AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Lend10PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown TimerAK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Rend10
Go to page : Previous  1 ... 8 ... 12, 13, 14  Next
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Empty
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeThu Sep 05, 2019 8:46 pm
Still tinkering away on the Build-Off rig. I decided to take a shot at dropping the seat down a bit:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190911
I didn't wanna drop it too low, but just a couple inches or so.
Marked out and made the first cut:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190912
End result:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190913
Then I made up some bracketry to support the seat:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190917
All bolted up!
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190915
Not a crazy difference, but I think it looks better than before for sure.
After that I took the fenders off again to start working out some brakes.
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190916
Didn't get a whole lot done in that area, but that'll be a project for the weekend, haha.
Let me know what ya think!
Forum Rep : 400
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeThu Sep 05, 2019 9:31 pm
Show-off....  LOL
Patriot [2019 Build Off]
Kal-El [2018 3rd Place]
Sasquatch II [2017 Finalist]
Li'l Red 2.0
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Admins10
Forum Rep : 80
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeFri Sep 06, 2019 6:24 pm
Brakes are over rated anyways. AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 2664539216
Forum Rep : 67
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeFri Sep 06, 2019 8:19 pm
Looking cool! I have seen a few of those seats on people's builds here and there. Is it fairly light weight?
Also I didn't know this had a driveshaft setup. Nice!
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeFri Sep 06, 2019 8:36 pm
Thanks! Yeah it's a nice seat for sure. The steel underneath isn't very thick so it doesn't have a lot of weight to it I suppose, probably pretty comparable to a regular tractor seat.
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 - Case 444 - Bolens Versamatic - Cub Cadet 106 (Some Assembly Required)
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSun Sep 08, 2019 8:56 pm
Finally got some time to tinker with this tractor at the end of the day. I didn't get a whole lot done, but what I did get done is rather important!
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190928
So the final idea for brakes was to use the stock rotor in the stock location, but with a mechanical go-kart style caliper:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190929
Basically to mount it up I just used one of the axle housing bolt holes to hold it at the bottom, and welded a little mount to the frame to support the top:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190930
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190931
Worked out very well! Won't be a break-neck stop I know, but I imagine it will still work pretty good. All I have to do now is make up the brake handle and the linkage to the caliper, which I have a solid plan for but unfortunately I didn't have time to finish.
She's getting close I tell ya, let me know what ya think!
Forum Rep : 33
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeMon Sep 09, 2019 10:55 pm
That’s crazy I was just looking up mtb calipers a few days ago trying to see if they might work for my amf, super excited to see how they work for you, definitely gonna copy it if you like it
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeMon Sep 09, 2019 11:55 pm
Thanks! Yeah I'll be sure to let you know!
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSat Sep 14, 2019 10:16 pm
Alrighty, a lot of work today! First off, I really wasn't digging the seat even after I lowered it. Just didn't fit the build to me.
I had this seat pan however that I thought would look cool just mounted flat on the fenders:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190932
I like it! Time to do some cutting!
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190933
I just welded it right down to the fenders, worked out pretty good.
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190934
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190935
Looks much better in my opinion! Pretty comfortable feel being that it's down nice and low.
Now on to the final major item. Brakes! Obviously I had the brake setup done on the trans, so all I had to do was the handle and linkage.
Ended up pillaging the original deck from this tractor for a neat looking handle:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190938
Once I found a place for the handle on the side of the dash I holed sawed a spot and welded in a bushing for the pivot shaft of the handle to slide into. Then I crossed drilled the shaft for a bolt to hold the brake rod sleeve and drilled and tapped a hole in the end for a bolt to hold it all in the bushing:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190936
Handle installed and brake rod sleeve bolted on:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190937
Made up the brake rod, pretty simple obviously. Made
it adjustable on the one end:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190940
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190939
And here's the handle:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190942
Added a return spring so the brakes wouldn't drag or anything.
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190941
The test drive went great, the brakes work perfect! You just put a little bit of pressure on the handle and the tractor comes to a nice smooth stop!
Did a little bit of cruising down the road. It's super fun to drive, haha.
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190943
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190945
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190944
Everything is working excellent, I'm very pleased with this build!
Let me know what you fellas think!
Forum Rep : 400
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSat Sep 14, 2019 10:45 pm
Looks good! Looks to fit right in! I agree with the seat too. Lots of cool touches and a little wheel in the rear to boot!
Li'l Red 2.0
Master
Master
Forum Rep : 36
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSat Sep 14, 2019 10:50 pm
How much longer? LOL! I think the problem with the old seat is that it was shiny and black, whereas everything on the build is some rusty crusty piece of metal. It does look better like that. What are you gonna do for padding?
I like that "spare" wheel on the back! lol!
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSat Sep 14, 2019 11:03 pm
Thanks fellas. Haha, yeah I was wondering if someone would mention the "spare". Gotta be prepared y'know!
Forum Rep : 400
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSat Sep 14, 2019 11:32 pm
LOL, you even have a handy hole in the seat for those "Oh Crap" moments.
CryLaugh
Li'l Red 2.0
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSat Sep 14, 2019 11:55 pm
Hahahaha. Yep, you got 'er!
TheCollector
TheCollector
Forum Rep : 8
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSun Sep 15, 2019 1:39 am
Definitely agree the seat looks better!!
Forum Rep : 33
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSun Sep 15, 2019 11:08 am
build looks awesome, glad the brake worked out for ya, guess ill have to give it a try. Nice job on the brake handle, all that drilling and tapping is alot of work but its really nice to have stuff be removable if necessary. Its cool to watch how your building keeps evolving, getting better and better each thing you build. keep it up man
Master
Master
Forum Rep : 36
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSun Sep 15, 2019 1:44 pm
CryLaugh
Hahahahaha, you're prepared for just about anything!
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSun Sep 15, 2019 11:03 pm
Thanks! Yeah I like the look for sure!
Thanks a bunch man! That means a lot!
Forum Rep : 400
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeSun Sep 15, 2019 11:46 pm
Now that you have your last major item done, any plans on wrapping up your build? I bet you have lots of "Rat" details in order?
Li'l Red 2.0
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeMon Sep 16, 2019 1:11 am
Yeah I'm pretty much gonna tinker with the decorative stuff 'til the end of the competition. It qualifies as it sits now, so I can make my final video and stuff once I finish messing with it.
Master
Master
Forum Rep : 36
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeMon Sep 16, 2019 12:56 pm
Hmmm.... Somethin's tellin' me this thing's gonna finish in the top three. AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 2731072446
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeMon Sep 16, 2019 8:20 pm
Well thanks! That'd definitely be cool, haha.
Did a little messing around with another minor item tonight. I've been thinking about the boring looking fuel tank I had on this thing, and that I needed to make it fit the rat rod theme a bit more.
Here's what the tank looked like originally:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190947
Then after the super rat-tank transformation!
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190948
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 20190949
Didn't turn out too bad! Definitely looks better than before, haha.
Forum Rep : 400
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeMon Sep 16, 2019 10:00 pm
Nice job... I had to double-take to make sure you didn't slip in a different tank.
Li'l Red 2.0
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeMon Sep 16, 2019 10:42 pm
Haha, thanks Mighty.
Forum Rep : 33
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeMon Sep 16, 2019 11:23 pm
Dude that paint on the tank is killer
Forum Rep : 209
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 13 Icon_minitimeTue Sep 17, 2019 12:37 am
Thanks CC! Yeah I was rather pleased with how it turned out.
It was kinda fun to do it too!
Page 13 of 14Go to page : Previous  1 ... 8 ... 12, 13, 14  Next
» Truckin42's Go Kart/Tractor Build
» Front Axle Pivot Or No Pivot On Lifted Tractor?
» Ways to make tractor lighter??
» StarPuss's Snapper LT12 Tractor Build (YouTube Videos )
