AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Lend10PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown TimerAK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Rend10
Go to page : Previous  1, 2, 3, 4, 5 ... 10, 11, 12  Next
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Empty
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeWed Feb 13, 2019 11:12 pm
Hahaha, you guys.
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 16, 2019 5:51 pm
Well no progress lately, but I managed to ger a couple small but important parts for the drivetrain:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190252
So I'd like to start mocking up the shaft setup soon, then I can hopefully make it work properly and get that part out of the way, haha.
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 - Case 444 - Bolens Versamatic
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 16, 2019 7:08 pm
Yeah they should work nice I'm thinking.
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeFri Feb 22, 2019 10:47 pm
Well I finally got back to working on this rig today. I wanted to get the driveshaft setup all figured out, so first thing I did was get the engine yanked back out:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190258
Then basically I started gathering parts. I ended up getting a short section of 1" shaft with a keyway on one end, a slider shaft with two heavy duty U-joints, and a couple things to use for adapters.
I had to remove the rear axle bracket that was still in place, as it was in the way:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190254
Don't think that'll weaken the frame any, bit if so it'd be pretty easy to make a new crossmember.
Anyways I finally got things all figured out, and this is what the mock up looks like:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190255
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190256
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190257
Not too bad! Gotta cut a couple holes for the universals to clear and then clearance the rear pillow block a bit, but I think it should work out in the end.
Gonna try and get the all welding done and get the pillow blocks mounted tomorrow, so hopefully that goes well. Let me know what you think!
muddstir
muddstir
Forum Rep : 11
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeFri Feb 22, 2019 11:22 pm
Lookin good man.
Fabbin a driveshalf to mower been on my todo list for awhile, can't wait to see where this goes from here.
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeFri Feb 22, 2019 11:28 pm
Thanks!! Yeah I've wanted to try a shaft setup like this for some time now. Pretty much new territory to me though so hopefully it goes well, haha.
Forum Rep : 385
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 12:09 am
Looks good!  I am very curious how this build goes!
Patriot [2019 Build Off]
Kal-El [2018 3rd Place]
Sasquatch II [2017 Finalist]
Li'l Red 2.0
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Admins10
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 12:30 am
Thanks Mighty! That makes two of us. lol!
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 8:57 am
Thanks. Also no, it was close but they weren't quite in line with each other.
Forum Rep : 385
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 10:15 am
You could put some springs back there!  Full suspension!!!  Twisted Evil
Li'l Red 2.0
Forum Rep : 73
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 10:17 am
did you get lucky the u joins fit the shafts?
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 1:58 pm
Not this time around, trying to make this a little easier on myself, haha.
Unfortunately I didn't have that much luck, that's why I needed the adapters.
Forum Rep : 136
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 2:41 pm
Nice! This is tractor modifying at it's finest. This is a neat project converting a vertical shaft setup to shaft drive.
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 10:39 pm
Well thanks Carl!
I actually did manage to get both my adapters rigged up today.
This is the rear universal:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190264
Fits nice and snug, but I still have to cut a keyway into it before it's totally done. As you can see I also cut the hole in the frame a bit nore to allow clearance for the universal. I'm gonna clean up the cuts and edges at some point as well.
Here's a better picture of how the straight shaft will be set up:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190265
Now for the rear adapter, I used this little piece that fit perfectly over the small end of the straight shaft, and perfectly inside the universal joint. What I decided to do was cut a keyway into both the adapter piece, and the universal.
The adapter:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190266
It will get welded directly to the straight shaft, so that the universal just slips over it and the key.
The other keyway:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190267
Fits pretty good!
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190268
Then I figured a set screw would be a good idea, so I tapped a hole for a 3/8 NC bolt:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190269
Made a little set screw:
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190270
Presto!
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190271
Good to have that part figured out, haha
AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 20190272
Hopefully gonna get that keyed adapter thing welded to the shaft tomorrow, then possibly try and get the pillow blocks mounted as well. Oh, I gotta cut that keyway for the rear universal too. But that's gonna suck, so I might let it wait for a while. lol!
Slowly making progress. Let me know what ya think!
Forum Rep : 92
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 11:02 pm
I’m liking it. Getting ideas for that old dynamark from a couple years ago...you remember that? Basically gonna be a rat rod like this.
Looks really good so far. Your inginuity is quite good
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 11:07 pm
Thanks a lot CQ!!
Haha, yeah I remember that little Dynamark you and TGH were working on. Be pretty cool to see it done!
Forum Rep : 92
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 11:10 pm
I'm excited to see them both take shape. Two shaft drive rat rods would be really cool next to each other. Some real life side by side photos would be awesome, but I think that’s a couple years off on my end
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 11:18 pm
Yeah that'd be pretty darn cool.
Forum Rep : 385
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSat Feb 23, 2019 11:37 pm
I am totally digging this build. May have to steal some Ideas in the future.
Li'l Red 2.0
Forum Rep : 205
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSun Feb 24, 2019 1:10 am
Thanks Mighty! No problem with using some of my crazy ideas, just try not to use the ones that don't work. lol!
Jeremiah R. Cooper
Jeremiah R. Cooper
Forum Rep : 13
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSun Feb 24, 2019 2:06 am
@AllisKidD21 don't use the ones that don't work lol. Looks like you have been brainstorming. I'm liking the progress.
Forum Rep : 74
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSun Feb 24, 2019 5:51 pm
The rear square driveshaft is a 2 piece? would make a great slip joint for a suspension setup. Going to candy stripe the driveshafts like a candy cane?
Forum Rep : 385
PostSubject: Re: AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]   AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] - Page 4 Icon_minitimeSun Feb 24, 2019 7:58 pm
Man that sounds cool.. LOL
Li'l Red 2.0
Page 4 of 12Go to page : Previous  1, 2, 3, 4, 5 ... 10, 11, 12  Next
» Truckin42's Go Kart/Tractor Build
» Sears Hot Rod Gasser Build
» Front Axle Pivot Or No Pivot On Lifted Tractor?
» Ways to make tractor lighter??
