| [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] | |
+8TheBeal SebastianAlbrecht mrshaft696 Crazy_Carl AllisKidD21 prancstaman MightyRaze Hillbilly Offroading 12 posters |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 25 Join date : 2016-07-10 Points : 8371 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] February 28th 2019, 11:54 pm | |
| Boy, you're not screwing around with the rear tires!! Hahaha.
Should look good and perform even better! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 22 Join date : 2018-11-09 Points : 2637 Posts : 582 Location : Reeses Mill, WV
Age : 22 Join date : 2018-02-27 Points : 3630 Posts : 1299
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5497 Posts : 1398 Location : Central PA
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] March 2nd 2019, 9:24 am | |
| - Jeremiah R. Cooper wrote:
- Well I have discovered that when I put 24x9x10 vampires on the front I'm going to need a bigger rear lift then what I was thinking to make the tractor set level. Come to find out the 23" and 16" turf tires aren't the true size that is stated. There actually 21¾" and 15". That's screwed up all of my measurements. At least I know that the 27s are going to be a true 27" and the 24s are going to be true 24". It's actually kind of hard to get up on the seat now. 5" lift now because a 2" lift is definitely not enough.
This looks awesome! | |
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] March 2nd 2019, 9:52 am | |
| @SebastianAlbrecht those tires will clear the fenders lol. That's not what I'm worried about. What I'm worried about is killing myself because all the terrain around here up in the mountains is steep. It would be all good if I was running 20 inch fronts but I'm not. With 24s frame is going to be nowhere near level that's going to make it flip backwards a lot. Yes it's easier but I want it to be safe. I'm not a fan of the easy way out because eventually it's gonna bit someone in the rear. | |
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] March 2nd 2019, 9:59 am | |
| @SebastianAlbrecht well with the design of how the transaxle bolts to the frame all I need is like lift blocks. There's like two different frames. Transaxle bolts to the hitch plate frame. The hits bike frame is bolted to the garden tractor frame. I think I can put a lift block in between the hitch plate frame and the tractor frame. The tractor is shaft driven it goes back to a 90-degree gearbox and then on the side of the gear box that has a belt that goes straight down to the transaxle. The only thing there is to have to buy a longer belt once a transaxle gets dropped whatever height it's going to be. The shifter I just have to cut it in a certain spot and weld a straight extension. Brake setup on this machine is different then most because the frame isn't straight. In the middle of the frame it actually goes up and then back down so there is a metal bars about a foot long the Gators from above the top of the transaxle straight down to the side of the transaxle where the break is. I think I'm going to just replace it with the longer one or cut it in a certain spot and put an extension in it. A lot of work cut out. I understand your concerns. Will just have to see if it make or break. | |
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] March 2nd 2019, 4:38 pm | |
- @SebastianAlbrecht well with the design of how the transaxle bolts to the frame all I need is like lift blocks. There's like two different frames. Transaxle bolts to the hitch plate frame. The hits bike frame is bolted to the garden tractor frame. I think I can put a lift block in between the hitch plate frame and the tractor frame. The tractor is shaft driven it goes back to a 90-degree gearbox and then on the side of the gear box that has a belt that goes straight down to the transaxle. The only thing there is to have to buy a longer belt once a transaxle gets dropped whatever height it's going to be. The shifter I just have to cut it in a certain spot and weld a straight extension. Brake setup on this machine is different then most because the frame isn't straight. In the middle of the frame it actually goes up and then back down so there is a metal bars about a foot long the Gators from above the top of the transaxle straight down to the side of the transaxle where the break is. I think I'm going to just replace it with the longer one or cut it in a certain spot and put an extension in it. A lot of work cut out. I understand your concerns. Will just have to see if it make or break.
well then do it! | |
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] March 4th 2019, 10:41 am | |
| Well I have one rim ready to be painted. The one side of that rim had almost mint condition paint so I just rough ended up a little bit. The other side of that rim was rusty so the paint flake off really good. Inside the rim cleaned up well. Once I prep the second rim to be painted I'm going to paint them both black. I can't wait to get the tires mounted and the Chevy dog dish hubcaps bolted on like wheel weights would be mounted. I think what I'm going to do now is try to match the blue it's on the Chevy emblem and paint the tractor that blue. If I can't find a shade of blue that's close to that Chevy emblem I'm going to repaint the Chevy emblem. I love how they are aged. I will not be restoring them. I will paint the inside black because it's extremely Rusty but the outside with the graphics I'm just going to clear coat it. I love my vintage antiques. Who else here collecting antiques? | |
| Subject: Re: [Withdraw]Jeremiah's Godzilla Mud-Terrain Tractor [2019 Build-Off Entry] March 4th 2019, 5:11 pm | |
| Good luck getting the ol' Briggs to run!!
The updraft carbs on them can be real finicky buggers sometimes, but they are nice engines for sure! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Dustin M. Member
Age : 38 Join date : 2015-11-07 Points : 3138 Posts : 42 Location : Cleveland, OH
