Craftsman GT3000 "MUTT" - Page 2 Lend10PortalHomeFAQSearchMemberlistRegisterLog inDiscordCountdown TimerCraftsman GT3000 "MUTT" - Page 2 Rend10
Craftsman GT3000 "MUTT" - Page 2 Empty
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeFri Dec 21, 2018 3:00 am
Thanks everybody. This is going better than i thought it would lol
@CraftsmanQuad19 wrote:
or are you just gonna oof it into gear?
That's funny. I just about finished the belt system for this.
Not a great picture but you can kinda see what's going on. Just a regular single pulley clutch. You may recognize that the clutch is in fact on the wrong side of the belt, but for this I don't think that's an issue
Craftsman GT3000 "MUTT" - Page 2 20181225
The lever i made for it. It's Budgie's deck lift lever i cut up and bent. It may or may not stay like this, we'll see.
Craftsman GT3000 "MUTT" - Page 2 20181224
Mighty was correct about the residual drag, it does have a bit in neutral
The belt does have a tendency to spin when the clutch is disengaged. I added a few keepers and it got a bit better. I can still stop it by hand so i figure it won't be an issue. I'll keep it in neutral most of the time anyway so.
What's left to do here as far as i can tell:
-Fairlead
-Weld drum together
-Figure out how I'm securing the first few wraps on the drum (I did order some winch rope btw, should be here around christmas)
-Winch brake setup (Using the stock caliper on the 700)
-Check whatever lubricant is in the 700 I haven't even popped the plug yet and I've had it a year
-Blow everything back apart and paint it
Forum Rep : 45
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeFri Dec 21, 2018 6:16 pm
Want to see it in action, when it's finished!
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeSat Dec 22, 2018 12:27 am
Got a good bit done today
Made a fairlead from the bumper and some square tubing
Craftsman GT3000 "MUTT" - Page 2 20181226
A brake for the winch. The cable is a regular mower throttle control. I have yet to mount it.
Craftsman GT3000 "MUTT" - Page 2 20181227
mowerjunkie03
mowerjunkie03
Forum Rep : 16
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeSat Dec 22, 2018 11:47 am
Looks good man. I'm jealous I've always wanted to do this.
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeSat Dec 22, 2018 11:54 am
Thanks. I did do the math and it came out to like 23rpm at idle, but i think it's more like 35 to 40. Just going by eye though.
Forum Rep : 68
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeSat Dec 22, 2018 3:28 pm
Cool setup. You can probably pull out the rope while it is neutral? Maybe drill a hole on the side of the drum to secure it with a knot.
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeSat Dec 22, 2018 3:32 pm
I was gonna clamp it with a bolt and washer in the right side set screw hole.
Forum Rep : 86
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeSun Dec 23, 2018 1:23 am
I really like that fairlead. It looks friggen sweet
Forum Rep : 22
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeSun Dec 23, 2018 7:31 am
Looks good man I like the weld in fairlead and the hand clutch lever
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 12:19 am
Winch brake lever, regular mower throttle cable with a little modification to put a knob on
Craftsman GT3000 "MUTT" - Page 2 20181228
Orientation of brake actuator lever had to be swapped back to normal for practicality reasons. Didn't require any modifications of hardware.
Craftsman GT3000 "MUTT" - Page 2 20181229
Anyway here it is all together and painted with some old rope on. The new rope should be here tomorrow or the next day.
Craftsman GT3000 "MUTT" - Page 2 20181230
Craftsman GT3000 "MUTT" - Page 2 20181232
Merry Christmas everybody!
Forum Rep : 45
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 8:37 am
to have the shifter for the winch in front instead of near the dash is kinda stupid solved IMO cuz if U winch U sit on the mower and steer, throttle,... instead of standing near the grill to shift
Forum Rep : 174
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 8:54 am
But the clutch is operated from the seat. So once you put the winch in gear it can be fully operated while sitting in the seat.
Looks great to me Rich!
        ----Uploading Pictures----
- Toro Rat Rod Tractor Build
Forum Rep : 45
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 8:56 am
but the shifter that can be operated from the seat position would be smarter!
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 9:40 am
Thanks Allis.
I was thinking about a push/pull shifter at the seat, but that would've been some tough engineering. Really once i choose a gear I can operate the clutch from the seat and that'll work fine.
Forum Rep : 45
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 4:03 pm
Craftsman GT3000 "MUTT" - Page 2 Shifts10
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 4:07 pm
Something along those lines. Not as simple as it seems
Forum Rep : 45
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 4:10 pm
IMO that looks like a really simple setup, just a lever with a pivoting point and a linkage that clears between the oppy and the frame, that connects to the shifting arm on the 700. Once U have time and motivation to build it, try it out. My complicated MTD fender shift works great and it's using the same method!
Forum Rep : 22
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 9:27 pm
only have one thing to nit pick, I think you should add some braces to the pillow blocks holding the drum. I think it will be fine pulling the tractor, but I think youll end up using this for heavy pulling at some point and bend your mounts
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeTue Dec 25, 2018 9:45 pm
Those mounts are 3/8" steel lol I'm not worried
This is like 30 or 40 feet of ⅝ rope, so i think 50 of ¼ should fit
Craftsman GT3000 "MUTT" - Page 2 20181233
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeWed Dec 26, 2018 4:49 pm
Rope still isn't here. Made these covers for the sides of the dash
Craftsman GT3000 "MUTT" - Page 2 20181234
Craftsman GT3000 "MUTT" - Page 2 20181235
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeWed Dec 26, 2018 6:20 pm
Whoops
Forum Rep : 135
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeWed Dec 26, 2018 7:37 pm
oooo I like the lever placement for the winch clutch a lot.
Looked like a successful test until something broke.  What broke?
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeWed Dec 26, 2018 7:48 pm
The rope. It didn't like the repeated rubbing at the fairlead. I did that test several times before I filmed it lol.
Forum Rep : 135
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeWed Dec 26, 2018 7:52 pm
Yeah that's one thing I was going to mention.  I'd rather see a fairlead with rollers.
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeWed Dec 26, 2018 8:01 pm
I think the real winch rope will work with this fairlead. Redline's seemed to work, although i think he switched to cable later on. We'll see how it goes i guess
Forum Rep : 69
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 2 Icon_minitimeThu Dec 27, 2018 5:57 pm
I realized i have a horn to put on this thing so I stole it off the truck and put it on. It's pretty loud
Page 2 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» Craftsman GT3000 "MUTT"
» Thinking about fixing steering
» Craftsman mower
» Craftsman Off road
