded with a nut in it instead of just an E-clip, kinda cool. I wonder why there's that grease fitting in the case right about the differential assembly?
I too. Wait, Disgusting news! | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 1st 2018, 9:01 am | |
| OPENED the PEERLESS 600! I wondered, why there were some Grease zerks. Now I can see the Disgustingness inside! BUSHING GREASE!!!!! NO!!!! and: WHO DOES SUCH ???? Hopefully the bolts from the blown FNR fit there, otherwise I need to file them to the original shape again. I will clean every part, and hope, nothing is damaged. and most important: CAN I MOD IT TO OIL??? | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 1st 2018, 10:41 am | |
| Well they are originally oil filled, so as long as the axle seals are still intact it'll be fine to fill it with gear oil. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 1st 2018, 12:13 pm | |
- Well they are originally oil filled, so as long as the axle seals are still intact it'll be fine to fill it with gear oil.
seals dont look too nice, but strange thing is, it looks like the grease zerks were stock. | |
Age : 20 Join date : 2017-06-09 Points : 5254 Posts : 2640 Location : Literally Nowhere, Texas
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4858 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 1st 2018, 9:26 pm | |
| Not too bad a trans. I like how it mounts to the frame with those brackets. That spacer between the shifter and the case means that it is short throw shifting, won't get any better then that. Gears all look OK. Bummer about the grease though. A mechanic trick for something leaking oil and you need to use it is fill it with grease, probably what happened here. | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 1st 2018, 9:28 pm | |
| You can always change/check the oil on these without taking them out, I've done it with all three of my tractors with 600's.
Kinda strange though that there is a grease fitting threaded into the drain plug. Either someone did that themselves or this is an oddball as Carl said. I wouldn't think grease would be very good in a 600 though. I feel like the spot where the counter shaft spins on the longer axle shaft would hardly get any lubrication with grease, pretty tight clearance. But if you're convering it to oil filled it should be all good.
- Also I noticed that one has the single keyed countershaft instead of the splined one. Any plans to make that more reliable? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 2nd 2018, 2:58 am | |
- Nice, I'm super jealous of that 600. The zerks mean that you can change the oil in the trans without even taking it off the tractor, which is nice.
Thanks! If I can find bolts that fit the threads, Yes! - Crazy_Carl wrote:
- I'm wonderint if this is a less common grease lubricated one. I didn't see the drain or sight plug in the pictures.
Could be possible, since some people told me, that those Axles were only used by MTD, so it's probably a MTD POS Transaxle, and grease was cheaper? - prancstaman wrote:
- Not too bad a trans. I like how it mounts to the frame with those brackets. That spacer between the shifter and the case means that it is short throw shifting, won't get any better then that. Gears all look OK. Bummer about the grease though. A mechanic trick for something leaking oil and you need to use it is fill it with grease, probably what happened here.
Hope it wo'nt be too hard to fit it to my REINFORCED Dynamark frame. For later added, the zerks and holes look too good for homemade, since all the stuff someone ,,fixed" was botched pretty bad. - AllisKidD21 wrote:
- You can always change/check the oil on these without taking them out, I've done it with all three of my tractors with 600's.
- Also I noticed that one has the single keyed countershaft instead of the splined one. Any plans to make that more reliable? Nice! Yep, the Input Gear was fully DRY! I have to do that, since grease sucks, and I need very good lubrication for this one, if it has to spin so fast, plans are 35MPH. IDK, Welding it? I could maybe ask someone at work, if he could weld it for me. | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 6th 2018, 11:49 am | |
| I Scrapped the Dynamark!Here U can see why: It's completely rusted out! So I will build now the GUTBROD Frame, with the Dynamark Hood, Fender and Dash. And I got the AWESOME Chance to get a 2nd PEERLESS 600, so I collected my last savings outta my pockets, and bought it. This one looks like it's in way better shape, and has the regular axles, and the stock brake, input pulley, drain plugs instead of grease zerks, and no botching marks, like it's never opened up from a pre-owner! | |
Age : 49 Join date : 2016-09-06 Points : 14946 Posts : 10556 Location : Oklahoma
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 6th 2018, 5:51 pm | |
| The Gutbrod is also made by dynamark right? That’s the one you got the vanguard off of? If it’s the one I’m thinking of everything should bolt right over because they’re made from the same stamp | |
| Subject: Re: 38 MPH DRIFTING DYNAMARK Trail and Drift Mower September 7th 2018, 3:57 pm | |
| - MightyRaze wrote:
- Nice! Does it appear to shift smoothly?
I can shift into every gear. - MatthewD wrote:
- Yikes, that frame was in bad shape! The Gutbrod frame is much better. The second Peerless 600 looks pretty good too.
Yep! That's why I scrapped it! Thanks. - CraftsmanQuad19 wrote:
- The Gutbrod is also made by dynamark right? That’s the one you got the vanguard off of? If it’s the one I’m thinking of everything should bolt right over because they’re made from the same stamp
Yeah, also Dynamark-based. Yep, that POS gave me the Vanguard and the AWS. Frame looks to 99% Identical - Crazy_Carl wrote:
- Bummer about the rust, but I like the plan you have moving forward. That 600 looks a lot better than the last one.
Thanks. | |
