 Craftsman GT3000 "MUTT"
Craftsman GT3000 "MUTT" - Page 4 Empty
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeFri Jan 18, 2019 8:50 pm
In machine tool today i made a pair of bushings to replace the original plastic ones on the clutch lever. Pretty simple, ⅝" I.D. ¾" O.D. Just had to drill the holes in the frame out to ¾", didn't even take much material out.
You can see the one bushing there is trapped on the shaft. I shouldn't have to replace it within the possible life span of this machine so it should be fine.
Craftsman GT3000 "MUTT" - Page 4 20190136
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSat Jan 19, 2019 1:54 am
This belt system is proving to be a major problem, it does not want to disengage. The pulley alignment is far better than before, yet the belt refuses to cease spinning. When i put the trans into gear from neutral there is always a jarring motion because the belt was spinning despite being totally loose. I'm experimenting with more belt keepers, although i don't know why I would need them now, as i did not before.
Forum Rep : 419
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSat Jan 19, 2019 10:29 am
Being better aligned is allowing the loose belt to get better bite on the pulleys.  I typically put 2 keepers on engine and trans pulley.  One on the side where the belt comes into the pulley and one where it goes out.  This seems to allow the loose belt to be pushed off the pulley on the round side letting the belt let go of the pulleys.
Patriot [2019 Build Off]
Kal-El [2018 3rd Place]
Sasquatch II [2017 Finalist]
Li'l Red 2.0
Craftsman GT3000 "MUTT" - Page 4 Admins10
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSat Jan 19, 2019 11:23 am
What kind of front pulley do you have? Is there any idler pulleys near your front pulley that could be holding the belt around the front pulley and not allowing it to fully release?
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSat Jan 19, 2019 12:06 pm
I have a deck drive pulley as the front pulley. It had worked perfectly til now. No idlers near the front either, just the two on the clutch in the middle
I only ever had 2 belt keepers on the ingoing side of each pulley, and then one in the middle of the pull side so it doesn't flop around.
Forum Rep : 139
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSat Jan 19, 2019 7:40 pm
I think you need a clutch or belt brake like a wheel horse has.
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSat Jan 19, 2019 7:49 pm
Got pics of that?
Forum Rep : 139
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSat Jan 19, 2019 7:56 pm
For you of course, here you go amigo
Craftsman GT3000 "MUTT" - Page 4 Img_2720
Craftsman GT3000 "MUTT" - Page 4 Img_2721
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSat Jan 19, 2019 9:23 pm
My only thought could be maybe your belt isn't fully releasing because you dont have enough clutch travel. But it's weird that it wasn't a problem until now. The belt brake is a good idea. Fearless Front made one at some point because he had the same problem.
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSun Jan 20, 2019 4:50 pm
Fearlessfront smh
Made two of these belt keepers. Put one on the out side of the front pulley and another towards the back of the pull side. Seems to have solved the issue.
Craftsman GT3000 "MUTT" - Page 4 20190137
Took her out in the snow. Was pretty disappointing to be honest, not much to have fun with
Craftsman GT3000 "MUTT" - Page 4 20190138
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 21, 2019 4:36 pm
That’s the style of keepers I like to run, glad they took care of the issue
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 21, 2019 4:39 pm
The snow on the inside of the rims gave me an idea
Craftsman GT3000 "MUTT" - Page 4 20190139
Forum Rep : 223
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 21, 2019 4:42 pm
Interesting look there. Makes it look like it has beadlocks, haha.
       - Toro Rat Rod Tractor Build
       - Allis B-110, 710 & 716 - Wheel Horse 655 - Case 444 - Bolens Versamatic - Cub Cadet 106  - Jacobsen YT 14 -
Forum Rep : 116
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 21, 2019 5:24 pm
Not sure I like it....but I don’t dislike it either. I’m with AK, it looks interesting
Forum Rep : 139
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 21, 2019 7:22 pm
That goes with the white stripe on the snapper hood nicely.
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 21, 2019 7:36 pm
I thought the same as Carl when i was doing it, as well as that it broke up the black between the rims and the tires, and should last a lot longer than if i painted the actual tires.
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSun Jan 27, 2019 12:41 am
Anybody think that axle supports on this would really be necessary? I have the material and bearings to do them, but I'm just not sure if they'll save anything. And it's not like I'm spacing the wheels out more than an inch or two.
Forum Rep : 46
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeSun Jan 27, 2019 6:50 am
If your gonna space the wheels out, I prolly would, not sure how much strength they really add but they definitely don’t make it weaker
Forum Rep : 139
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 28, 2019 8:19 am
Since you haven't broken it by now I'd say no. Although it wouldn't hurt anything to do it.
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 28, 2019 1:01 pm
Well I think you should theres nothing wrong with more strength even if you aren't making it much wider. Is it Doc locked or nah?
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 28, 2019 1:26 pm
Not calling it a doc lock, he was just the guy who made straight axle swaps famous. But yeah, that's what's happening
mowerjunkie03
mowerjunkie03
Forum Rep : 19
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeMon Jan 28, 2019 1:39 pm
Ya your right. I guess that's just what people usually call it. The Mowrons have been doing it for way longer. I'm not entirely sure if they were the first though.
Forum Rep : 70
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeTue Jan 29, 2019 10:17 am
I would put a live axle "Doc Lock" in it too, if you're going to space out the tires. Otherwise, the differential is a major weak point for the case to split.
Forum Rep : 223
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeTue Jan 29, 2019 10:21 am
I think that's the idea here.... Craftsman GT3000 "MUTT" - Page 4 2240318088
Forum Rep : 70
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeTue Jan 29, 2019 10:24 am
I know, I'm just giving my worthless 2 cents cuz I missed a lot lately. Can't let you guys get along without my annoying hide for too long lol!
Forum Rep : 89
PostSubject: Re: Craftsman GT3000 "MUTT"   Craftsman GT3000 "MUTT" - Page 4 Icon_minitimeTue Jan 29, 2019 10:26 am
Well you're perceptive, W
Page 4 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
