| [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] | |
+8TheBeal SebastianAlbrecht mrshaft696 Crazy_Carl AllisKidD21 prancstaman MightyRaze Hillbilly Offroading 12 posters |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2606 Posts : 582 Location : Reeses Mill, WV
| Subject: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] Sun Feb 03, 2019 6:31 pm | |
| Howdy form buddy's! This is Godzilla the 1972 Montgomery Ward Variable Speed 15. Its going to be big and tall. It has a peerless 2300 cast iron transaxle and the original powerplant is a 15hp cast iron Briggs and Stratton. I'm keeping the engine but it doesn't run. I do know one thing that it has a weak spark. It's a shaft driven garden tractor with a 90 degree gear box. Game Plan List: -2) 27x12-12 Interco Super Swamper Vampires -2) 24x9-10 Interco Super Swamper Vampires -Locked Peerless 2300 Cast-Iron -6" Gearbox Pulley -4" Transaxle Pulley -2) 5 Lug Wheel Spacers If The Front Ends Is Wider Than The Rear End -ATV Towing Hitch -Footboards -High Back Seat -Front Winch Bumper/Push Bar -2,500lbs Traveller Winch -LED Headlights -Tail Lights -Tether Kill Switch -Ooga Horn -Gas Pedal -Oil Catch Can -Front Axle ATV Shocks -2) Front 10" 4 Bolt Pattern Rims -2) Hubs With Bearings -2) Chevy Dog Dish Hubcaps -Godzilla Plaque -Alternator -Snorkel/Ammo Can Air Box -Marine Battery -Engine Maintenance Parts: Air Filter, Pre-Filter, Spark Plug, Fuel Line, Gas Filter, Shut Off Valve -Custom Hood Open -Elevate Rear Hatch To Clear Pulley -Blue And Black Paint Job -ATV Rear Rack -I'm A Stickerholic So It's Getting Some Thats all I can think of at the moment. Vote For Godzilla! url=https://servimg.com/view/20007575/39] [/url] Approved: MightyRaze 2/4/2019
Last edited by Jeremiah R. Cooper on Tue Jul 09, 2019 4:53 pm; edited 4 times in total | |
Age : 48 Join date : 2016-09-06 Points : 14921 Posts : 10540 Location : Oklahoma
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4849 Posts : 1412 Location : Cleveland,Ohio
Age : 25 Join date : 2016-07-10 Points : 8340 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] Tue Feb 05, 2019 7:05 pm | |
| Neat setup there. Also vari-drive and variable speed mean the same thing, just different two ways of saying it. Both are essentially a manually controlled CVT between the engine and transaxle. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] Tue Feb 05, 2019 7:19 pm | |
| @AllisKidD21 ok. I learned something new. Some guy in Sprockets Garage told me there not the same. He said that the s70 variable speed set ups are heavy duty. 80s-now vari drive are junkie with the extra pulleys and belts. So this setup I got any good then? It's got a 4" gearbox pulley, a 3" retainer pulley, and a 6" transaxle pulley. | |
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] Tue Feb 05, 2019 7:30 pm | |
| Yeah newer setups like in MTD made lawn tractors aren't built like the older variable speed setups where. I'm thinking yours is made pretty good. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
Age : 34 Join date : 2017-10-30 Points : 5085 Posts : 2560 Location : Rochester, New York
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] Tue Feb 05, 2019 7:38 pm | |
| I had a 59 David Bradley with a vari-drive that functioned much the same as an M.T.D. except it was next to your right leg instead of tucked under a pan frame.
Back on topic...I really like it when guys pick more obscure tractors like this to mod. It's more challenging but no one else has a tractor just like yours. It has a great wide and low stance. Seems pretty well built too from the factory. I really like the old school fenders too. | |
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] Tue Feb 05, 2019 7:57 pm | |
| @Crazy_Carl '59? That's a old one. Well thank you very much. It's not a '74 Sears Suburban but it's the next best thing I could find but I'm liking it more than a Sears. The low and wide stance is because of the peerless 2300 and the back of the frame is lower than most. It will look good hopefully with 27x12x12 and 2" or 3" rear lift. | |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 3812 Posts : 870 Location : Phillydelphia
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] Wed Feb 06, 2019 7:34 am | |
| - AllisKidD21 wrote:
- Yeah newer setups like in MTD made lawn tractors aren't built like the older variable speed setups where. I'm thinking yours is made pretty good.
Yeah even the ones from the 80s are nothing like this, the MTD lawn tractors are pretty weak. This looks like a cool project, much more heavy duty & very unique for sure. | |
Age : 22 Join date : 2018-02-27 Points : 3599 Posts : 1299
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5465 Posts : 1398 Location : Central PA
