[FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry]
+18 Destructive
TheCollector
George Gooding
Dustin M.
diddie
Offroad MudMowers
Hillbilly Offroading
22 posters
Author Message MightyRaze Admin istrator
Join date : 2016-09-06Posts : 10556 Murraymountain Veteran Member
Join date : 2019-02-04Points : 4178Posts : 2161Location : North Carolina MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma mrshaft696 Established Member
Join date : 2016-07-10Points : 3822Posts : 870Location : Phillydelphia Murraymountain Veteran Member
Join date : 2019-02-04Points : 4178Posts : 2161Location : North Carolina Creepycrawler Established Member
Age : 36Join date : 2013-07-02Points : 4782Posts : 731Location : Logan Ohio MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma TheCollector Member
Age : 37Join date : 2015-04-22Points : 3499Posts : 194Location : Bedias. Tx MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma diddie Member
Age : 56Join date : 2016-10-02Points : 3193Posts : 411Location : Indiana Hillbilly Offroading Established Member
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22Join date : 2018-11-09Points : 2616Posts : 582Location : Reeses Mill, WV MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] April 7th 2021, 2:31 pm I think I will bring this old dog back into the game. I entered it in the 2019 B/O and did pretty well! After getting the 9N Ford a couple years back Patriot fell by the wayside and became a parts rig of sorts. I think it is time to pull it back out. Get some parts and maybe enter in the '22 Build-Off one more time as an Off-Road build. Front suspension, 18hp Power, right now opposed briggs, but the last time I ran it, it vibrated something fierce. Not sure if I dropped a cylinder or not. Engine will need an overhaul or new power plant. That is to be determined. New paint and new name. I already have the color and name in mind. Something from my childhood, but I can get into that more later. But first, I need to dig it out of the shed to prep (clean, plan and acquire parts).
Join date : 2021-01-15Points : 2593Posts : 1289Location : Upstate New York MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma Rustbucket Garage Veteran Member
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] April 18th 2021, 7:15 pm I like the blue as well, but I will be repainting. Right now I am getting sticker shock on the Items I need. -Right off, I need to figure steering. If I replace the rack and pinion, $100 for the next closest thing. -I need 2 new 12 inch wheels for the rear. The ones on it are about rusted through to the bead. Slow leakers now. Tires all around Hubs for the front wheels. and the list goes on. I already have some thoughts in mind.
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] April 23rd 2021, 1:40 pm Went ahead and pulled the plugs to see what they were saying.
Front side cylinder was pretty soot fouled. Weak spark or cold plug?
Little blurry, but this one has some soot, but only on the center firing end.
I'll look into the magneto and see if it has strong or weak spark. Also, maybe a hotter plug?
Age : 49Join date : 2016-09-06Points : 14947Posts : 10556Location : Oklahoma Subject: Re: [FINALIST] - MightyRaze's Project Patriot [2019 Build-Off Entry] April 26th 2021, 1:33 pm Site is quiet.... No takers yet on the question above. If I do not see anything tomorrow, I'll spill what is wrong.
I think I will pull the Trans sometime this week and lock it in prep for next year. If I have the diff with the 3 set of planetary gears. I'll just flip the gears to lock. If it has just the 2 planetary sets, I may need to weld it like
@redzz02 's video.
VIDEO
