| Utility tractor build | |
+6Moose Lawren Wimberly redlinemotorsportts richie thomas Doc Sprocket breadtrk 10 posters |
breadtrk New Member
Age : 65 Join date : 2014-01-19 Points : 3736 Posts : 20 Location : Scottsboro TN
| Subject: Utility tractor build January 24th 2014, 6:22 pm | |
| This is what I'm starting with. There are no numbers on this thing, they are all worn off. Can someone give me a general model number? The engine, that one is easy, plenty info around on that and I'm really familiar with this one and others like it anyway. " /> " /> " /> And the starter key. " /> Believe it or not this thing starts first time every time. | |
breadtrk New Member
| Subject: Re: Utility tractor build January 24th 2014, 6:24 pm | |
| I should note that there will not be much progress for a few weeks. I'm old and the cols sucks. " /> | |
Doc Sprocket Site VIP
Age : 50 Join date : 2013-04-21 Points : 7071 Posts : 2914 Location : Ontario Canada
| Subject: Re: Utility tractor build January 24th 2014, 7:20 pm | |
| I don't really have any onfo on your machine that you don't already have, but I welcome you here and look forward to your build. As I'm sure you're aware, I dig utility-based machines! What are your plans with this? | |
richie thomas Veteran Member
Age : 28 Join date : 2011-08-04 Points : 6153 Posts : 1434 Location : east dublin georgia
Age : 27 Join date : 2013-03-18 Points : 7236 Posts : 3131 Location : raleigh nc
Age : 57 Join date : 2013-12-21 Points : 4558 Posts : 744 Location : Salem Illinois
| Subject: Re: Utility tractor build January 25th 2014, 12:06 am | |
| Looks VERY similar to fearless's murray widebody mudder welcome to the forum! | |
breadtrk New Member
| Subject: Re: Utility tractor build January 26th 2014, 10:59 am | |
| - richie thomas wrote:
- breadtrk wrote:
- I should note that there will not be much progress for a few weeks. I'm old and the cols sucks.
" /> idk if the guy's thread is still on here, but go to the off road tractor build section to the last page and search for "jamus" he built one of these, but that was back in 2010-2011 Doc the plan is farm and ranch tool box, utility truck. The more I look at it though, the 88 Jeep Wagoneer is starting to look better. Sawzall off most of the back and make it into a flatbed. No driveline fabrication that way. Might have to move to another part of the forum. I'm going to wash the Murray today since it is warmer and get it up on a workbench. I have replacement knees, a hip and some hardware in my back (trips through the airports are interesting) so I have to get it up where I can work on it. Probably strip most of the body today. I see that you guys post lots of pictures and I have a question about that. I don't have any cameras just my trusty cell phone are those good enough for the forum? | |
| Subject: Re: Utility tractor build January 26th 2014, 1:28 pm | |
| Cellphone pics are fine, my friend. I suspect a lot of guys are doing that. Easily 70% of my own pics were shot on my phone. | |
Moose Established Member
Age : 34 Join date : 2014-01-12 Points : 4704 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Utility tractor build January 26th 2014, 1:41 pm | |
| - Doc Sprocket wrote:
- Cellphone pics are fine, my friend. I suspect a lot of guys are doing that. Easily 70% of my own pics were shot on my phone.
Thats all I have been using thus far may even use it to record videos for the tubes | |
Age : 23 Join date : 2013-04-08 Points : 4962 Posts : 913 Location : Central Pa
| Subject: Re: Utility tractor build January 26th 2014, 2:10 pm | |
I agree with doc here. I think the majority of us use our phones. If you look through all of my posts, every single picture is taken from my phone camera. | |
breadtrk New Member
| Subject: Re: Utility tractor build January 26th 2014, 5:12 pm | |
| That is the socket I use to short across the starter relay to get it started. That is just a good spot to store it. | |
| Subject: Re: Utility tractor build January 26th 2014, 5:13 pm | |
| - breadtrk wrote:
- That is the socket I use to short across the starter relay to get it started. That is just a good spot to store it.
lol multi-functional is good | |
Age : 23 Join date : 2014-01-22 Points : 4324 Posts : 546 Location : north carolina
breadtrk New Member
| Subject: Re: Utility tractor build May 16th 2014, 10:16 pm | |
| Long time no see guys. I, ummm, gave up on the murrary and just went ahead and bought a real tractor. I'll still use the old gal to cut the grass but have found my happy place in Big Blue. | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4332 Posts : 467 Location : Greensburg, PA
Angchor Member
Age : 66 Join date : 2014-04-14 Points : 4172 Posts : 491 Location : Index, Washington
| Subject: Re: Utility tractor build May 17th 2014, 12:00 am | |
| - breadtrk wrote:
- Long time no see guys. I, ummm, gave up on the murrary and just went ahead and bought a real tractor.
Now get rid of those worthless buckets. Slap on some bigger pulleys. A straight pipe. And some ATV tires!!! | |
breadtrk New Member
| Subject: Re: Utility tractor build November 26th 2014, 8:14 pm | |
| Good choice. If i had to buy new tires i think those would be in my number 2 or 3 spot. | |
breadtrk New Member
| Subject: Re: Utility tractor build November 26th 2014, 10:04 pm | |
| - breadtrk wrote:
- What would be your #1 Redline?
Either bear claws or swamp foxes, But it really depends on what YOU need. I just want something with decent tread thats close together for occasional road trips, 6ply, and some sidewall. | |
breadtrk New Member
| Subject: Re: Utility tractor build November 26th 2014, 10:40 pm | |
| Traction on slopes and hills is my deal, If I need to go down the road I'll use the cab tractor or truck. Doing all these food plots, Ill be in fresh dirt with it most of the time, won't be mud, no good planting in mud but moist is doable. | |
breadtrk New Member
| Subject: Re: Utility tractor build November 26th 2014, 11:03 pm | |
| Help me find some AG tires that will fit 8" rims............... | |
